Question about Hotpoint First Edition FEW12 Front Load Washer
My Hoover First Edition keeps filling with water to the point of it pouring out of the door. It seems to be draining fine, but just keeps letting in short bursts of water, which don't seem to stop. Eventually, the weight of the water gets too much for the door and it pours out. I need to make a decision on whether it's fixable or if I need to buy a new machine as I can't be without a machine for more than a couple of days. Many thanks for your ideas.
  • Hotpoint Master
  • 17,130 Answers
This seems quite likely to be a fault of the WATER LEVEL SENSOR. So since the pressure activated switch is not working even when the set water level is reached the water overflows.
Drain the water out of the washer and remove the level sensor which is located on the rim of the drum which has a tube feeding water to a pressure activated switch- the diaphragm could have punctured or failed on the switch.
You can bypass the switch by shorting to see if the machine starts and works , if so change the switch.
Posted on May 18, 2011
  • 654123a May 18, 2011
    Thanks for your solution, which makes perfect sense. Can you advise if the sensor is accessible from within the drum that the laundry is loaded into, or do we need to remove a panel to access it from behind?
Water freezing in bottom freezer
The drain line is clogged, unplug. Remove the back panel being very careful not to cut yourself or damage the evaporator. Remove the ice not sharp or pointed objects for this, just hot water. Lay towels down and start pouring hot water until you hear it go down the drain.
Mar 14, 2015 | Samsung Refrigerators
Why is my Viking refrigerator/bottom freezer leaking water out bottom of door? There is a layer of ice on bottom of freezer.
The ice on the bottom of the freezer is blocking a drain hole. When the freezer defrosts automatically, water drains out the bottom into a tray, where it evaporates away and you never see it under most conditions.
The solution is to either defrost the freezer manually and let the ice melt, or pour some hot water into the bottom of the freezer to thaw out the ice and clear the blockage.
If the drain is plugged because of some foreign matter, either method will make a mess, so have some towels at the ready to sop everything up if need be. If it is blocked, a can of Air Duster (like for cleaning electronics) might be able to blow the blockage out, if you seal the nozzle tube up as it is stuck into the drain.
Most likely it is just ice blockage.
You can access the drain tray (where the water goes to evaporate) by removing the grille on the front bottom of the fridge and peeking / poking around. You might want to keep an eye on it as you defrost the freezer or pour hot water in the bottom - it can over-fill quickly.
Jul 20, 2014 | Viking Refrigerators
Gld2445rfso will not fill up with water -- it will run fine and drain if I pour water into the unit and shut the door but will not fill -- water is fine at the entry point when disconnected -- worked fine...
Check the voltage at the solenoid valve and then check the reistance to it. This will tell you if the voltage is not present, replace the control board, if the resistance is high (infinity) replace the valve. If both are normal the valve is stuck, replace it.
Dec 16, 2013 | Dishwashers
My kenmore refrigeratot model 58087 has ice in the bottom of the freezer section. I assume this is from a clog somewhere in the automatic defrost lines. How do I get to these lines to clean them?
Unplug the unit! You have to remove the shelves and the rear panel of the freezer. I take two coffee cups filled with water heat them in the microwave for 2-3 minutes and keep pouring them on the ice until you see the drain, keep pouring the hot water at this point and let the hot water sit a little keep doing this until the water drains down if it doesn't drain down then you still have ice in the drain tube or you have a object in it so use compressed air if you can. Use a lot of bath towels to help with catching the water inside the unit while working in the freezer.
Sep 27, 2011 | Kenmore Side by Side Refrigerator
I have water leaking into both drivers and passengers footwells in my Suzuki Grand Vitara. Heater matrix seems fine and the washer bottle pipes seem fine. Have checked seals on door panel. Again, fine....
Does it have to do with the AC. I had a similar problem with my vitara and they said a washer was prob loose in the ac system which would cause the water to leak to the footwell. Mine was only the passenger side.
Apr 04, 2010 | 2003 Suzuki Vitara
Hoover Dishwasher - d823 - Water pours out the front door of the machine from time to time even when empty - Seems to overfill as well
this problem will usually be your bottom and main door seal for over filling will most probs be ure side chamber and pressure chamber
Feb 03, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Soap in JetDry dispenser.
Unfortunately there is no easy way to completely get the detergent out of the rinse aid reservoir in one quick method, short of taking the inside panel off the door.
However, I would try a simple way to flush it out. With the door open almost al the way open, pour warm/hot water into the rinse aid fill hole and keep pouring until you start to get clear water coming out. The water will be flowing back out the fill hole you're pouring the water into and should just flow down the door panel into the dishwasher tub. Try to keep the door about 10-15 degrees up from all the way open to let the water get in the rinse aid reservoir.
Just pour the water in slowing so you don't agitate the mixture and you should be able to get it running clear in 5-10 minutes. It could take a gallon or so of warm/hot water to accomplish this, but it will flush it.
When you'r done, just put the dishwasher into a rinse cycle to pump out the water and soap, etc. You may have to run a full cycle afterwards to get rid of any excess detergent in the tub.
Hope this helps and best regards!
Aug 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My washer has a fusty smell i use it regually can anyone ntell me what is causing this smell
try doing a wash no clothes fill washer with hot water pour 2 cups good old clorox chlorine bleach into water let wash before it drains open door and wash area around door seal let drain and rinse leave door open as much as possible in future to allow water traped in boot to evaporate as much as possible
Jul 31, 2008 | Indesit Washing Machines
Timer on dishwasher not working
ok start the washer after it fills and starts washing open the door again and turn the dial to drain shut the door see if it drains if it does then open the door and turn it to heated dry shut the door and get you a small glass of warm water let it sit in heated dry for about 3 minutes open the door and pour the water on the heating element and let me know if it sizzles
Mar 27, 2008 | Dishwashers
Hotpoint First Edition FEW12 Front Load Washer Logo
78 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
