Question about HP Photosmart D5160 InkJet Printer
Squeak When the printer takes in A4 paper from the tray it squeaks loudly. This does not happen at any other stage of the printing. Any suggestions would be much appreciated. I am very satisfied with this printer except for its annoying squeak.
PHOTPSMART PRINTER 4180 MAKES SQUEAK SOUND WHEN SCANNIN
Posted on Jan 30, 2009
4mv won't pick up paper
The feed rollers need to be replaced. The squeak is the worn rollers sliding over the edge of the paper.
Mar 25, 2014 | HP LaserJet 4mv Printer
Hp 3035mfp is not taking up the paper, there is a loud squeak
Please remove paper then check Pick roller , should clean
Mar 18, 2013 | HP LaserJet M3035 MFP Printer
My Dell 5210n printer has a very loud squeak in the back. How do open the printer to lubricate the bearings?
Usually you don't lubricate. It is probably the fuser assembly wearing. How is the print quality? Have you ran a test page, ran a supply status page? Checked the error log?
Jan 17, 2013 | Dell 5210n Laser Printer
My HL 2140 squeeks loudly when I turn it on as well as when it is printing
it most likely has parts that are worn out and need replaced. you will need to have it serviced.
Oct 09, 2012 | Brother HL 2140 Laser Printer
A3 paper jams up as it exists the fusser unit. This usually only happens after printing off three sheets. A4 paper works fine. Paper weight is 80 grams on A3 and A4 and the fusser is set to normal...
chances are the pickup rollers are worn and in need of replacement,these are located just above the tray inside the printer and are both easy to remove and widely available
May 18, 2011 | Office Equipment & Supplies
Hello sir, how to take print on A4 page? please help me
Hi The A4 paper size is an internationally used paper format. Although not often used in America, it is by far the most commonly and widely circulated paper size. At 8 1/4 inches by 11 3/4 inches, it is similar though not quite identical to the American standard U.S. letter size, which is 8 1/2 inches by 11 inches. Because of its ubiquity, all printers and programs have the ability to handle the size, and getting a printer to print to it is a matter of adjusting the settings.Put the A4 sized paper into the automatic feeder in the printer. You may have to adjust the tray guides to fit the paper in snugly. Close the tray firmly when finished.
  • Step 2.Set the printer to register the A4 sized paper inside the the tray. This varies from printer to printer but generally involves going into the print menu, scrolling to the automatic feeder and designating the tray as an A4 tray.Step 3.Select "File" and then "Page setup" in the program you are using.Step 4.lick on the drop down menumag-glass_10x10.gif next to paper size and choose "A4.Step 5.Select "File" and then "Print." Click the "Print Summary" button to ensure the file is set to print to the A4 size.
  • Step 6.Press "Print" to print the photograph.
  • Jul 31, 2010 | Toshiba e-Studio163 Copier
    Error 241.1 Paper Jam. I have reseated the tray
    Brand New T652n lexmark printer get a paper jam every time! just opened and haven't been able to print one paper. Doesn't matter if you print from tray one or tray two. It gets stuck right after the rollers pick it up and try to send it to the toner. Any suggestions? I've tried to reseat the toner, plain paper, sized the paper correctly, I've tried just about everything I can think of! I can feed paper manually through the top tray, and it will print. But, just using the manual tray defeats the purpose of the other two trays. Anyone else having this issue?
    May 26, 2010 | Dell 5310n Laser Printer
    Hl-2140 noises
    For a possible fix to the Brother HL-2140 squeal/squeak/noise problem open the printer at the other side from the paper tray and toner cartridge door. You should see a little black roller rod along with some white wheels.
    The noise may be coming from the contact between the wheels/rollers which pull paper toward the output tray on top after it has been printed.
    Check and clean/wipe the wheels and black rod, especially in the center area. Hopefully the noise will now be reduced/eliminated.
    Cheers, Stephen
    Sep 14, 2009 | Brother HL 2140 Laser Printer
    Squeaky Printer
    Mine had a similar squeak and I took the toner out and shook it. Squeak went away.
    May 29, 2008 | HP LaserJet 1100 Printer
    Loud noise/paper tray not working
    What error? Does it say paper jam and a number? Have you tried cleaning the rollers that pick up the paper? Use a cotton cloth with a little bit of WD40. Then a dry cloth to remove residue oil. Do not use alcohol. It will dry out the roller and make it slick.
    Aug 08, 2007 | Ricoh Aficio AP410N Laser Printer
    HP Photosmart D5160 InkJet Printer Logo
    1,307 people viewed this question
    Ben Johnson
