Question about LG Dishwashers
Good day, I have an lg dishwasher LD-2131SH. It it continuously giving me the error OE (drainage trouble). I have cleaned the filters and checked for kinks in the pipe and everything is clear. Please help! What else could it be. Thanks Yaseen
  • 1003 Answers
SOURCE: LD-14AW1 keeps coming up with OE error code
REPLACE PCB POWER CONTROL BOARD
Posted on Jan 18, 2008
SOURCE: OE Error
had the same problem and had the pump replaced
Posted on Mar 11, 2008
  • 171 Answers
SOURCE: LG Dishwasher LD 2060SH OE Error code Draining problem
Hi sonicmule,
I'm Harvey the Master Plumber.
Your question is: Re-circulation pump was replaced under warranty after 7 months. Now there appears to be draining problems. hose not kinked and filter seems clear - I guess the pump is either broken or something has jammed it. Does anyone know how to get at it??? Warranty has expired and a new pump + fitting is gonna be expensive. Any tips?
If the motor runs but it won't empty then the pump needs replacement. If the unit washes but the motor won't come on to empty then you have a control problem. Either way I don't recomend this repair to the average homeowner. The unit must be removed to access the pump. You might consider utilizing our Repair Directory to find a repair man.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
SOURCE: LG Dishwasher Model LD-4120M Error 0E
I had the same endless problem and finaly put a cleaning product through with heaps of restarts and now the machine works perfectly. So anyone out there with the OE error should try this inexpensive solution. If it does not work you have not lost much. You may need to restart several times during the process and is a great pain but maybe it will solve your problem .
Posted on Apr 21, 2009
  • 3230 Answers
SOURCE: Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Posted on May 06, 2009
Ld14aw3 error code 0e lg dishwasher
LD 14AW3 Service Manual pdf
Mike - Here is the service manual.
Use - ld14aw3
Apr 07, 2014 | Dishwashers
Hello, LG LD 14AT1 dishwasher, starts cycle runs 3 minutes, starts stops on off no water in bottom. Then displays OE chimes! Checked tap under sink water there, checked filter inside bottom, turned off for...
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
Error code OE
The error is DE - DRAIN ERROR , Not fully drained out in spite of 5 min. drain operation
Possible causes
¥ The Filter clogged.
¥ The Drain Hose kinked or blocked.
¥ The Drain Pump/Motor or circuit is troubled.
Possible solutions
¥ Clean the Filter.
¥ Remove the cause of kink or block.
¥ Replace the Drain Pump/Motor or repair the Circuit.
Jul 09, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error Code OE
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
My husband has just installed a LG LD 14AW2 which was given to us
OE = Outlet Error It involves everything related to pumping the water out. Easiest is to start at the drain and work back. Check for a plugged drain. then a kink in the drain hose. A plugged hose?
If problem remains, remove lower rack and unscrew/remove the filter from the sump area, looking for debris. Rinse out any filter in the mesh filter. Look again for anything that is blocking the drain outlet. Reassemble and run a cycle.
If problems continue, the probable cause is a failing pump motor. Servce call time.
Good Luck!
Mar 30, 2009 | GE GSD5920 Dishwasher
Ld-1204w1
What did you find the problem to be?
On an LG dishwasher, I am not aware of an E0 error. But there is a "OE" error code (as in output error)
The first thing to check is the lower sump area - remove the filter beneath the spray arm and look everywhere for blockages that have slipped through. If that is not the problem, the drain motor has probably failed.
Good Luck!
Oct 19, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Lg - LDS5811ST Dishwasher OE Error Code
hi
May 11, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Error
The ?OE? indicates drainage trouble. It could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Sep 16, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
Good Luck!!!
Oct 28, 2006 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
32 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
