Question about Hotpoint 24 in. DWF33 Built-in Dishwasher
Nothing happens when switched on although light illuminate and huming sound heard. small amount of water in filter/drain?
    Sergeant:
    Champion:
  • 252 Answers
Your water valve If you are not getting any water, the valve is stuck in closed position.
Posted on May 18, 2011
There doesn't seem to be any water coming out of my machine, although it sounds like its running, nothing is happening. the light is flashing on the pan wash
The most common reason is because the drain pipe at the entry to the garbage disposal is clogged. Place a pan under the pipe, remove the rubber drain hose, and clean the inside. Some states require a device called an "Air Gap". These tend to get blocked and prevent water from draining.
Feb 12, 2015 | Dishwashers
Kenmore 600 series washer
Sounds like this could be a blocked/air-locked filter.
easy fix if so.
First. switch off the Machine at the socket.
Check your washing machine user manual for the location of the pump filter access screw. (Normally situated behind a front bottom clip out panel) ensure you have a few towels and a couple of pans/dishes at the ready before releasing the access screw, expect two or three litres of water to drain... as well as whatever is blocking the filter. (could just be an air blockage or a small object) replace the filter screw and clip off panel, switch on at mains.
Hope this helps.
Aug 26, 2014 | Kenmore Washing Machines
Machine does not seem to be filling properly, then does nothing else.
Sounds like you're fill valves are junk which sadly happens allot. This video is very generic but should give you an idea
Jul 06, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
We have a Haier DW12-PFE2-U dishwasher thats 2 years old. The cycle stopped yesterday leaving an amount of water in the bottom and all of the program lights are illuminated with a recurring beeping sound...
Refer userr guide on page 21. It reads...
When all the programme indicators " J" blink.
Have you checked whether:
the door is closed properly.
The door switch could be the problem or the door seal is pushing the door open. May need replacement.
May 19, 2011 | Dishwashers
Washing machine EWF1087 Main light works, nothing else does, no display. Machine stopped half way through a wash, still full of water and clothes.
http://safemanuals.com/314159.php?k=0412aef66a84f8f875bfc5cd7f91d5c0&ID=281660&q=AEG-ELECTROLUX%20EWF1087
user manual.
http://www.home-appliance-kitchen-aids.com/washing-machine-repairs.html
troubleshooting advice.
Washing-machine-repairs - The washing-machine fills with water but does not start the washing cycle
1. The water level sensor or float switch may be faulty. If the unit does not sense that the water is at the right level nothing will happen.
2. When the water filling rate appears very slow, the inlet water filters may be clogged. Although not that common the inlet solenoid valve can jam and only partially lift.
3. The cycle timer or program circuit board may be faulty
http://www.washingmachinerepair.info/the_enquiry.html
Shows how it should operate.
There is a thermal switch inside the pump and this corrodes even after a year. If the filter is blocked the the pump has to work harder and so heats up (a lot). This switch is prone to staying open once it trips out.
SOLUTION
Isolate machine from mains and water supply.
Empty machine with drain hose and bucket at floor level.
Clean Filter out.
Turn machine on its side.
Remove electrical connections from pump.
Remove 3 screws holding pump (small leakage so get a towel).
Remove PUMP from machine. (be observant now)
Remove plastic cover over coil on pump.(its easy)
Thermal switch is soldered between 2 of the now 3 visible terminals. about 7mm x 15mm x 2mm in size
Remove small insulating cover and bend switch up about 30 degrees then flick with fingernail and blow out the dust or rust.
This resets the switch (horray)
Replace insulation on switch and bend back into position gently.
Replace cover over the coil.
Turn pump by hand (resistance should be like pushing 2 small/ medium size magnets together the wrong way)
Return pump to machine and reconnect pumps electrical connections. 2
Reconnect machine to mains (water and electric and waste)
Turn on machine while holding START and SKIP BUTTONS at the SAME TIME.
Leave it off for five mins then turn off and turn on again.
If it does not work straight away RESET again and Repeat as above.
SELECT PROGRAM AND WASH ALL YOUR TROUBLES AWAY.
Apr 11, 2010 | Washing Machines
Quiet Partners III will not start. It blinks and then goes off. If I push the "Cancel" pad, it lights 2 and it attempots to drain (no water in tub) and then the light goes to 1 and within a minute it goe...
Sounds like the anti flood activates when water (even a small amount) appears on the bottom of the machiene. This is usualy a leaking pipe but can also be caused by a clogged pipe. Most machiens do have a plastic pipe that (from the flat water tank) feeds water to the bottom of the machiene in case of an internal fault. The anti flood is normaly a polystireen float with micro switch on the base of the washer. This automatically puts the outlet pump on to drain the water. Nothing else happens until you clear the water problem.
Jan 18, 2010 | Dishwashers
Bosch classicxx dishwasher not working check water light on
he there,
sounds like there may be something caught in the drain pump itself.
can you provide me with the complete model # on your dishwasher please?
thanks
Sep 25, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Zanussi IZ 12 Washing Machine Front Load
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Aug 28, 2008 | Zanussi FJS1225W Front Load Washer
Hotpoint bwm129 making huming noise
Sounds like the rinse water can't come. Maybe the solenoid for cold water got stuck or a water filter needs cleaning? If the humming is louder, perhaps the drum motor (or drum) needs a little care or cleaning.
If all else fails, download the user manual and check the trouble checklist index. (Or; try learning your kenpo succession move sparring against laundry to clean it.)
Apr 14, 2008 | Hotpoint BWM12 Front Load Washer
Hotpoint 24 in. DWF33 Built-in Dishwasher Logo
199 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
