Question about Stanton STR8-100 Turntable
My stanton str8 100 makes a rubbing noise when its turned on
  • 670 Answers
Rubbing as in its grinding or just a like its in motion its normal to hear some type of rubbing as the platter spins because if u notice when u push down on the platter it has some play you can clean the inside by removig the platter and cleaning and dirt and dust
Posted on May 20, 2011
In the right rear I get a rubbing noise when making a left turn or during rapid acceleration.
If the tire started coming apart it could have hit the brake dust cover and bent it.
May 01, 2016 | 2002 Jaguar X-Type
What causes a popping noise from front end, and a rubbing noise , not grinding
4wd?? Check CV shafts. Also look for whats rubbing. whre is the dirt rubbed off.
Feb 26, 2016 | 2005 GMC Yukon
Convert 45s to mp3s - sound scratchy
Just check the connections to the cartridge on the Stanton. Make certain they fit and are correctly fitted. Also check or replace the stylus, if it is not new.
Jun 14, 2012 | Stanton T.92 USB Turntable
2003 camry with 200,000 miles has rubbing noise not the brakes wondering if a cv joint or u joint problem
If you have a rubbing noise on the BRAKES then its most likely the pads worn out and touching the metal backing plate ,other wise it could be the wheel bearing worn or coming loose but the CV Joint if worn will make a clanking noise when turned on full lock either Left or Right.
So jack it up at the front and check the wheel bearings and turn the wheel to see if the noise is there as it will be a metal to metal noise ,but if pads are good then it will just be a soft rubbing noise.
Mar 22, 2011 | 2003 Toyota Camry
Rubbing/grinding noise
Usually the strut bearing will make this noise upon turning a corner and hitting a rut or pot hole when turning. A wheel bearing will make a low pitched whinning sound constantly
Jan 16, 2010 | 1998 Ford Ranger SuperCab
Truck making a knocking noise when turning getting a little feed back in steering wheel to. only 35,000 k when hard turn almost sound like its rubbing something or grinding. if shaking steering shaft it...
there is a problem with the steering shaft going to gear box 2 out of 10 trucks have this problem gmc and chevy ive done a few, its a dealer part, replace that first then see if the other rubbing noise is there, but the knock noise is the shaft, i had 2 with about that mileage they were out of warranty, good luck start there first.
Oct 31, 2009 | 2006 GMC Sierra Denali
Noise coming from front of car
It sounds exactly like a wheel bearing problem.The right side its seems would be the problem. When you turn right it puts more pressure on the bad bearing making it louder. I would suggest replacing both. If on is gone the other one isn't far off. Hope this helps
Mar 05, 2009 | 2008 Hyundai Elantra
STANTON STR8-150 Sound levels
try different rca leads to amp
Jun 01, 2008 | Stanton STR8-150 Turntable
STANTON SK-FIVE MIXER HOOK UP
are the gnds connected(earths) you get a buzzin noise if not earthed
May 15, 2008 | Stanton Sk2f DJ Scratch Mixer - Good...
Stanton STR8-100 Turntable Logo
319 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
