Question about Price Pfister Home
How do I change the hot water setting on a new cartridge?
    Problem Solver:
  • 16 Answers
HELLO- This type of valve has a two piece catridge,you will have to adjust it till it reaches the hot water inlet. A little tricky but you can do it, be sure to shut water off to shower!!!!! Good luck.
Posted on May 19, 2011
Moen water flow restricted and only warm
Not sure about your particular valve, but most newer shower valves have an anti-scald limiter that stops the handle from turning too far to the hot water side. Check for a ring or a pin under the handle that can be set in different positions. It will need to be moved clockwise to allow the handle to rotate farther to hot.
Hope that helps. If you have trouble finding it, try looking up a diagram for the valve model.
Jul 03, 2017 | Moen & Replacement Cartridge
We have a new Price Pfister 49 Series bathroom faucet set with two handles. Even with the hot water tap open full the water just dribbles out
If you have full pressure on the cold water side and low pressure on the hot side then you well need to remove and clean or replace the cartridge for the hot side. If you have low water pressure on both sides try removing the aerator and cleaning it.
If you need to replace the cartridge on the hot side do both sides while you at it.
Whenever you work on any faucet before you turn the water on remove the aerator and run the water for a few seconds then replace the aerator.
Mar 07, 2011 | Price Pfister Two Handle Lavatory Faucet -...
I installed a new Price Pfister 08 series tub & shower single control, pressure balancing valve body.The temperature adjustment is set at full travel for temperature. The water doesn't get very hot at...
No and you can thank you government rep next time you see or talk to him for this. The valve is set to give no more than 110 to 115 degree water and cannot be changed. If you want hotter water you will need to install a non-scald faucet. Now if you are not getting to the 110 degree mark then you will need to disassemble the valve body and look for debris in the hot water inlet side.
Now when it is apart turn the water on low and flush the piping out before putting it back together.
Feb 11, 2011 | Price Pfister Universal 0X8-310A Pressure...
We installed a new singel handled faucte in our shower and now we are running out of hot water. this never happened in this house before. we always have plenty of hot water, i called delta and they said...
The way the faucet cartridge is designed it will protect you from large changes in water pressure. This can happen if someone is useing the shower and someone else flushes a tolet there is a sliding valve in the cartridge that will close off hot water supply to protect you from getting scalded.If you are not getting hot enough water there are adjustment you can make to increase the maximum setting.
As long as you are getting good hot water supply in other fixtures in your house I doubt that changeing the water heater is going to help.
I think that you may have a defective cartridge and I would call delta again and give them another chance. They generally have very good customer service, and perhaps the one you talked do did not understand that you have good hot water supply elsewhere.
If you do not have hot enough water to shower valve that can eaisily adjusted by removing set screw that holds the handle on and remove the handle.If there is a white temp. limit disc on the stem then remove it. Slid the chrome sleeve from around the valve body off. You should see a disc that you can slid out a little and rotate to the left a small amount. This adjusting disc and its mating surface have teeth on them that mate. There should be marks on the valve and disc with a arrow on them to show which way to turn for hotter water.Reassemble and check.
If your water starts out hot and then gets cooler while being used and you still have hot water in other places then I think you have a defective cartridge. It should be under warranty. Hope this helps you some. Good luck and thank you.
Jan 26, 2011 | Delta & Single Handle Shower Faucet
I cant adjust water temp 0n a single handle kohler shower valve
4yrs isn't very long, but I do believe the mixer needs a new cartridge in it. unless you have a loose knob/handle.But I don't thnk so. The temps should change almost immediatley. Have someone change the cartridge. It may need a special tool. If you think you can, do it yourself, the tool comes with full instructions. Make sure it does, consult with the pkumbing person .
Nov 09, 2009 | Water Heaters
Instructions for refill tonner
Changing the print cartridge
1. Open the print cartridge door, and remove the old print cartridge. See the recycling
information inside the print cartridge box.
CAUTION To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper.
2. Remove the new print cartridge from the packaging.
3. Bend the tab on the left side of the cartridge to break it loose.
4. Pull the tab until all the tape is removed from the cartridge. Put the tab in the print cartridge box to return for recycling.
5. Gently rock the toner cartridge from front to back to distribute the toner evenly inside the
cartridge.
6. Insert the print cartridge in the printer, making sure that the print cartridge is in position.
Close the print cartridge door.
CAUTION If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water.
Hot water sets toner into the fabric.
Oct 31, 2009 | HP LaserJet 1160 Printer
Moen kitchen faucet. I changed the cartridge but
Single or dual lever? A new ball if single lever. Home Depot or Menards will carry them. Teflon tape if dual cartridge. Stay away from moving parts
Aug 14, 2009 | Moen & One Handle Tub & Shower Faucet
No hot water
turm off the water at the main first.
take the handle and the plate off the control.
use a plier to take out the cartridge.
replace with a new one or you can repair by change all of the "O" rings and rubber sets.
make sure the postion when you take off the cartridge. there is front and back to the cartridge. if you install it backwards, it will not work.
Dec 04, 2008 | Moen 3175 Legend One Handle Shower Faucet...
7 orage light blink on my canon s520 printer
Take printer head and cartridges out - remove cartridges - wash printer head in hot /warm water for 30 mins - dry - place 5 drops of alcohol- metho - no drinking - on each noozle and let stand for 5mins. wash printer head in clean hot water for 10 mins - dry - clean outlets of cartridges with 3 drops alcohol - hic - remove scum layer until colour shows ie black,cyan, magenta & yellow - set into printer - set test page - stand back and admire the quality print of your new printer - RC
Aug 28, 2008 | Canon S520 InkJet Photo Printer
Home Logo
180 people viewed this question
Top Price Pfister Home Experts
Mike
Tim Whalen
Are you a Price Pfister Home Expert? Answer questions, earn points and help others
