When I purchased my Acco Rexel Goliath Stapler, there were no instructions/instruction manual with the stapler. It appears now that some staple pins are jammed in the area where you load the staple pins and I can't staple with it. How do I get these out?
  • 2072 Answers
SOURCE: AS 300 electric stapler--pulled out
What has most likely happened is part of a staple is stuck in the front portion of the stapler where it forms the staple and presses it into the stapler.
You would most likely have to remove the stapler, and remove the binding staple from the stapler head.
Posted on Sep 28, 2008
  • 40 Answers
SOURCE: instructions on unjamming swingline electric
First, are you using the recommended staples for this stapler? Many heavy duty electric staplers don't use "standard" desk staples. Second, try unplugging the stapler, unloading the staples, and if possible, reach a couple of fingers into the stapler and try manually pushing up on the staple head to see if you can get the driver blade to come down. Does it come down smoothly, or does it seem like there is something stuck in there? If you aren't sure about disassembling the unit (my usual method-but I'd recommend having the parts diagram handy), try using a flashlight to look at the underside of the staple head, where the staples come out - can you see anything stuck in there? If so, you might be able to use a small knife blade or small dental pick to get jammed staple pieces out.
Posted on Mar 14, 2009
rowdy45176
  • 2176 Answers
SOURCE: Disassembled the stapler now need diagram to reassemble
Found user manual online but no parts breakdown, I have a phone number at 1-800-343-9329 and they might be to email you the breakdown. Wish I had better info but this is all they furnish online.
Posted on Mar 15, 2009
goalie39
  • 469 Answers
SOURCE: stapler is not dispensing staples after new cartridge is inserted. Can you help?
Remove the staple cartridge, look into the cartrige area, are there any stray staples in this area, if so remove them, cycle the unit a couple of times without the cartrige in place, check the output end, any stray staples here? re assemble making sure you pull the first row ow staples even with the nozzle of the cartrige.
Hope this helps
Ed
Posted on Apr 30, 2009
SOURCE: Staples penetrate, but do not bend
If you unscrew 4 bottom screws to lift the top cover, you may find out that there are 2 orange rubbers above its hammer that broke and needs to be replaced.
Posted on Jun 25, 2009
Rexel stapler
Sadly, the solution to this problem is very simply, and stated on the instructions for the stapler, which I ignored myself until I had bought my third one and continued to have the jamming problem. The solution is you HAVE to use the Optima staples they sell. Look for them in the silver metal box, and they are labeled Optima. Once I did that, all three of the staplers worked without a hitch, and I love them. Good luck!
Sep 30, 2013 | Swingline 48210 Optima ® 70 Electric...
How to load staples into rexel easy touch stapler
If you imagine that the end that the staples come out of is the front, then the back is where you load the staples. Your picture shows a small black bit at the very back of the stapler. You have to remove this, usually by pushing it in and lifting it up. Once loosened, it should pull out from the back of the stapler. You should then be able to reload. Finishing is the reverse process.
Nov 05, 2012 | Tools & Hardware - Others
How do I open up a rexel stapler?
There's a plastic button on the back of the Rexel stapler that says "press."
May 04, 2012 | Tools & Hardware - Others
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
I have a rexel odyssey heavy duty stapler but the spring has popped out, how and where do I attach it back on?
Rexel Odyssey heavy duty stapler: The pring that pushes the staples into position can come losse if the stapler iss dropped. It's difficult to work out how to replace it! However, there are only two "lugs" that will take the circular ends of the spring. One obviously fits to the sliding staple retainer. The other to the back end of the pressed-metal inner body. However, to work, the spring must be threaded from this point along the pressed metal parallel-sided inner body back through a slot and over a rounded bent piece (shiny from prvious friction) and back down to the sliding staple retainer. It's trickey to do, but that's where it has to go in order to provide forward tension when the Stapler is closed.
Aug 02, 2011 | Office Equipment & Supplies
Trying to load the staples into a model #90010. They're fine except at the very front of the stapler, they wont go all the way down flush with the others and the chamber won't even close.
1. Make sure you have the correct staples for the machine, Swingline Hvy-Duty Staples for 90010 Stapler, 0.625-Inch Leg Length, 2500 per Box (90009)
2. Check the staples to make sure there are no visible jams. Remove some staples from the row if this helps them fit.
3. If you continue to have problems, contact the manufacturer at http://www.acco.com/swingline/, or
Repair Service/Technical Support:
Phone: 800.790.7787
They will replace the stapler if needed.
Apr 14, 2011 | Swingline ® LightTouch Heavy-Duty Stapler,...
Swingline 270 (69270) Staple ends are left mostly open Also, stapler makes a significant popping noise with each use
Swingline, now owned by ACCO, should have a service manual that would tell you how to clear jams - here's the url - http://www.acco.com/contactus.aspx#swingline. If not, you can also send them your question directly so they can help you resolve the issue.
Jan 27, 2011 | Office Equipment & Supplies
How do you load the stapler, powershot 5700m
Here are the scanned images from the Black & Decker 5700 Powershot Instruction Manual. These are just the instructions and corresponding illustrations for how to load the stapler, but the full instruction manual is available here:
http://servicenet.blackanddecker.com/Products/Detail/5700#
Jan 11, 2011 | Black & Decker 5700 Powershot Forward...
Hi Guys Rexel Cosmos 210 Stapler (Staple Gun - Mk II) I have a Rexel Cosmos 210 Stapler that has a broken white plastic bit. I have had it and used it at work for about 25 years. How can I get a...
I have one equally old and my plastic bit broke off many years ago.
I just get used to using it without.
It sticks but it's such a good stapler I forgive it.
Jun 12, 2010 | ACCO Brands Office Equipment & Supplies
977 people viewed this question
jasbo
jasbo
