Question about HP LaserJet 5200 Printer
13.20.00 JAM INSIDE TOP COVER - HP LaserJet 5200 Printer
    Genius:
  • 1,089 Answers
Without seeing the printer or knowing what you have already done....a "13.20 Jam inside top cover" error means that a jam occurred in the registration assembly area.
Remove the toner cartridge.
Remove all paper from inside printer.
You should see a metal flap. That's part of the "registration assembly".
Lift it up and make sure that all paper pieces are removed. Use a flashlight if you can.
Make sure that the media size that you are using matches the tray settings and the dial on the tray.
Reinstall the cartridge and try again.
Posted on May 19, 2011
  • 393 Answers
SOURCE: 13.20.00 Jam in top cover area, no jam
pull your fuser out and you will find the jam and reason for the noise. it is pulled from the rear 2 covers and 2 screws
Posted on Jun 23, 2009
SOURCE: paper jammed problem 13.05.00 JAM INSIDE TOP COVER
It happens form both: manual feed and tray... sensors don't look misplaced.
Posted on Jan 17, 2008
pineworks
  • 4041 Answers
SOURCE: 13/20.00 jam inside top cover message and have
Hello there
Ok try this may cleaer it.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 09, 2010
  • 12 Answers
SOURCE: Have Kyocero 2050. Error - Misfeed paper - Open
JAM 00 means ..printer not able to pickup paper from tray... check paper pickup assy.. and also check registration sensor...
Posted on Feb 07, 2011
celibytes
  • 70 Answers
SOURCE: paper jam on top cover but ther is no paper on top
There could be a problem with the sensor it might got stack,look for the small movable part near that top cover,
Posted on Apr 15, 2010
I have 5200 hp laserjet printer is a problem 13.05.00 jam inside top cover tell me this problem
A jam has occurred in the registration
assembly area.
1. Press the 'down arrow' to see step-by-step
information.
2. Open the top cover and remove the print
cartridge.
3. Remove all media inside.
4. Lift the metal flap and remove any
remaining media.
5. Verify that the media size matches the
6. Reinstall the print cartridge and close
the top cover.
7. To exit, press ? .
Oct 27, 2011 | HP LaserJet 5200 Printer
My HP 8500 a909a states there is a carriage jam. However there is not paper jam. I've tried resetting it and turning off, pluging into wall outlet, removing and replacing the printheads. I think...
Hi, please try this:
1. Remove all media from the output tray.
2. Check the duplexer.
a. Push the button on either side of the duplexer, and then remove the panel or unit.
b. Locate any jammed media inside the device, grasp it with both hands and then pull it towards you.
c. If the jam is not there, push the latch on the top of the duplexer and lower its cover. If the jam is inside, carefully remove it. Close the cover.
d. Reinsert the duplexer into the device.
3. Open the top cover and remove any debris.
4. If you have not found the jam and have Tray 2 installed, pull out the tray and remove the jammed media, if possible. If not, do the following:
a. Ensure the device is turned off and disconnect the power cord.
b. Lift the device off Tray 2.
c. Remove the jammed media from the bottom of the device or from Tray 2.
d. Reposition the device on top of Tray 2.
5. Open the print carriage access door. If there is paper remaining inside the device, ensure the carriage has moved to the right of the device, free any paper scraps or wrinkled media, and pull the media towards you through the top of the device.
6. After clearing the jam, close all covers, turn on the device (if you turned it off) and resend the print job.
Aug 23, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My hp 8500 is saying paper jam but there never was one
This is based on the HP 8500 manual. I hope this helps.
Aug 22, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Jam is in the back door area..paper tore off inside...is there anyway to take out top section inside the back door to clear?
There is, but best done in a shop. You remove the back cover, 4 screws, and the fuser is held in by another 4 screws. The fuser has to be aligned to gears on the right, and a spring loaded connector on the top left to be removed. You also have to remove the right cover and unplug the 2 cables to the fuser to get enough room to clear the jam.
Apr 20, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Paper jam on top cover but ther is no paper on top
check for stuck up key sensor, hook type that detect paper passing, some time that key dislocate.
Apr 15, 2010 | Office Equipment & Supplies
Top cover paper jam in laserjet 4345mfp
check the top cover, all the trays of the printer. sometimes there are small particles of paper that is put in the trays or inside the machine.
Feb 25, 2010 | HP LaserJet M4345 MultiFunction Printer
13,20.00 printer error
13.XX.YY JAM IN TRAY X 13.XX.YY JAM INSIDE DUPLEXER 13.XX.YY JAM INSIDE TOP COVER
Oct 01, 2009 | HP LaserJet P3005 Printer
Jun 23, 2009 | HP LaserJet 4200 Printer
Paper jammed problem 13.05.00 JAM INSIDE TOP COVER
Nov 19, 2007 | HP LaserJet 2420 Printer
2,654 people viewed this question
Seeker5211
Seeker5211
