Question about Olevia 227-S11 27 in. LCD TV
My power plug had electric shock while i was watch tv now my tv doest work
  • Olevia Master
  • 17,130 Answers
Possible that a power outage had damaged the power supply of the TV. so disconnecct the plug and remove the back panel. Now check on the power supply section- the SMPS unit.
check this link below for tips ;
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Posted on May 18, 2011
  • Olevia Master
  • 2,098 Answers
Your unit has fuse protection for AC supply malfunction like the short circuit. You must take it apart and check this fuse, for sure it is already blown. Pull-out it in the board and replaced it with same current (ampere) and voltage ratings.
Replace also your power cord to ensure that same cenario will not happen again.
Visit your local electronics supply for the replacement, this parts are widely available at the market.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Hello I have a 52 inch PANASONIC viera TV and whenever there is a power outage or I disconnect and I want to turn it back on, it won't turn on for a long time. What can I do about this?
www.electro-medical.blogspot.com
You have to check the power supply of the tv. Think the power supply has become faulty in the while power surge. To know and understand how to check the power supply watch the bellow added video. If you are doing it then take care power supply board there is a risk of electric shock.
Testing LCD TV Power Supply BoardsSTEP BY STEP
Nov 02, 2015 | Panasonic Televison & Video
Dead set no sound picture tube totally blackout. unit goes while watching tv program
If the unit has shut down during watching a program, there are mainly to reasons. The first one is its EHT section, and the second one is its main power regulator section circuits. Contact any service technician. Troubleshooting to this kind of fault is somewhat skilled one. If you wish to get some details, check the site linked here. Pull up older posts. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service center.
Dec 08, 2013 | Aiwa F2000 20" TV
Tv turns off itself
Check its horizontal output section circuit, and replace damaged component/s. Contact any service technician. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Jul 17, 2013 | Sanyo Televison & Video
No power to TV
Check and replace its main power regulator board inside. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electric shock. Instead, contact any experienced service technician, or the nearest service center.
Apr 30, 2013 | Hyundai Televison & Video
Phillips 50pfp55320 Flat screen tv will not turn on
The symptoms described suggest a power supply problem
Feb 22, 2013 | Televison & Video
Bush led24970dvdfhd no power no lights nothing
The main power supply regulator section circuit should be troubleshooted. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Watching the TV and heard a "pop", it went dead. Opened up the back and found a blown 4A 125V fuse. Replaced fuse and plugged in TV. Fuse blew instantly when I plugged in the TV. Sylvania...
The power suply unit may be dead......if the fuse blows instantly it means that the main input is short.
possible parts damaged :the diodes from the mains, the power tranzistor and the ic from the primary part and other components around them.
First unplug the tv, unload the mains capacitor (using a light bulb) check all the diodes from the rectifing bridge, check for any shortened semiconductors or blow resistors.
BE VERRY CAREFUL !!! THERE IS A RISK OF ELECTRIC SHOCK ,IF U DON"T KONW ANY ELECTRONICS TAKE IT TO A SPECIALIST
Feb 19, 2011 | Sylvania LC370SL8 37 in. LCD Television
My wii just turned off! I was watching a movie n my TV and everything just sut off my TV came back on but my Wii is still off!!
Was there some sort of power surge? A lot of the time when the power shuts off and back on -- there was a power problem. When the power comes back on, it can send a higher voltage which can break certain components. The Wii AC Adapter is made to absorb the shock rather than the Wii taking the shock. Try plugging it out and back in. If that does not work, you'll need a new AC Adapter. You can find one for around $19, free shipping, at the following page:
http://store.richspsxparts.com/ofniwiiacadr.html
Aug 12, 2010 | Nintendo Wii Console
TV WANT COME ON LIGHT JUST FLASHES.
you are definitely having the same problem I"m having with my samsung.. Cheap capacitors. You will need to replace your powerboard with something similar to this:
http://cgi.ebay.com/Magnavox-37MF231D%2F37-Power-Supply-REPAIR-SERVICE_W0QQitemZ350261990220QQcmdZViewItemQQimsxZ20091007?IMSfp=TL091007138002r8521
I recommend watching a video on how to take it apart and remember to be VERY CAREFUL there are high voltages stored in the capacitor banks even when it is not plugged in there is still risk of electrical shock.
Oct 29, 2009 | Philips 37MF231D 37 in. LCD Television
Electric plug for the dryer.
there is NO such adaptor.. you were given anelectric dryer, electric dryers require a 220v outlet, not an ormal 110v house outlet. you would need to call an electricin to run you a 220v line to use this dryer
Nov 25, 2008 | Kenmore 63942 Dryer
Olevia 227-S11 27 in. LCD TV Logo
100 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
