Question about LG ZW6500R Air Conditioner
My air conditioner stops cooling. Occasionally, it will just function on fan mode even though I confirm that it is on cool mode. Warm air comes out even on the absolute coldest setting. I have to turn it off and use the manual reset button on the plug to get it to work properly. The problem started after the unit iced up one night and it hasn't worked right since. Is there any way to fix this or am I gonna have to get a new AC?
  • LG Master
  • 17,130 Answers
If after reset the A/C cools then the fault seems related to the thermostat or the cut off pressure switch or load cut off.
However is there is no cooling at all the compressor and the gas pressure- check for leak if gas is absent.- must be checked .
If compressor is suspect you must check the estimate and decide whether it seems better to scrap and buy a new one.
Posted on May 18, 2011
My lg wall unit airconditioner is blowing air but not cold. this seems to have happened after at&t came to install new cable uverse in tv nnext to airconditioner.
Posted on May 21, 2011
LG air conditioner the fan comes on when in heat mode but when switched to cool the fan stops
They run on different speeds for heat and cool you either lost a speed for cool or the relay for the cool mode is not closing, Does the compressor come on in cool mode?
Sep 05, 2014 | LG Heating & Cooling
AIR BLOWING LIKE IT'S ON FAN EVEN THOUGH IT IS ON COOL
close vent for outside air.....if not then probably lost its chaerge.
Oct 11, 2017 | Heating & Cooling
I have an air conditioner Mitsubishi MSZ-A26YV, it has stopped heating, even if it's on the heat setting [sun emblem] and is set to highest temp, only cold air comes out, otherwise it does all other...
It's not indicated to turn directly from cooling mode to heating mode. You must wait about two or three minutes before the change. After the spliter start, you must wait few minutes to get hot air.
Mar 30, 2011 | Mitsubishi MSZ-A24NA Split System Air...
Intertherm heatpump outside fan will not come on, replace fan motor and capacitor, fan will not come on what could it be
some times heat pumps have a fan cycling switch to keep the head pressure normal in cool weather or check the defrost relay for the fan when a heat pump condenser gets frosted it will stop the fan and reverse into cooling mode for a few min. to melt the ice and this function is done by a relay or a printed circuit board if it goes bad you wont have voltage to the fan
Sep 30, 2010 | Intertherm P3RA-060K Air Conditioner
Compressor wont start..blows hot air
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 27, 2010 | LG LP1200DXR Portable Air Conditioner
I programmed my AC at 79ºF, when i got home last Saturday the temp inside the house was 86ºF! my daughter and i tried to troubleshoot using the Honeywell pamphlet but we're getting fan not cool...
heatman101
Sep 27, 2010 | Honeywell Heating & Cooling
Heater smell when AC comes on...
The fan that blows the air blows through the heater coils before it blows through the A/C.As long as the heater doesn't come on, there is not much that can be done. ZCooking the attic room will be a problem because it is the heat rises thing, and on top(literally) of it all, the roof is radiating heat.
Sep 21, 2009 | LG Heat cool Window Air Conditioner
Could you please explain the ''dry'' setting on the mode
The 'dry' setting is a feature which allows you to use the air conditioner as a dehumidifier. It works by cooling the radiator enough for it to attract condensation (mosture from the rooms air) which then drains into a tank or an external hose which dries the room. Even when used in cooling mode the unit will dehumidfy too, but because the fan is on it will be less effective. Also when the unit is in cooling mode it stops the compressor (cooling motor) when it reaches the selected rom temperature, however the dry function overides this and is a more effective dehumidifier as it will work in small spaces too. Hope this helps.
Aug 26, 2009 | Comfort-Aire CS-101A Air Conditioner
LG ZW6500R Air Conditioner Logo
260 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
