Question about Ahead Software Nero Express 6.0 (NERO6OEM) for PC
Nero express will not load on windows 7 T4300 Packard Bel on trying to install . The computer will not read the properties to open the disc to get the .exe file So I cannot list the file to install via the control panel
  • 48 Answers
The Disc must be full of scratches so there must be Problem reading CD. Borrow Nero 6 CD from your friend and then install. Nero 6 sometimes also comes in Motherboard Drivers CD, try to find it.
Posted on May 18, 2011
Describe your Hewlett Packard HP G60-635DX Pentium Dual-Core T4300 2.1GHz 3GB 320GB DVDRW DL 15.6" Windows 7 Home Premium w/Webcam... (WA574UAR) PC Notebook Problem
Hello Sir/Madam,
If you can properly state the problem with your system then a solution will be provided for you, thats the reason why this website exist.
Thankyou.
Aug 25, 2011 | HEWLETT-PACKARD HP G60-635DX T4300...
Where can I find a windows 7 recovery disk for HP h60 635dx? HP does not have them on the site
Thankfully any Windows recovery disk will work, you just need to determine if your operating system is 32 or 64bit
  • click on the Start menu, then right Click on "computer" in the right hand column and choose "Properties
  • Under the "System" section it should say "System type:" followed by a 32 or a 64
then you need to get a hold of a windows recovery cd: Best of Luck
--Nat
Aug 16, 2011 | HEWLETT-PACKARD HP G60-635DX T4300...
I install windows 7 now my nero doesn't run
The following Nero products are compatible with Windows 7:
Nero Multimedia Suite 10 Platinum HD
Nero Kwik Media
Nero Video Premium HD
Nero Vision Xtra
Nero BurningROM
Nero BackItUp & Burn (as of version 1.2.17)
Nero MediaHome 4
Nero BurnExpress
Nero 9 (as of version 9.4.26.0)
Sadly we have to inform you that any Version of Nero prior to Nero 9 will not officially be supported with Windows® 7.
You could try to change the way Nero is launched, but it may not work.
May 24, 2011 | Ahead Software Nero Express 6.0 (NERO6OEM)...
I have Nero-burning rom and have been using it successfully with Windows XP for the past two and a half years. The disc will not load in my NEW computer using Windows 7. Please help. Regards, Hamilton
first u must check if the disc still in good condition (sometimes the problem is the disc is already damaged)..
if the disc not broken try to explore it and find the setup application then run it. if its doesn't work maybe your windows 7 is installed with 64bit system and i think nero 5.5 is not compatible with 64bit system.
maybe u need up to date software ( nero 7 above)..
hope this useful.
Feb 15, 2011 | Ahead Software Nero Burning ROM 5.5 Full...
Hi!! I have a Dell Vostro 1310 with Windows 7 Ultimate installed and I was burning a DVD with Nero Express when it suddenly froze. I restarted the computer and when I put a DVD back into it, it doesn't...
It is probably a nero quirk. You will not be able to read the disk you were writing as there will be no table of contents written to it which is [ossibly why it failed.
Re install Nero or load the latest updates before trying again.
Dec 23, 2010 | Dell Vostro 1310 Laptop Computer PC...
Computer locks up when I install NERO 7 essentials. I had a 1 yr. old version when I built the computer and it worked great. I bought a new lite-on burner and received this new software. Installed it...
well ok the reason it locks up is this see you hade nero on you computer once before although you removed it from add remove programs you still dint remome all of it see heres what to do dont install nero 7 yet go to c drive and look for the comon folder open it and you see everything that you removed you can clear this folder it want hurt the pc and if windows want remove some files in it well there is a wat tiy do that you have to go past windows if you can remove it fine if you cant download revo uninstaller aand ues the auto run part you see all the programs the auto run in it get rid of the old nero in it and as mug of the programd that you are not using any more then resart you computer check how much hard drive free space tioy have if the drive is full it will lock up to so after you restart you have to use a registry cleaner for the things you removed use comodo registry clearner you have to down load it from the comodo site no after you done all this and removed all the orphened files restart you computer it will say finalize click yes and windows will continue loading and thin try to load nero 7 again it shoul load and the computer shouyld not lock up
May 04, 2009 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Uninstalled nero 7 to put nero 6 back on but it's not working!!
Did U Checked ur Windows - Is it Vista - ?
If not Something got wrong n Now u have to delete the folder of Ahead From C:
Now Reinstall Applpication u might find the reason and the Thing -
Jan 15, 2009 | Ahead Software Nero 6.0 (60045) for PC
Nero 7 essentials disc but when i try to install it it comes up with message this version dose not support vista
Windows Vista is supported by Nero 7 since the version Nero 7.5.7.0.. Older versions of Nero 7 do not support Windows Vista. If you are trying to install Nero 7 from your original disc it is likely that there is an older version included on this disc. If you want to install Nero 7 on Windows Vista please be sure that you will only use latest Nero 7 version, you can download from the below website. Also please be sure that there won't be any rests of old Nero 7 versions on your system by performing the following steps:
1.
Start uninstalling all old Nero 7 applications and files from your computer using the Nero 7 CleanTool
Download the Nero 7 CleanTool using the following link:
Click here.
Save this file to your desktop.
Unzip the ZIP-file with WinZip or WinRAR and save the content to your hard drive.
Double-click on the unzipped EXE-file to start the CleanTool.
The window “Nero General Clean Tool” will open. The installed Nero version will be displayed.
Activate the checkboxes in the displayed Nero version.
Then click the “Clean” button.
A status window will open.
The execution of the tool may take several minutes.
Please wait until the progress bar has moved completely to the right.
In the window “Nero General Clean Tool” click the “Exit” button as soon as the erasing procedure is completed.
Reboot your computer.
The Nero 7 CleanTool has removed all Nero entries from your computer.
2.
To install the latest Nero 7 version, please proceed as follows:
(Note: do not install a previous Nero 7 version from an installation CD now, but download and install the latest version of Nero 7 from our website. All Nero 7 download versions have the full range of functions as an original Nero 7 installation CD. There is no need to install a previous version of Nero first.)
Download and install the latest Nero 7 version from website using the following link:
Click here.
Double-click the downloaded Nero 7 installation file to start the installation.
Enter your Nero 7 serial number during the installation to make your Nero into a permanent version. (The download without a serial number is a trial version only).
You now have a newly installed version of Nero 7 on your computer.
Jul 17, 2008 | Computers & Internet
Nero express updates
here are updates for nero 6.
http://www.nero.com/ena/downloads-nero6-update.php
unfortunately, you cant cant use nero 6 on vista. you need to upgrade... nero 7 or nero 8.
http://cquirke.spaces.live.com/blog/cns!C7DAB1E724AB8C23!167.entry
hope this helps
Jan 24, 2008 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Nero INCD
check the properties of the cd/rw device. did the tech replace the device?
Dec 01, 2007 | Computers & Internet
Ahead Software Nero Express 6.0 (NERO6OEM) for PC Logo
Top Ahead Software Computers & Internet Experts
celos
lemesee
Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
