Question about Pioneer Televison & Video
Insert dvd but comes back saying no disc inserted
    Top Expert:
  • Pioneer Master
  • 74,496 Answers
Hello
Your DVD players loading mechanism has some fault with it. It does not load the disc properly in, Check the loading belat first, and the loading motor for low pulling power. Check whether there is any fault loading gear wheels. The fault is clearly of the loading mechanism itself. OK.
Posted on May 18, 2011
VOTIT
  • 2071 Answers
SOURCE: APEX AD-1115 DVD PLAYER
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Aug 25, 2008
aceltix
  • 119 Answers
SOURCE: cannot play dvd
hy
try to clean the reading lense with a special brush cleaning cd.
youll find it computer stores.
most of the cases it works
bye
Posted on Feb 03, 2008
SOURCE: Recordable DVD
can only record 2x,4x, and 8x..........not anything beyond 8x it seems....so 1x-16x will not work. Now if I could just get the loading messageto stop on mine.
Posted on Mar 11, 2008
  • 98 Answers
SOURCE: player won't read a DVD
Sounds like a bad pick up assy (Laser)
Posted on Nov 25, 2008
  • 4090 Answers
SOURCE: I have a Samsung DVD-R155. When I insert a DVD,
Try using a DVD scanner eye cleaner. It is aDVD with a brush grafted to it. I suspect the scanner eye is dirty so it cannot read the boot starp properly and so ejects
Posted on Aug 15, 2009
After inserting a DVD to play a bought film or recorded disc a message comes up in the display saying No Disc
It may be dust built up and you have to get a DVD insert that's made especially for cleaning the inside of the player
Feb 09, 2012 | Sony Televison & Video
My 2 1/2 year old LG dvd/vcr recorder will play some dvds but will not play others. It says unknown disc. I was told to try a lens cleaner; I bought one and the lens cleaner says unknown disc as well. ...
Your DVD /VCR says unknown disc because the
dvd which you have inserted is not of the supported format by player.
If you insert unsupported formats only it will say as unknown disc.This is not related with disc cleaners.
Please insert the supported formats and it will play the disc.
Thanx
Jul 31, 2010 | LG Televison & Video
When it comes time for me to copy my dvd...it prompts me to insert a blank dvd-r...i insert a blank dvd-r and it kicks the disc back out telling me to insert a blank dvd-r. Do i have to do something...
This is a common problem. RW DVD are different types. You need to read what type of RW DVD you need there will be either a nimber, leter or symbol at the end of where it says RW DVD or DVD RW and you CANNOT use just any disc.
Mar 16, 2010 | Roxio Easy CD & DVD Burning
When inserting a dvd in to my in car dvd player it
You have to clean the lens of the DVD player.
Oct 18, 2009 | 2006 Toyota Corolla
Dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would...
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
Oct 12, 2009 | Cyberhome CH-DVD 300 DVD Player
I have a Samsung DVD-R155. When I insert a DVD, the screen reads "load", but eventually it screen will say it can't read the DVD, and then ejects the DVD. It doesn' t matter if it is a new or used DVD. I...
Aug 15, 2009 | Samsung DVD-R155
When I insert a dvd it says no disc
DVD need replesment of optical lens,then its ok
Jul 09, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Player won't read a DVD
Nov 24, 2008 | Samsung DVD-R155
Televison & Video Logo
382 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
