Question about Behringer Eurolive B415dsp 600w 15" PA Loudspeaker
I have two Behringer Eurolive B415DSP speaker, one of them stopped working out of no where. To my best knowledge, the problem is that it doesn't turn on. I had the Fuse check already and thats not the problem. The front LED doesn't turn on to indicate that there's power going thru. I try using other power cables and other outlets, but that doesn't seem to be the problem. The on/off button works like new too. I think there is a problem with the amp, what do you think? And/or what can I do?
    Sergeant:
  • 158 Answers
This is alimentation fault of the amplifier inside the box. Dismount the amplifier block and take a look first if there are some burned pieces. If it seems all ok, better bring it to a electronics/ tv service center.
Posted on May 18, 2011
Behringer B112D wont power up until 10 minutes after switching on
This will be a power supply problem. Take it in to your repair shop for service.
May 07, 2016 | Behringer Eurolive B112D Powered PA...
How do i change the woofer in the eurolive B215d..does the front screen pop out
Yes, the front screen should just be a compression fit. Something a bit stronger than a paperclip should work fine to pull it out. Work around the edges.
Jan 18, 2015 | Behringer Eurolive B215DWH 550W 2Way PA...
Th lights on rare of the speaker are blinking no sound
I had two of these units fail exactly the same way. The amplifier assembly is the failing part.
If it's out of warranty, then you will need to order a replacement. Don't bother with Behringer support, they aren't helpful. I recommend a place called The Tone Garage. They have said they can order replacement amplifier assemblies in about 4 weeks.
Here is the link:
Eurolive B115D Powered PA Speaker
Apr 23, 2014 | Behringer Eurolive B115D Powered PA...
I want to order a new volume pot for my Eurolive B215A powered speaker directly from Behringer, then fit it myself. Who do I contact to order the part?
Lots of luck. Behringer no longer sells direct. Fullcompass.com is their parts distributor. If they don't have it in stock, it takes months... I have had an order in for 6 months now. The procedure is you call Behringer at 1-425-672-0816 to get a part number and an incident type number. Then call Fullcompass and order the part at 1-800-356-5844 and tell them you need Behringer part. IF they have it in stock, then you are lucky.
May 18, 2011 | Behringer PA speaker Eurolive B212A
Behringer b415 horn stop working how and where i get replacement
First thing is to test the horn as the crossover circuit may be the problem. If you need the part(s) for the crossover you can get them via DIgiKey.com, however repalcing the horn driver you may have to go through FullCompass.com and if the part has to come from Behringer it takes months.
Mar 16, 2011 | Behringer B415dsp Eurolive 600watt 15 PA...
I have a b415 dsp speaker that I pulled apart due to a rattle in the driver. I need to confirm the correct wire color to the speakers. I believe the red and black went to the driver and the blue and yellow...
Way to find out: The minus speaker leads go to ground at the amp and therefore are electricaally connected together... just use an ohmmeter to find which two wires are tied together and connect those to the minus leads of the speakers.
Jan 12, 2011 | Behringer B415dsp Eurolive 600watt 15 PA...
Behringer Eurolive B415dsp 600w 15" PA Loudspeaker Logo
235 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
