Question about LG Kitchen Ranges
Aircon not cooling - LG Kitchen Ranges
  • LG Master
  • 17,130 Answers
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the A/C and check the compressor.Make sure that the thermostat was set to normal mode. If there is no cooling then we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
So try this test from the outside and make your observations so that we come to the solution.
Posted on May 18, 2011
Aircon not cooling, aux fan not turning, fuses OK heating Ok ,system has been regased
If the fan that cools the condensor is not working then the aircon will not work .
Dec 02, 2012 | 1995 Mercedes-Benz E-Class
I had the aircon thermostat on cold then my friend just transfered it to warm without turning the aircon off because it was too cold. in the afternoon when i tried to use the aircon theremostat to...
Problem is the thermostat.The heat/cool selector switch might not be making try back and fourth from heat/cool to make a good contact.In heat mode make sure the temp is set LOWER than your cooling temp.If it is too cold in the future just RAISE the cooling temp up and not the heat/cool switch.
Jun 04, 2011 | Heating & Cooling
My car overheat when im using the car aircon,it doest overheat when im not using the aircon,so how can i use the aircon with out overheating my engine,i already clean the radiator,condenser,check the...
The cooling fan should run continuously when the A/C is on. If it does then I suggest you drain and flush the cooling system, and replace the thermostat. Fill it with a fresh supply of a 50/50 mix of antifreeze and distilled water.
May 16, 2010 | 1999 Suzuki Vitara
My LS-H186 VML 1Metal Art Cool 12000 BTU Air Con does not heat up
You should also check the outside unit to make sure the coil is not clogged with dirt or grass clippings and the fan is working. The reversing valve that switches it from cool to heat could also be a problem. If it isn't shifting it will not switch between heat and cool.
Apr 29, 2010 | LG Art Cool LA181CNW Split System Air...
1996 audi a4 aircon problem
You have a leak most likely, and these are typically hard to spot without test equipment. Take it back to your technician and ask him to recharge the system and perform a dye test to locate the leak. Could be as simple as a bad o-ring in a fitting, or as complicated as a seal in the compressor.
Jan 05, 2010 | 1996 Audi A4
MY AIRCON IS BUILDING UP SOME ICE
Sounds like it's low on charge, dirty coil. Is this a ductless unit or window?
Jul 26, 2009 | LG Heating & Cooling
My KOLIN window type remote control AIRCON is building up ICE
If you already had the coils and filter cleaned and the blower is OK, that only leaves the refrigerant charge.
You are probably low on refrigerant.
Jul 26, 2009 | Heating & Cooling
Aircon not working
The F8 Fault means that the Temp sensor in the indoor unit that goes into the cooling coil is faulty.
Nov 17, 2008 | LG Art Cool LA1000PR Air Conditioner
Aircon does not cool
have you had it regased yet ?
Oct 20, 2008 | 1999 Audi A4
Sudden brownout
hi,
it has a small microcomputer which will shut off if /or error if the voltage parameters are too far out(brownout,surge) carriers are a higher end machine, better parts, should be fine..
jm
Jul 27, 2017 | Carrier Heating & Cooling
Kitchen Ranges Logo
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Mike Carew
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
