Question about Symbol LS 4000i Handheld
How can I set up the ls4000-i000 to read code 128 in any length? on the manual it says the default is in any length but it can only read up to 20 characters.
4 Suggested Answers
SOURCE: ean 13 problem
dear bluegreenash, the EAN 13 has 12 real characters..the first one(13 character) shows the country code and it's called "check digit".The default settings in the bar code scanner do not show the 13 character if the value is zero!!(zero is the code for US and Canada).So,by going to the configuration manual I scanned the setting that enables and shows the check digit character and the problem solved!!thanks for the help!!
Posted on Sep 30, 2008
  • 38 Answers
SOURCE: Code 128 Barcode Problem
Hello paul blando. I think I can help you here. First, are you sure your barcodes with asterisks are Code128 like the others? Generally a Code128 barcode will look like: "(1234) 567890 (01) 123456" and wouldn't really use asterisks at all. However, I know that it is standard practice for people who make their own Code39 barcodes to start and end the code with an asterisk to denote a start/stop action. Could they be Code39? They would look like: "*123456789*". If this is the case, then I have the manual for the P370/P470 on my company's site here. Take a look at the Code39 Chapter and make sure to print and scan the pages to disable the check-digit transmittal. If that doesn't do the trick, then try the "recall defaults" or "reset to defaults" barcode to reset the scanner to it's initial defaults. That should put it on track. If you still have trouble, please feel free to send me a message or email me. I hope this helps. Good luck!
Posted on Jan 06, 2010
If the leading digit that is being missed is a zero then the likelyhood is that the barcode is a UPC-A barcode (12 digit) but displayed as 13 by using a leading 0. You can convert the UPC-A barcode to a EAN13 on the MS9520 by using the setting that comes either in the 9520 manual or the start-up guide provided in the box. See Conversion of UPC-A to EAN13
Posted on Feb 15, 2013
My ds9208 does not read some code128 barcodes. It is currently set at default. Any settings that could help this? I've tried setting lengths but no success.
hi,It could be that the Barcode is some odd variation of 128, or badly printed. It does not take much to mess up the Quality of the Label.
Can you send me one, as a PDF, i can read it with one of my testers and make sure it is correctly formatted.
dave.germain<@>penmobile<dot>co<dot>uk
Mar 12, 2013 | Symbol Motorola DS9208 - Barcode scanner -...
Tip
How to setup WEP on an SMCD3GN Wireless Cable Modem Gateway 1. Log into the...
1. Log into the router. To do this you will need to open your web browser and enter http://192.168.0.1
2. You will need to log in to the router. The Default Username and Password:
User Login
Username: cusadmin.
Password: password
3. Next click on [WIRELESS] link on the Side Navigation bar.
4. Select [WEP] from the [SecurityMode] drop-down menu.
You can choose between standard 64-bit or 12b-bit encryption keys. Below are the configuration options for 64-bit WEP. A passphrase or a manual key can be used
NOTE: To enter a manual WEP key you will need to enter hexadecimal values (A-F and 0-9). Example: 64-bit hexadecimal keys are exactly 10 characters in length. (123654ACDE is a valid strong of 10 characters for 64-bit encryption).
To automatically generate a 64-bit WEP key, enter in a Passphrase (keyword- ex. homegateway). And click the [Generate Keys] option. Once you do this, the Gateway will dynamically generate 4 keys. Simply configure the Default Key to the one key that you will be using across your network.
5. Select the Open System, Shared Key or Automatic from the [Authentication] drop-down menu. Note in most cases you want it set to Automatic.
For more security, you can use 128-bit WEP encryption. To use this mode, select the [128 bit (26 hex digits)] from theWEP Key Length drop-down menu option and the configuration section will be displayed. 128-bit encryption requires a longer key than 64-bit encryption. Keys are defined by entering in a strong in HEX (hexadecimal- using characters 0-9, A-F) or ASCII (American Standard Code for Information Interchange – alphanumeric characters) format. ASCII format is provided so you can enter a string that is easier to remember. The ASCII string is converted to HEX for use over the network. You can manually enter in the 26-digit hexadecimal key.
Example: 128-bit hexadecimal keys are exactly 26 characters in length. ( 234FEDCBA12340013333389319 is a valid string of 26 characters for 128-bit encryption).
NOTE: If you are having a difficult time getting the wireless connection up after enabling WEP- Please confirm that you have configured the SAME WEP key on both the Gateway and Client card.
6. Click the [Apply] button to save your settings
on Feb 26, 2010 | Computers & Internet
I DO NOT KNOW MY SECURITY PASSPHRASE
n most cases the default wireless settings are sufficient for normal home use.
Locating the WEP or Network key:
To change your Residential Gateway wireless settings:
  1. Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
    If the Home page does not open, check to make sure that you have no software firewalls blocking network access.
  2. Click the Home Networking tab at the top of the 2Wire Home page.
  3. Click EDIT SETTINGS located on the right panel (Status at a Glance) under the Wireless Settings heading.
  4. Change your wireless settings and use the following information if you want to change to a custom WEP key.
    64-bit hexadecimal keys are exactly 10 characters in length. (For example, 123456789A is a valid string of 10 characters for 64-bit encryption.)
    128-bit hexadecimal keys are exactly 26 characters in length. (For example, 456FBCDF123400144445271730 is a valid string of 26 characters for 128-bit encryption.)
    64-bit ASCII keys are exactly 5 characters in length. (For example, GMODE is a valid string of 5 characters for 64-bit encryption)
    128-bit ASCII keys are exactly 13 characters in length (For example, 2008SUNSSWIN1 is a valid string of 13 characters for 128-bit encryption.)
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 15, 2010 | 2wire 2700HG-B Router (2700HGB)
&#305; have mc 7090 using windows mobile 6.1 &#305; use datawedge 3.2.4 &#305; want o scan code 128 type barcodes but its not reading. I was using earlier 2.0.2 version and checked symbologies...
Hello Osman, in the default settings of datawedge is an issue with barcode length for code128. Please check it and setup the specific length, that you want to use.
Klick on the DataWedge icon, select Standard Configurations, go to Scanner, Decoders, Code128 and select the min and max value.
Oct 29, 2010 | Symbol MC70 Barcode Scanner
Symbol 4000i scanner will not scan barcodes that are single digit
Hello Jane Diaz,
the scanner has several barcode types enabled by default. Other type or lengths must be activated with an programming barcode from the Programm Reference Guide for LS4000.
Please check which kind of barcode are you using. Download the Program Reference Guide from support.symbol.com Scan the barcodes from the chapter Symbologies
Oct 13, 2010 | Symbol LS 4000i Handheld
I downloaded Windows 7 and my wireless laptop won't connect to my 2wire. Where can I get new security key code or info get my laptop to work?
Hey pkkern,
Your default 10 digit security is located on the bottom of your router.
If you want to change it or for some reason your default key is no longer working we will have to get into the routers configuration homepage.
To access this open up your Internet browser and write in this address, (which is your routers address) 192.168.1.254.
If your routers homepage does NOT open up check to make sure you have no software firewalls
You will see a wireless network security section, use the following information to select a custom wep-key.
Change your wireless settings and use the following information if you want to change to a custom WEP key. 64-bit hexadecimal keys are exactly 10 characters in length. (For example, 123456789A is a valid string of 10 characters for 64-bit encryption.)
Thanks for using fixya!
If you need information just comment in this thread and I will get back to you, don't forget to leave feedback!
Cheers,
Jul 24, 2010 | 2wire (1000-400108-001) Router
I do not know how to set a symbol ls4000i scanner to read 39 or 128 barcodes
Please check the Symbologies chapter in the LS4000 Guide, you would need to enable the correct length.
The Guide is avalaible here http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=3789802apdf&sliceId=&dialogID=189660227&stateId=1%200%20189654325
Feb 17, 2010 | Symbol LS 4000i Handheld
I need a default barcode to reset my scanner to accept barcodes automatically with my LS 4000I-I000 scanner
There is no such bar code. barcode scanner scans any barcode and give the result.
scanner can scan in any software. eg. excel,word. dos etc.
Aug 08, 2009 | Symbol LS 4000i Handheld
Problems with very small Barcodes
Default settings set a global limit of 4.
You can set the global minimum code length by following the instructions in the user manual on page 24:
1) Start
2) Set Global Min Length
3) Scan the number on page 303: I.e. '0' followed by '3' to set length to 3
4) Set
5) End
Jan 09, 2009 | Datalogic PSC QuickScan QS6500 Handheld...
Handheld Symbol LS4000-I100 barcode reader
you need to use the code book (the programmers book) to configure the reader, you need to tell it how to communicate with the PC (bit rate, stop bits etc....)
this code book should have come with the reader...
this book has barcodes on many pages and also configures the types of barcodes that the scanner can read....
if you do not have the code book you can download it from the maufacturers website
Jul 08, 2008 | Symbol PN: LS4000-I100 Laser Scanner...
Symbol LS 4000i Handheld Logo
183 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
