Question about Corel Draw 9 (90ENG0) for PC
I'm running Corel Draw 9 on Windows 7 32-bit. I keep getting "unexpected error" and being bombed out. Mostly I can go a back a few versions of drawing and proceed, but sometimes even versions which were OK during use and saved normally give the error message when attempting to open them at a later stage
  • 48 Answers
You can try creating a new workspace from whatever you get into after all the error messages on startup and use that as your default workspace.
Tools -> Options -> Workspace -> New ... name it -> Set as current
OR
There may be something else if you're using XP and NOT an administrator account. Your settings then should be transferred from the administrator's settings folder to yours with the same names and everything (something in Document and Settings folder under whatever name you chose during WinXP installation).
Posted on May 18, 2011
Corel DRAW X6 problems
I presume you mean CorelDRAW Graphics Suite X6 and NOT technical Suite?
If nothing seems to work I would then do as follows.
1.Uninstall CorelDRAW X6 via Control Panel
2.After uninstalling X6 in the Control Panel - Go BACK to the Control Panel and uninstall "Corel Graphics - Windows Shell Extension".
3.Then go to Documents > Corel folder > Uninstall/Delete anything that says CorelDRAW X6
4.You can also go to C: > Program > Corel and delete anythign that says CorelDRAW X6
5.Repeat step 4, but choose folder called Programx86, and delete anything that says CorelDRAW X6
6.You should now have uninstalled everything that useally could disturb when you re-install from scratch.
7.NOW put in your DVD again with CorelDRAW Graphics Suite X6 - and INSTALL from Scratch.
8.You SHOULD now be able to run your CorelDRAW X6.
9.And NOW you should go online to www.corel.com and download and install Update/service pack and Hotfix for CorelADRAW Graphics Suite X6
10.It should in all normal situations work just fine on your PC with any Windows 7 version as well as any Windows 8 and 8.1 version.
11.Try to use a program to recover and view CDR files. For example, you can try this CDR Open File Tool http://www.cdr.openfiletool.com/
12.Also recommend to come to this forum. Many have useful information on the topic. http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/coreldraw/479-problems-with-cdr-files
Good luck and hope this helps!
Nov 12, 2014 | Corel DRAW Graphics Suite X5
Tip
Windows 7 Updates Running TOO SLOW, or just plain "hanging up / freezing"??
Anyone out there in "Windows7ville" experiencing those DREADED slooooowww updates, or is it seeming to hang / freeze without actually downloading and installing your security updates??
I struggled with this exact same issue regarding Windows 7 Updates.. (SLOOOW download times, Win7 Update basically "hanging" at the "searching for updates" portion of the install procedure), you name it! Fortunately, I got fed-UP with these problems and "dug down deep" in researching for a "fool-proof" solution!
This issue apparently stems from the fact that Microsoft in all their "wisdom" decided to change how their update servers "hand out" their updates to computers requesting Windows 7-related updates, after Windows 8/8.1 was released.
Here's the fix(es) which worked for me:
First, we need to find out what version of Windows 7 (32 or 64 bit) we have:
Click the Start button. Right-click "Computer", and then left-click "Properties" from the resulting pop-up menu. This will bring up a new window showing what version of Windows 7 you have, what type of CPU, how much system RAM, and most importantly if it is 32 or 64-bit.
(For this solution, I'm assuming that one has the 64 bit version of Windows 7. If you have 32 bit, then at any time during this process you see a different choice to download the 32 bit version of an update, please do so. Also, you MUST have Service Pack 1 installed on Windows 7 for this guide to be successful. If you don't have it installed yet, please download the full installer and run it before continuing: https://www.microsoft.com/en-us/download/details.aspx?id=5842
Make SURE you restart once SP1 has finished installing!)
First, click the "start button" (Lower-left corner of your screen.. looks like the windows logo in a "bubble"). In the search blank at the bottom of the "start menu", type in "cmd". When it shows the result, right-click it, and then left-click "Run as Administrator". Keep this window open, but shrunk-down and off to the side a bit, as you'll need to run a command a couple times during this process.
1.) Type in (or copy and paste this) into the command prompt:
net stop wuauserv
Press "enter" / "return". This will completely stop the background Windows Update service, preventing it from interrupting our repairs / updates to Windows Update.
2.) Download and run (I recommend Google Chrome or FireFox browser -- steer clear of using Internet Explorer, as it's FULL of non-fixable security flaws!!):
https://support.microsoft.com/kb/3138612
This will ask you if you're sure you'd like to run this. Just keep saying "yes" or "ok".. (basically give it a positive response until it finishes). When it's done, restart your PC.
3.) Once your PC has fully restarted and you're back at your desktop screen, (you can see your wallpaper and all your "usual" desktop icons), REPEAT STEP 1... Then go back onto the web. Download and run:
https://support.microsoft.com/en-us/kb/3102810
Once again, give it "positive responses" if it asks if you're sure you want to install this update package... Restart your PC once more after it's done.
Now, If you'd like to get all the most needed and necessary security updates done and over-with in "one fell swoop", then download and install the "Windows 7 Convenience Update", which will get your PC up-to-speed and up-to-date with security fixes MUCH more quickly!!
(Again, please repeat Step 1 before continuing!)
First, we'll need to run a quick "service stack update" on the updater service. Download and Run:
https://support.microsoft.com/en-us/kb/3020369
On the service stack update page, remember to pick from the first two choices, based on if you have 64 bit or 32 bit.
Restart your PC once it's finished!
Repeat Step 1.
Now, onto the "Convenience Update"
Download and Run:
For 64 Bit:
http://download.windowsupdate.com/d/msdownload/update/software/updt/2016/05/windows6.1-kb3125574-v4-x64_2dafb1d203c8964239af3048b5dd4b1264cd93b9.msu
For 32 Bit:
http://download.windowsupdate.com/d/msdownload/update/software/updt/2016/05/windows6.1-kb3125574-v4-x86_ba1ff5537312561795cc04db0b02fbb0a74b2cbd.msu
As "always", restart your PC once the update finishes!
I hope this helped someone! Please let me know if it did, and have a truly excellent day!
on Apr 21, 2017 | Microsoft Windows 7 Professional 64 Bit 3...
Been a Corel user for years,the last couple of times I try to open CorelDRAW Graphics Suite X5, a notice appears "check online for a solution and close the program. my reg #...
Hi jlawilke
Delete and reinstall your program . If problem persists , try a recovery system to set your pc back to a date whem the program was running smoothly . If still no solution , go on line at Corel's support .
Best regards ,
fanaudi .
Aug 29, 2011 | Corel DRAW Graphics Suite X5
I try to reinstal corel draw graphic 11 but it's always fail.. please guide me. i use windows 7
-Try to remove your older corel draw in control panel
-Delete folder corel draw in program files
-Restart computer
-Try to install corel draw again, Thx
May 31, 2011 | CorelDraw Graphics Suite 11 for Mac, PC
Corel draw x4 activation key
if you wanted a corel x4 activation key do the following steps
1.open corel draw
2.select phone corel
3.go to ********* and download the corel draw x4 keygen
4.open the keygen and copy the serial no.
5.go to corel draw and paste the code then copy the initializing code from corel
6. paste the code in keygen and click genrate button
7. you found a activation code copy the code
8.paste the code into corel draw
9.select the finish button
Oct 26, 2010 | CorelDRAW Graphics Suite X4 for PC...
Activation code for this key "DR14T22-FKTH7SJ-KN3CTHP-5BED2VW"
first change you computer date 2009
1.open corel draw
3.go to ******** and download the corel draw x4 keygen
Jul 19, 2010 | CorelDRAW Graphics Suite X4 for PC...
Corel Draw 9 (90ENG0) for PC Logo
299 people viewed this question
Top Corel Computers & Internet Experts
photoshop serial
Dan Shibata
Dan Shibata
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
