Why does my laptop only work when my charger is plugged in.
  • 32,281 Answers
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Posted on May 18, 2011
My dell laptop isn't charging when plugged in. What should i do?
Dell chargers have a centre pin to allow the laptop to sense that the charger is a genuine Dell one. If the battery is not charging then:
a) Battery is faulty (old and dead)
b) Pin missing on the charger, wire broken or not original Dell device
c) Charging port on the laptop has become loose.
Hope this helps.
Jul 02, 2016 | Dell Inspiron Computers & Internet
Cooling fan stopped working
any 18-20 volt laptop charger should work only need correct power plug and that can be easily changed if necessary with soldering iron and volt meter. using old charger plug as replacement. volt meter is used to check out correct polarity of plug before and after you re solder plug on.generally outside is -ve and center is +ve ,alternatively go to ebay or google and type in Sony Vaio PCG 7Q1M charger,or type in part number ,or try 18-20v laptop charger, that is what I do when I need a replacement charger,cost around $10 delivered usually.
Jan 04, 2014 | Sony Vaio PCG 7Q1M Laptop Universal AC...
When I connect charger with my laptop 30 sec show battery is charging after 30 sec one message show:- QuickSet The Ac power adapter type cannot be determined. your system will operate slower...
del recognition circuit may have failed in charger , or could be fine central pin on charger plug or laptop plug has broken connection,it is used to tell laptop that this is genuine dell charger.If you remove battery will laptop work off charger.if does then definitely one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed. If either of last 2 can repair but need to pull apart repair broken connection ,or open up laptop and check power connection and repair connection . If you remove battery will laptop work off charger.if does the definately one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed.
Oct 27, 2013 | Dell Inspiron 65W PA-12 1525 LAPTOP
My laptop is working only via battery
That means your Ac charger is bad so you have to look for another charger of thesame specification voltages and use
Jan 02, 2013 | Computers & Internet
SAMSUNG LAPTOP PLUGGED IN NOT CHARGING
try removing the battery and just use the mains power. If the laptop works you may need a new battery. If it doesn't your charger is faulty.
Nov 26, 2012 | Samsung R580 Notebook
When i plug the charger in the first time it is working but when the charger is unplug the laptop is not working.
Hi Tim, As per my understanding you are experiencing issues with the laptop not working without a charger being plugged in.In this regards what I would suggest you do is see if the battery charges with the charger plugged in and in case the battery does get charged see if you are able to power on the laptop with just the battery connected and no charger plugged in.If you are able to get the laptop to turn on only with the charger connected and unable to power on with just the battery then it would be an issue with the battery not getting charge.So before you replace the battery please unplug all external devices from the laptop including the charger and the battery and without the charger or battery connected to the laptop please press and hold down the power button for 30 seconds after which please insert the battery into the laptop and see if you are able to turn on the laptop.This step is performed so that we could drain out unwanted static electric charges from the laptop.In case this step does not work please do consider replacing the battery since it would be an issue with the battery not getting charged. Best wishes for your effort.
Nov 12, 2010 | ASUS A9RP Notebook
Hi i have some problem to my laptop battery it wont charging, but laptop charger is working fine, my laptop brand is compaq presario C700. i tried to charge my laptop in 2 hours after that i tried to turn...
Did ur laptop works or turn on when u plug the adaptor charger?
If ur laptop turns on when the charger is pluged in, u got problem with ur DYiNG BATTERY!
Better buy a brand new battery!
Nov 08, 2010 | Compaq Presario 700 470024-192 Notebook
Laptop stopped working and now not starting up. I think the battrey is dead and charger not working. it is HP laptop
If the charger has a light on it when it's plugged in and it's not on when you plug it in, then yes your charger is bad. if the light is green then you have issues with the laptop. If no light, check the voltage with a volt meter to see if the charger has power. good luck.
Sep 05, 2009 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
161 people viewed this question
David Payne
David Payne
