Question about Panasonic KX-FPG378 Fax
Replaced film, now unit says, check film cover open Have replaced film and closed cover several times. Still won't work.
  • 3 Answers
Call me at 7445084 or 09192467036 and i assist to your problem
Posted on Aug 16, 2008
Brothers Printer MFC 7420 Error Message "Back Door Open" I opened it and closed it several times still getting message. I unpluged it andtried again. Help
Hi. You have to follow these steps: Be very careful:
1. Open front cover, like in this image:
2. Pull out your printer's toner cartridge & drum unit:
3. Open back cover
4. Pull the tab which is in front of you in order to open the rear chute cover.
5. If there is any, pull the jammed paper out of the fuser.
6. Close back cover and put the cartridge toner & drum unit back where it belongs.
7. Close front cover too and see if it works! If your error will still appear, try powering your printer OFF & ON
I hope I helped you!
May 20, 2011 | Office Equipment & Supplies
Shutter button will not depress it says that the lens is either locked or not there
Today's digital cameras are smart. They won't operation if the lens cover is in place (or closed), nor if there is no memory card in place. So ...
  1. Check that the lens cover is "open" or removed. (Open and close several times to be sure it's not stuck or jammed.)
  2. Then check that you have a memory card inserted, AND that it is properly formated (that is, that it is prepared to record images; see your instruction manual for details.
I hope this helps.
Apr 05, 2011 | Cameras
Check Film and Cover Open: KX-FPC95
Check for slack in film between supply and take-up rollers. Manually advance take-up roller to remove slack before closing cover.
Dec 18, 2009 | Panasonic KX-FPC95 Plain Paper Thermal...
Blinking 0 on my minolta maxxum 5 after I loaded the film. I cant take any pics.
It did not load your film. open the back, be sure you have the film pulled across the opening to the far side of the take-up spool, and close the back again. It should make noise as it winds the film, then number 1 should appear in the top window. If it does not make noise and advance film, you likely need the film advance motor replaced. Every time you close the back, it will try to advance film.
The motor itself can die and those plastic gears can break teeth. If repositioning the film does not work, your maxxum needs a trip to the repair shop.
Dec 06, 2009 | Photography
Replaced the magenta cartrage. arror check Ink
The Error "Check INK U140"
Causes : Possible causes are as follows :
* The ink tank may not be installed properly (The lamp on the ink tank is off).
Install the appropriate ink tank.
* The ink tank not be compatible with this machine. (The lamp on the ink tank is off).
Install the appropriate Ink tank.
The machine will not print of the wrong type of ink tank is used or if it is installed incorrectly.
Be sure to install the ink tanks in the proper order. The proper arrangement from the left to right is Black - (CLI-8BK), Black -(PGI-5BK), Yellow - (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Replacing Tanks
1) Ensure that the machine is on.
2) Raise the Scanning Unit (Printer Cover) until it stops.
The Paper Output tray will open automatically and the Print Holder moves to the center.
Impoprtant : If the Scanning Unit (PRinter Cover) is left open for more than 10 minutes, The Print Head Holder moves to the right. Close and reopen the Scanning Unit(Printer Cover) to return the Print Head Holder to the center.
3) OPen the Inner Cover.
4) Press the Open button to open the Paper Output tray if it does not open automatically and remove the ink tank whoe lamp is flashing red fast. Do not touch the Print Head Lock Lvever. Remove only the ink tank.
Important : * Handle the ink tanks carefully to avoid staining clothing or the surrounding area.
* Discard empty ink tanks according to the locakl laws and regulations regarding disposal of consumables.
Note : Be sure to replace ink tanks one by one when replacing more than one ink tank.
5) Prepare a replacement tank.
a) Remove the new tank ink from its packaging, then pull the orange tape so that the protective film does not remain on air hole. Then remove the film.
b) Remove the orange protective cap from the bottom of the ink tank and discard it.
6) Install the ink .
a) Install the ink tank into the Print Head.
b) Press on the Push button on the ink tank until the ink tank snaps firmly into place.
c) Ensure that the ink tank clicks into place and then its lamp lights red.
Important : Make sure to install all the ink tanks to enable printing. The machine cannot be used unless all the ink tanks are installed.
7) Close the Inner Cover.
Note: Ensure that the Inner Cover is closed, Printing will not occur if the Inner Cover is open.
Hope this help. PLease rate my response.
Thanks
have a good day.
Nov 23, 2009 | Canon PIXMA MP530 All-In-One InkJet...
I just rebuilt my Canon PC850 toner cartridge and when closing the unit after installing the cartridge it would not latch like usual. I tried several times and finally got it to latch properly. Once...
Exists much reasons the film could be damaged.Most often of them - is mechanical damage.This can be use fine or thick paper, which rumpled in termo unit. To Install the new film you must required the special knowlege of the service. Do Not advise you to proceed this work without preparing. Good luck
Oct 31, 2009 | Canon Office Equipment & Supplies
Have replaced film and unit keeps saying "cover open" or check film. I replaced film correctly twenty times.
On some units it is possible to install the film upside down( backwards) but since you've done it multiple times it is more likely that the sensor that sees the film is broken or blocked. Look for a small block with two little lenses. They don't usually break per se but can get blocked by debris like scraps of paper.
Good luck
Jul 27, 2009 | Panasonic KX-FPG378 Fax
Liftmaster Remote garage door openers work intermittently.
check to see if your ant. is up inside of the cover it's a little black wire that hangs outside of the operator shiould be about 6 inch.
Jun 02, 2009 | liftmaster Chamberlain Garage Door Opener...
Replaced film, unit say's "Check film, Cover open". Film is fine, cover is closed, can't figure ths out?
I had that problem once and I unplugged it for 5 minutes and then replugged it in and it was fine.
That's what worked for me.
May 30, 2009 | Office Equipment & Supplies
Shutter stays open on mamiya 645 M
Get any crud from the battery out of the works with pH-neutral stuff and q-tips or lint-free towels, and see if it works (without film; might as well check current drain with a bench supply instead of a battery, too) once you've done a satisfactory job of that.  Then visit a shop so they can see if the shutter timing is tolerable...and perhaps sometime you can load film in again.
Jul 31, 2008 | Mamiya 645 Medium Format Camera
Panasonic KX-FPG378 Fax Logo
165 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
