I have NEC washing machine- NWTL 656/ 6.5KG. The spinning does not work. Where to look for problem?
SOURCE: washing machine nec nw-652
I had the exactly the same problem and then got to the stage that it wouldn't work at all. So i looked it up in the manual and found out that it was the filter, (and thats not the lint filters like i originally thought lol) so i cleaned it out and now it works better than new. Hope this helps you cos it was such a relief that i didn't have to buy a new one.
Posted on Jan 10, 2008
dutchman05
  • 487 Answers
SOURCE: E3 error on NWTL 506
Hi that is for me a hard one as I think you are locates in AU but please sent question to HERE and they will answer it for you during office hours. No problem
Posted on May 13, 2008
JULIANFIX
  • 975 Answers
SOURCE: NEC NW452 4.5kg washing machine - spin cycle not working
theres 2 things to look for , 1 the LID SWITCH that tells the main module that is OK to SPIN, it could be loose or defective (need a multimeter to check the voltage on switch) 2 the DRAIN PUMP MOTOR , usually it gets stuck with lint and debris, need to open washer ,locate at the bottom on one side where the DRAIN hose is connected, is a small motor , take it out and check inside for clogged stuff , also check drain hose , hope this helps , AJ
Posted on May 16, 2009
ghost4548
  • 776 Answers
SOURCE: nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Posted on Jun 30, 2009
  • 25 Answers
SOURCE: I require a user manual for a Whirlpool AWG5122
if you go to the whirlpool web site under support you should be able to download one.
Posted on Apr 07, 2010
I have a nec nw-691, when you put it on spin cycle it brings error message --lid open??? plz help
Yuo might try making sure it is still level but I'd just try using a lower spin speed. How have to use "gentle spin" when I wash towels or my washing machine has errors and stops. If still too damp just use a gentle spin only cycle once more to finish the job.
Apr 16, 2015 | Washing Machines
How to fix NEC NW-961 6kg
Good to know the washer is working fine.
You may also benefit from running the washer empty with a cleaning agent like this
http://www.rubbedin.com.au/Product/17/The-Magic-Range/Washing-Machine-Cleaner-
Apr 27, 2014 | Washing Machines
My NEC NFL855 E3 error
E3 error is discharging water problem. ie 1.the pump not working (under bra wire will stop it spinning) or 2. the discharge hose blocked or most likely 3. the pump inlet hose from the drum is blocked (with small article of cloth or coins or similar).
To Fix:
1. Open the pump filter and check if spinning during empty/spin cycle, make sure nothing jamming or twisted around impellor.
2. Check discharge hose is not crushed or kinked.
3. Lay machine on its side, access pump and remove inlet hose assembly and remove any blockage.
Jeremy
Jul 19, 2009 | Washing Machines
Nec nw-891 washing machine will not complete the programmed cycle
Jun 30, 2009 | Washing Machines
May 16, 2009 | Washing Machines
HELLO WE HAVE A NEC WASHING MACHINE AND IT HAS STARTED TO ONLY SPIN LARGE LOADS OF WASHING IF THERE IS A SMALL LOAD IN THE MACHINE IT GETS UNBALANCED AND WILL NOT SPIN EVEN WHEN WE MOVE IT AROUND IN THE...
FRONT LOAD MACHINES ,WE DO NOT RECOMEND WASHING SMALL LOADS IN FRONTLOAD WILL NOT CLEAN CLOTHES PROPERLY,, ALL FRONT LOAD MAKE SAME NOISE WILL TRYING TO START SPIN CYCLE
Nov 27, 2008 | Washing Machines
E3 error on NWTL 506 washing machine
May 13, 2008 | Washing Machines
Washing machine nec nw-652
i am having the almost the same problem with what i have, if it is turn, the water will just keeping on pouring in non stop, it does matter wether it is wash, rinse, dry or spin the water will just keep on pouring in at all time, it is not a good machine at all.
Sep 09, 2007 | Washing Machines
Lg washing machine wft855a top loader
Following up my comment from yesterday, I took the machine apart and discovered that the black rubber cover on the valve that releases the cold water had perished and cracked, and wasn't opening properly.
I tested the hot and cold solenoids and everything checked out ok. Was just the cold valve sticking.
The wash cycle was working because I was using hot/warm water. As the rinse cycle needs cold water to get started, it was not working and the rinse and spin cycles wouldn't complete.
I have swapped the valves over for now (put the working hot one on the cold side and am using cold water only). It's working while I order a replacement...
Sep 07, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
123 people viewed this question
Top Washing Machines Experts
