Question about Luminox 1572 Wrist Watch
How do you change the battery for a Casio 1572 watch? I've changed the battery but still have no display on the screen, is there a reset button inside? When opening I made sure to keep the small springs in place etc.
My watch Casio buttons has stopped working, what is the problem.
Hi
What Casio model is it?
Do you still have a bright display?
Have you tried removing the battery to reset it?
In some Casio watches like the Protrek range the back light button fails to activate the display light. This is sometimes caused because the earth flange that completes the circuit when pressed has bended to far or snapped and fails to complete the circuit.
More info about the watch may help find a solution. mean time change the battery it may start working again. Good luck
Feb 12, 2017 | Casio Watches
Found small spring when changing battery
This happened because the COIL SPRING was lost during the battery change. This happens quite often to DIYers, as they do not know how the watch is built and the coil spring itself is very small, so, it's easy to loose it without even noticing it. Coil spring transmits electrical signals/vibrations from watch's movement to the quartz membrane attached inside case back. Now you have to find yours or need to visit your nearest watch repair shop and ask for the new one to be fitted..
Oct 18, 2012 | Casio Watches
I have an old Casio watch 863 SDB-500W, I have just change the battery . Light is working but nothing is display. How to reset it ?
To reset the watch, you need to 'short' the reset point with the battery. To do this, with the watch face down and the back removed the 'Reset' point is in the bottom right hand corner (a gold-coloured contact point). Use a pair of metal tweezers or an unbent paper-clip (anything as long as it's metal and will touch the reset point and the back of the battery at the same time). Maintain contact for about 5 seconds and you should get the display back.
I've just changed the battery in my SDB 500W and the above method worked. I did lose the audible 'beep' though and I'm currently on the net trying to find how to get it back. That's how I found your question... :)
Jul 24, 2011 | Bulova Watch
How do I replace the watch battery for Casio DW-6900?
mcdevito75 here, Casio uses an LCD crystal, Liquid Display Crystal, during a battery change any, any un do pressure remopveing or replaceing the battery could destroy the LCD. Take my advise, with a casio watch, look for a small watch repair shop in your area for the battery change. I"ve ruined many of my casio watches during battery change.
Aug 27, 2010 | Watches
Does not start after battery change. buttons are not functioning. display is fixed on 1- 1 SAT. light is off. I tried to reset shorting AC and [-] for more than 3 sec. but nothing happened. I concern it...
mcdevito75 here, Return your watch to whoever replaced the battery for adjustments. ------ If you replaced the battery yourself, you may have mis-aligned the buttons that press against the quartz movement to change the display, you"ll have to go inside the watch and make sure the buttons are touching where they are suppose to. It"s also ossible your new battery is weak from a long shelf life. Here also is Casio contact number, 800-706-2534 Optn. 2
Jul 13, 2010 | Casio WVA105HDA Wave Ceptor watch
How to restart my casio module no 2271 watch
mcdevito75 here, I'm figureing you"ve changed the battery, Pressing the MODE button should re-start your watch. If you didn"t change the battery and your watch just stopped, try pressing the MODE or any button to re-start the watch. If nothing, change the battery and repeat the above instructions.
Jun 23, 2010 | Casio PRG-40T-7 Pathfinder
Casio 1170 ATC-1200 watch needs to have batteries changed
I'll post in case somebody still needs this. This is the general procedure to switch the ATC 1200 from meters to feet. You can also switch the ATC 1200 (1170) from C to F. This is very helpful if you change the batteries and the watch gets reset to meters.
Also note, when you pull out the two batteries, you may not get the watch to come up. This is because of a race condition when the watch gets power. To fix this, look for the AC mark on the inside of the watch. Under this marking, in a little space to the left, are two copper pads. Short this out with a small screw driver to get the watch to ground zero.
To fix the Metric measurements:
1. Go to the home screen on the watch. This is when the the 3 letter abbr for the day is at the top. Also, if you cycle the mode button, it is the screen where the final beep is "high."
2. Then press the "memory" button, which will take the home display to the data screen. This shows current time, pressure and temperature.
3. Hold down the adjust button, until the set screen comes up.
4. Tab the mode/select button on the watch until you get a flashing C. Then press the memory button to toggle to F.
You can adjust all the measurements from this screen.
Jan 10, 2010 | Casio Watches
The time was supposed to change automatically. When I changed manually, it reverts right back Casio 1572
I have owned Casio watches for years, and the one thing I learned is to save the user manual preciously. I have never been able to set my watch without looking at the manual. And more often than not, I had to try the thing several times before getting it right. The only help I can provide is to give you the link to your watch's module manual.
Hope it helps.
Nov 03, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Casio 81cs-36 watch
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
May 02, 2008 | Casio Black Casual Sports Watch W7521AV...
Casio Databank watch
The replacement battery may be defective.
Nov 08, 2017 | Casio E-DataBank DBC3101 Wrist Watch
Luminox 1572 Wrist Watch Logo
571 people viewed this question
Top Luminox Watches Experts
Dennis Fitzsimmons
Level 1 Expert
ibewjm
Are you a Luminox Watch Expert? Answer questions, earn points and help others
