Hello, show the error As "CARRIER ERROR" At the time of power on of wep wincor nixdore high print 4915xe please give me solution for this Rudresh
JackHeath
  • 1049 Answers
SOURCE: error 1203 and carrier jam error
Error 1203 on a Lexmark is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would suggest you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
If that doesn't work just call up their support number and check for replacement..
Posted on Jul 28, 2008
proprod
  • 9 Answers
SOURCE: error-oxd 0620230 reset power
This document should help you out. Follow the instructions carefully.
An '0x ...' Error Message Displays on the Front Panel When Printing
Posted on Feb 01, 2009
Ajkill
  • 2035 Answers
SOURCE: Lexmark X5495,Error 1203, Says Clear Carrier Jam
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the All-In-One (AIO) on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
No: Continue to Step 4.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 4 and 5. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 6.
6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 7 Insert the black cartridge. Close the top cover, reinsert the power supply and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, skip to Defective Cartridge Test.
Posted on Apr 15, 2009
remaker
  • 449 Answers
SOURCE: my kyocera fs-2000d is giving an error message
You need to replace the waste toner box.
http://www.kyoceramita.co.uk/index/products/consumable/toner_installation.-cps-12303-files-97992-File.cpsdownload.tmp/Toner-2000D.pdf
Posted on Apr 13, 2011
  • 116 Answers
SOURCE: how to solve transport error on wincor nxdorf 4915xe
usually transport errors mean that something inside the printer is not allowing or not feeding the paper through properly , either a motor isn't kicking on, paper is not being picked up from the supply tray properly or there may be something caught in one of the stop sensors inside the printer that will not allow the paper to pass through properly. unfortunately the only way to fix that usually is to look at every sensor in the paper path and ensure nothing is blocking or holding any of the sensors open if none of those are blocked off then you may have a bad motor on one of the drives that pull the paper from one location to another inside the printer.
Posted on Jun 25, 2014
Wincor nixdorf 4915xe, i get "carrier error" on display, occasionally. what is this error pointing at?
Carrier error relates to ribbon. If ribbon is very loose or not properly installed it will give carrier error. Reseat the ribbon assembly and tighten the ribbon using knob available on top side.
Oct 14, 2014 | Office Equipment & Supplies
How to solve transport error on wincor nxdorf 4915xe
Jun 25, 2014 | Brother Dcp-7055 Laser Print Copy Scan...
CANON ir 3300 ERROR CODE 602-003
Dear All,
I need driver for wincor nixdor beetle /M II Plus, TH230, BA84,80 ? who can help pls.
Jan 06, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
I'm having cartridge problems with lexmark z2420 printer
The problem could be due to a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Jan 31, 2012 | Lexmark Z2420 Printer
Message reads "cartridge short press power key"
The error indicates that one or both of the cartridges has a short circuit. Please follow the steps below to identify and fix the problem:
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
5. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 11, 2011 | Lexmark X83 All-In-One InkJet Printer
Lights flash and message appears "Turn off and on again." Have tried disconnecting the printer from the data cable and turning the power off and on. Have disconnected the power cable from the...
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
Aug 28, 2011 | HP Photosmart C5580 All-In-One InkJet...
Lexmark X6570 printer cartridge black or colour not recognised error 005, they are correct cartridges, contacts are clean, will not print test page, used diagnostic tool and quote: incorrect cartridges,...
The Lexmark X6570 printer uses these cartridges: - #41, #41A, #42, #42A, #43XL, #44XL
Follow the steps below to fix the problem: 1. Remove the print cartridge that is indicated and close the cartridge carrier lid. 2. Close the scanner unit. 3. Disconnect the power cord from the electrical outlet. Wait a few seconds. 4. Reconnect the power cord to the electrical outlet. 5. If the power button is not lit, press it to activate. 6. Reinsert the print cartridge and close the cartridge carrier lid. 7. Close the scanner unit. 8. If the error reappears, then it could be a faulty cartridge. Replace the print cartridge with a new one, close the cartridge carrier lid, and close the scanner unit.
Jul 28, 2011 | Lexmark X6570 InkJet Printer
Hello, just today my printer (HP Officejet 6310 All-In-One InkJet Printer) showed an error saying , "Cartridge Error: Cartridge in the left must be replaced. I put ink on both , just in case that was...
You need to decide upon a suitable replacement. HP recommends using their ink cartridges, but you can also choose to use a cartridge from a different brand. If you have a higher volume of prints, you may even consider refilling old cartridges to cut down on costs.
Remove the old cartridge by removing the main cover. The cartridge carriers will automatically move to the center. Press the top of the carriers to open the plastic lids covering the cartridges. Gently press down on the old cartridge and slide it out.
Install your new HP printer ink cartridge. Remove the blue protective strip from the contacts and place the cartridge in the carriers. Press down gently until the cartridge sits in its position. Replace the carrier lid and main printer cover. Restart the printer and take some test prints.
Nov 17, 2010 | HP Officejet 6310 All-In-One InkJet...
1,368 people viewed this question
k24674
