Dell laptop power adapter problem
I have trouble connecting my power supply into my laptop. for a while I would shake the cord and push the adapter hard into the slot until I see the charge sign come on. Recently this stopped working and I am unable to connect. Any advise on what the issue is and how to fix it?
    Problem Solver:
  • 9 Answers
What finish the story, if you wnat some help.
Posted on Dec 19, 2008
6ya staff
SOURCE:
My dell studio1555 laptop is not recognising my mains lead/charger
Plug the adapter into the wall outlet or power strip. If using a power strip, make sure the strip is on. Most laptop power adapters have a small LED light; the light will illuminate when power is being transferred from the outlet to the adapter. If the light illuminates, chances are you have sufficient power to supply your laptop. Wiggle the power cord if the LED light did not initially illuminate. If the light turns on and off when you wiggle it, you might have a loose cord in the adapter, or the outlet could be faulty. Plug the adapter into another power outlet, preferably a different circuit in another room, if the LED light did not illuminate the first time. If it lights up from the second outlet, the first outlet either does not work or other devices were using too much power on the initial circuit. Connect the other end of the adapter to the laptop and turn the laptop on. When the computer starts up, you should see an indication of how the laptop is being powered in the lower right-hand corner. If you see a battery icon, then the laptop is being powered by the battery, not the adapter. Make sure both ends of the adapter are securely connected. If they are, and if the LED light on the adapter is lit, then you likely have a faulty wire that is not properly connecting to your computer. If you see a plug or adapter icon, then the laptop is successfully being powered by the adapter. If the LED light on the adapter is not lit, then the bulb is out, but the adapter is still working.
Jan 20, 2013 | Dell Computers & Internet
The ac power adapter type cannot be determined,your system will operate slower and the bettery will not charge. please connect a dell 65w AC adapter or Higher for best system operation.
Dell power supplies use 3 wires. One detects the power supply. If you are using a Dell supply then that wire is broken inside the cord or at the connection. If this a universal power supply it only has 2 wires.
Nov 14, 2009 | Televison & Video
Dell Inspiron Laptop Not Recognizing Universal Power Cord
some universal adapters work.but a dell power supply would be better for you.at least you know its the proper one. ebay search there.
Oct 08, 2009 | Computers & Internet
Pa-19 power supply for my Dell m1730 is broken
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Sep 08, 2009 | Dell XPS M1730 Laptop Computer PC...
I have a Laptop, Dell Inspirion 9100. Recently it
I would suggest testing your laptop with another adapter, first. Then you'll know whether to replace the adapter, which is priced around $50.
Aug 01, 2009 | Dell Computers & Internet
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell Laptop power supply charges sporadically
when i replug my Dell laptop ,the charging system does not display.
Mar 13, 2009 | Dell HQRP Replacement Laptop AC Adapter /...
DELL XPS M140 POWER ISSUE
Hi brendanram!
I am claudus_07 and i was a Dell - XPS Technical Support Specialist before so i will be glad to assist you with your concern.
As you said into your post, you tried plugging the AC Adapter to the power source without plugging the other end into the XPS laptop and the Green Light on the adapter is lit. But when you plug the jack on the laptop, the Green light is out. As for my experience on your laptop, there could be a problem with the power supply or the motherboard of your XPS laptop. Because everytime you plug the adapter to the laptop, the green light is going out so it means that the laptop or the adapter is grounded.
Here's what you need you to:
Step 1: Call Dell XPS Technical Support 1-800-624-9896
Step 2: Tell them the issue and the things that youve done.
Step 3: At the end of the troubleshooting, i know that the Technician will either replace the Power Supply, Motherboard, or the Adapter. (if you have a friend that has a Adapter same as yours, you may try to use it just to isolate the issue the Technician will choose from the Power Supply or the motherboard)
Step 4: If the Technician replaces the power supply and the issue still persists, call technical support again and ask them to replace the motherboard, no need to repeat the troubleshooting steps anymore just tell them that youre already done with it. (Dont ask for a system exchange, because i know that they will not give what you want.)
Thanks!
I know it will work. Be Positive!
Your good rating will be very much appreciated.
Good luck and thank you!
- claudus_07™
[email protected]
www.romaragregado.tk
Jul 27, 2008 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
AC adapter for dell laptop inspiron 2200
You can order the part from this link
Dell_PARTS_ADAPTER
Once you open the link scroll down and select the second adaper in the list
60 Watt 3 Prong AC Adapter with 3-ft Power Cord for Dell Inspiron 2200 / Latitude 110L Laptops
May 20, 2008 | Computers & Internet
Dell 922 AIO printer~~ does not power on when press power button all cords are connected ~~ is there a power supply in the power cord that fails ??
I had a simalar problem. On the back of the printer where the power cord plugs in it is connected to a power adapter. The adapter was burnt out. the power adapter slides out. Mine was melted easy to see. I ordered one from dell. If you do order one from dell make sure they send you the correct part. They sent me the wrong part the first time. There customer service dept. ha gone way downhill.. Regards Frank
Oct 02, 2007 | Dell 922 All-In-One InkJet Printer
Open Questions:
Computers & Internet Logo
128 people viewed this question
Ekse
Marvin
Marvin
