MY HI SUPER TAC-12CHS/G AIR CONDITIONER WONT HEAT. PLEASE HELP
3 Suggested Answers
flatech
  • 111 Answers
SOURCE: TCL model tac 24chs/k air conditioner is leaking from the
You will want to remove the panel in front of the air handler, usually a few 5/16 screws.
Once open then with a flashlight look down inside where the water collects in the condensate drain pan.
Verify that the pan is not full of water or algae build up.
If it is, then attach a wet vac to your drain outside and while it is pulling on the drain line spray some water inside till it is fully clean.
If it is not full of water then check the pvc pipes that are attached to the drain pan, they may have came loose and may need to be teflon taped and reconnected to the pan. Also verify there are no cracks in the pan.
Lastly inspect the bottom of the evaporator coil (Not the top) pull out the filter and make sure the coil is clean or water could drip down past the pan into your dwelling. Make sure as well that the insulation on your panel that covers the unit is intact and not worn away.
Good Luck!
Posted on Nov 14, 2009
SOURCE: TCL air conditioner wiring
John what is the problem ? My 18CHS gave me problems but are now fixed. Maybe I can help
Posted on Feb 24, 2010
Air conditioner TCL TAC-12CHS/G not cooling
you could have ither an electronic or lectrical problem, your electronic board in the inside unit or a bad capacitor for example not letting the compressor to run. call a service man or some thng
Jan 26, 2014 | Heating & Cooling
Rudd acheiver 10 heat pump wont stay cool
did you change the air filter and do not set it below 70,the tstat is not a gas pedal its works like a light switch, on or off, also please don't use your breaker as a switch its a safety device and will be damaged over time,If the unit starts to form ice (and it should never do that)
set the tstat from cool to off and the fan button from auto to fan on,this will speed up the thawing
Jul 02, 2013 | Ruud UBHC Air Conditioner
Have a goodman ckl-24-il unit with txv.need superheat,and sub-cooling chart
here is a link to a pt chart click at top right all you need. just google how to take super heat or sub cooling if you dont know how. super heat should be @ 7-12 and ur fine. if you are over 32 deg f or 55 psig u should also be fine
May 30, 2010 | Goodman CKL30AR30 Air Conditioner
Dec 18, 2009 | Heating & Cooling
MY AIR CONDITIONER TRIPPED ,NOW IT WONT COME BACK
Unplug unit let set till cool then turn on motor has heat trip button that will pop out so it wont over heat, It should pop back in when it cools off. Make sure filter is clean and condenser is not iced over by high humidity. If unit still wont come on check house fuse or breaker it should be on a circuit by it's shelf, flip it off and back on so it is closed all the way.
Jun 27, 2009 | Fedders A6P09S2A Air Conditioner
Air conditioner leaking in cold air in the winter
usually a cover goes on the outside but TOO HIGH your super needs a boot in the ****.open the front grill and put a towel or hand towel over it close cover back.that should help till your super gets a ladder
Nov 13, 2008 | GE Built-In Room Air Heat Cool Air...
Heating & Cooling Logo
423 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
