Question about Kenneth Cole KC1639 Watch
The main button isnt working and now i cant use the touh screen or even adjust anything on the watch.
  • 2,334 Answers
You have to visit your nearest watch repair shop. It is not possible to say what's wrong without close inspection.
Posted on May 18, 2011
How to adjust analog time in my g shock 20 bar
Press the "Adjust" button. It's usually the top-left button, slightly smaller than the rest. When you have successfully pressed the button, one of the numbers on the screen (generally the seconds) should begin to flash.
Choose which number you would like to change (hours, minutes, day, etc.) by using the "Mode" button on the bottom-right to cycle through each option on the main screen. You'll know when you have reached your target position because that number will flash.
Use the top-right button (usually labeled "Start/Stop," or sometimes "Light on/off") to change the number once you have highlighted the position you wish to change. When you have finished making the desired adjustments, press the "Adjust" button again to complete the process.
Use "Adjust" on any screen of your Casio G-Shock watch. To reach the watch's other screens, press "Mode" (bottom-right button). Most G-Shock watches have four screens total, including the main screen. On each screen, use the same process described above to make adjustments to the time (with the exception of the stopwatch screen, which does not keep time.)
Mar 15, 2017 | Watches
I cant fix the analog of my watch pasnew model PLG_1002AD GRADE A QC 6
Ignore the instructions I found its not as easy as they say first you need to sync the digital and analog to do this press all four buttons at once and hold for 3 secs tho sets the digital clock to 12 Now press mode till you see h-s hold reset till h-s flashes hold the start button in the analog will start moving its slow so be patient set analogue to 12 exactly ignore the minutes that have passed press preset the minute hand will automatically adjust once done press mode go to the main watch screen hold preset use mode to select hours minutes date year month etc and start to change the values keep it on 12 not 24 hour clock set the clock and press preset the analog will now automatically adjust to the time once done you can change to 24 hr mode if you wish
Mar 06, 2015 | Watches
Hi I have a g-shock watch, problem is that even though I have synced the time to the correct area (London) my watch appears fast. I feel the watch has the correct time because on the little digital display...
all you have to do is to set the analog time, to do this just simply press the mode button until the H-SET in the digital face appears then press and hold the adjust button on the upper left until the digital time appears, then press the upper right button until the analog time reaches the exact time of the digital. last, press once the adjust button... I hope this will help you..
Feb 05, 2013 | Watches
The directions in the booklet don't make any sense. I cant change anything.
press and hold the lower right button, the digits blinks(blinking means changeable) use the "mode"/the lower left button to choose what digits are you going to change. the upper right button is use for adjusting. if your done just press the lower right button. i hope i had been helped you
Sep 12, 2011 | Adidas ADH6079 Watch
Cant set anything on this watch. its a 144d indiglo. i have the booklet that comes with it but its not working like that.
if your 1440 timex watch has a set button, press and hold it until some of the digits blinks and the one that blinks can be adjusted. but if your watch doesn't have a "set" button, press and hold the "mode" and it turns to 0 00 press it again and the time blinks and you can set it. if you like most accurate solution please give me the model no. of your timex watch. thanks!
Jul 10, 2011 | Timex 27191 Wristwatch
Resendly purshased a casio 4772 watch. diplay time and city. trying to get it set for dst. read manual and cant get button (A) to flash. can u help
Hi ...
your watch supports Time Zones , Automatic time Updates, Automatic adjustments of DST.
First Verify Correct Home City Is Selected
1. In Time Keeping Mode (That is The Digital Display shows time and Day of week)
2. Press Button (A) long enough to country code start to flash on digital display.nightflare_4.png
3. Press Button (B) or Button (D) to change Country code to current one.
4. After Selecting Desired Country, Press button (A) TWICE.
Now Country Code will be saved on watch.
Supported Country codes are:-
To Activate DST (Daylight Saving Time).
2. Press Button (A) long enough to Digital Display start to flash.
3. Press Button (C) TWICE to Display DST Settings.
4. Press Button (D) repeatly to cycle through three DST Options:-
A --> DST is set on Automatic Mode. If Your country uses DST, the watch will Adjust DST Accordingly.
OFF --> DST is set to disabled. No DST is applied to Main Time Settings
ON --> DST is Set to On. DST is applied even if your country doesnot follow DST.
5. Press Button (A) TWICE to save Selected Option.
Default values (Factory Settings) when you bought this watch is
This way you can set DST
Mar 13, 2011 | Watches
How to set time
To set a digital watch you must have two buttons.
There must be a "mode" button which steps through the setting screens and a "set" button which adjusts the current setting screen.
Keep looking to find the second button.
As a last resort you should speak to Keneth Cole (set their web site for contact details) and ask them to help you.
May 02, 2010 | Kenneth Cole KC2315 watch
I have a jaga digital watch. It has a light/adjust/set and mode button. How do I set it for the time and then use the timer. it has a 8 lap memory. Hannah
hey. so you hold the set button down when your on the time mode, then the hour digit flashes and press the adjust button till its the right time, then the mode again to flash the minutes, then adjust till its the right number then that should be like it. once youve got the time and date and everything right press set and it should be done. hope this isnt like rela late or anything. x
Apr 19, 2009 | Watches
Can't set the time or adjust the ******** crystal Starck PH-1100
Take a VERY close look at yor watch and you should notice a few tiny buttons. One of them should correspond to MODE, another to SET and so on- depends on how many your watch has.
Use a pin or a needle to push them and find out the settings procedure.
If you cant find buttons on the case sides, examine case back. They can be hidden between the lugs, so, the strap should be taken off.
Remember- there are no watches in existance without adjustment features. Even atomic clock needs to be adjusted after a few million years of work:))
Good luck.
Arthur
Dec 16, 2008 | Fossil Watches
I can't even set my Casio Marine Gear watch.
Go to this link and with the four digit module code from the back of the watch you should be able to get a manual; http://world.casio.com/wat/download/en/manual/ Hope this helps :)
Jan 15, 2007 | Casio Marine Gear MTD1042A-2AV Wrist Watch
Kenneth Cole KC1639 Watch Logo
210 people viewed this question
Top Kenneth Cole Watches Experts
Jimmy Accardi
Gary Nitowski
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
