Question about Cameras
My camera says "lens error, restart camera." I restart the camera and the same msg pops up.
  • Cameras Master
  • 13,434 Answers
Is your camera still covered by warranty? you can try tapping the camera on the sides, but its best to send the camera to repair.
also there should be a reset switch / button you can try pressing, most likely its documented in the manual but as you didn't mention brand or model I don't know.
you can get a free repair estimate from
www.advancecamera.com/repair
Posted on Aug 14, 2008
  • Cameras Master
  • 19,396 Answers
Try first removing batteries for one minute.
  • Ginko
    Ginko Aug 14, 2008
    Lens error is caused by a problem within lens gear. Sometimes you clear the error just restarting the camera or removing batteries.
    If it does not clear try the following:
    If lens barrell does not open or retract completely try helping it with your finger nail while you turn camera on and off, try also tapping gently the back of the camera with the palm of your hand while lens extract.
    If you see dust or dirt in lens gear spry some canned air.
    If the simple tricks above did not clear the error, then the lens barrel must be taken apart and re assembled, you can have this job done at any camera repair shop.
    Check also your guaranty terms and eventually call service number that you find on camera user manual.
  • Ginko
    Ginko Aug 14, 2008
    There is sand inside the lens, this is quite normal if camera had been
    in contact with sand, you won't fix it by taking battery out, try
    blowing on lens gear, in attempt to remove sand particle, you can also
    use a compressor, like the ones at the petrol station.
    The right thing to do in this situation is taking the camera for repairs, as the lens barrell must be opened and cleaned.
    See if you can unlock it by chance in the way suggested, if not you will have to take your camera to a repair shop.
    Check your guaranty terms.
SOURCE:
When I turn on my camera - the "Lens error,
Here are some troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Jul 04, 2011 | Canon IXUS 80 IS Digital Camera
When I turn it on, the lens gets stuck. I get a msg on my screen that says "Lens error, restart camera". I've turned it on several times, and it keeps getting stuck. Is there something else I...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jan 09, 2011 | Canon Powershot A1000IS 10MP Digital...
1 MSG WHEN POWER IS TURNED ON 2 LENS ERROR -
Jan 09, 2011 | Canon PowerShot A710 IS Digital Camera
'Lens error please restart the camera' msg displaying
Jul 28, 2010 | Canon PowerShot A420 Digital Camera
Get msg when I power it on lens error, restart camera
This is probably THE most common failure among digital cameras.
There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 11, 2010 | Canon PowerShot SX100 IS Digital Camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Camera turns on BUT then get "lens error restart camera" msg
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Aug 09, 2008 | Canon PowerShot S3 IS Digital Camera
Cameras Logo
32 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
