Whenever I plug a USB Thumb drive into a Toshiba Satellite A135-S2276 it says "USB device not recognized". The computer used to be using Vista Home Basic but is now using Windows 7 Home Premium. Both OS's had the same problem even after a complete reinstallation of Windows.
  • 11,800 Answers
The USB thumb is faulty, the memory chip inside it has failed. The thumb is dead, buy a new one.
Posted on May 18, 2011
My usb ports stopped recognizing my plug in's. They work for power but my wireless mouse and iPhone when plugged in won't work now.
I have a similar problem with my A135-S2286. I noted that the mouse pad area got hot, but I found it was the Wifi card. After getting hot, the computer stops recognizing USB devices and finally the computer gets stuck.
Try turning off your Wifi and please let me know if it works.
Mar 04, 2010 | Toshiba Satellite A135-S2276 Notebook
Does the toshiba satellite a135 s2276 accomodate a second hard drive?
You won't find internal room to place a second hard drive, if that's what you're asking. Most laptops simply do not have the internal space, especially thin-line units.
What you could do for extra storage space is purchase an external drive.
Sep 01, 2009 | Toshiba Satellite A135-S2276 Notebook
I have a toshiba satellite a135 s2276. when ever i plug in a usb device it says it cant recognise the device. How do I fix this?
what type of device is this that you are plugging in? i have seen this happen and usually it requires you to download the correct driver for the device's website
Jul 12, 2009 | Toshiba Satellite A135-S2276 Notebook
I have Toashiba laptop Satellite A135-S2276. The laptop doesn?t recognize my USB flash drive. Apparently the device was detected by Windows because as soon as I plugged it in, a balloon pooped up and it...
Check it on another computer. if it still doesnt work then your backup is gone. if it does work maybe you should take it in. also try other accessories in that same port. if other stuff doesnt work then you'll probably need to fix the port. also check the drive on any USB ports in the back of you pc.
Regards
Jul 01, 2009 | Toshiba Satellite A135-S2276 Notebook
Computer canot recognize any device attached to it by USB
If Your device manager doesn't recognize any devices that are connected to your USB ports, the main problem is usually that you need to install the proper USB drivers
May 16, 2009 | Toshiba Satellite A135-S2276 Notebook
I have a toshiba satellite a135 s2276. The usb ports are all enabled but it won't recognize any device plugged in Also when i boot up the screen is kinda pinkish in color then goes black. Everything works...
The problem is with your harware. Either there is some problem with your USB ports( Mother Board) or its due to conflicting drives. Reinstall all your USB port drivers.
Mar 24, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite a135-2326 usb not recognized
HEY HEY HEY!
guess u wat? my usb came back to life! just like that! may be God exists afterl all, does He???
Jun 06, 2008 | Toshiba Satellite A135-S2276 Notebook
USB PORTS DO NOT WORK
Turn off computer and try connecting an older mouse to the mouse port. If it works:
Right click Computer>click properties>click hardware>click Device Manager> click USB adapters. Then check to see if some of them are marked. Also you can click on each one to see if each is OK. Make sure that USB is enabled in the BIOS.
Jun 01, 2008 | Toshiba Satellite A135-S2276 Notebook
Usb device not recognized
If your laptop is running Windows ME, 2000, XP or above, it should automatically do the New Hardware thing, and mount the drive. If using Windows 98se, you can probably get the drivers from the vendors web site.
Sometimes a usb port will not provide enough power for a specific device. Does the thumbdrive work in other computers? And do other USB devices work when connected to the laptop?
Feb 06, 2008 | Toshiba Satellite A135-S2276 Notebook
"USB Device Not Recognized" - any usb device
1-Make sure you are using XP SP2. You probably are but just in case....
2-Unplug all USB devices
3-Uninstall any software for the devices you just unplugged
4-Reboot into safe mode and open the device manager. Make sure to choose the show hidden devices option
Note: Follow the order of removal exactly and this MUST be done in safe mode only!
5-Remove any entries for USB peripherals like scanners and printers
6-Remove any entries for HID devices or Combp USB devices
7-Remove all USB root hub entries
8-Remove all USB host controller entries
9-Reboot to normal mode, let Windows reset the USB stack and try your thumb drive.
If this didn't work then repeat steps 1-8.
Staying in safe mode, right click in the device manager and scan for hardware changes. Let Windows reset the USB stack and try your thumb drive again.
Also when doing any of this try and get a hold of another thumb drive and try it instead of yours. Your thumb drive could be the source of the trouble. We had similar issues we tracked down to a bad batch of Memorex thumb drives.
Jan 20, 2008 | Toshiba Satellite A135-S2276 Notebook
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
