Question about General Kitchen Ranges
STANSAPP GE 6,5 GFD workshop manual. I need to replace the oil seal between the engine and the generator. I have stripped away as far as i could but, could not find the joint/coupling between it.
  • 2336 Answers
SOURCE: CBX Restoration
I have 4 CBX's '79-2, '81 Turbo, & '82. If you are using stock forks and not a real agressive rider, the ATF fluid works just fine. If you are using performance forks, have other internal modifications, or prefer the twisties, you can experiment with different weight oils. I believe that ATF is about 10W ...
Posted on Nov 10, 2008
brainyass
  • 242 Answers
SOURCE: jeep cherokee with a 4.0
Lots of clanking when first started sounds like a worn rod bearing. Check the engine compartment and rev engine to listen for knocking. It will get progressively worse as time goes by. Nothing to do except buy/install new crankshaft kit from autozone, about $300+.
In the mean time, just change oil and put in some oil additive to lessen the knocking. High speeds will accelerate the wear of the rod bearing. The rod bearing is installed inside of the piston rod. This bearing goes around the crankshaft. It has very tight tolerances down to the thousands of an inch. When it gets worn, metal will flake off of the soft bearing material and contaminate your oil more. If you catch it early enough, you can replace the bearing without too much trouble. Here is what you need to do.
Find the bad bearing. If you hear the knocking with the engine on and under the hood, disconnect a sparkplug. If the knocking goes away, that is the bad bearing. Do this disconnecting/reconnecting until you identify the bad bearings. Now disconnect battery. Next loosen drive belt- done from steering pump. Loosen 2-13mm bolts on back, one on top and one on bracket on bottom. On bottom right-hand side of pump will be a long adjusting bolt. Loosen turn this bolt counter clockwise to loosen drive belt. Now jack vehicle from the frame, vehicle will raise but tires will remain on ground. keep going as high as your jack will go. Install jack stands on frame. This extends your suspension and keep body raised. Drain oil, remove steering damper. It's the shock absorber looking thing connected to your tie rods/center link. The easiest way to remove the oil pan is to get a 3/8 inch socket adapter for a cordless drill. The bolts will come out in a hurry if you do this. Keep track of where the double sided bolts are, they secure the fuel line brackets. After all are removed, wiggle, tug, and pull pan out. Now you will see the large main caps and the rod caps. The mains are bolted to the block and the rods will rotate up and down with the spinning of the crankshaft. Spin the crankshaft to see. Each bearing cap needs to be marked. Use a center punch and hammer to mark from front to rear. 1 mark for rod cap 1 and so forth. You should end up with 6 marks on rod cap #6. Do the marking on the front side of the cap so you know how it fits back. Remove the rod caps that corresponded to the bad bearing identified earlier. Remove nut on cap. Wiggle cap back and forth until it comes loose. It will eventually come out. Inside the cap, you will see the bearing. It is basically a liner for the cap that rides on the crankshaft. there is one on the top of the rod too. Remove it by pushing rod up into cylinder and pulling it out with your hand. Ensure you remember the orientation of the bearings. One side has a notch, the other has a key that fits into a hole on the rod. Now you have the bearing in hand, check for scoring, or wearing on the face. Check the web for a nice color picture. Feel the crankshaft bearing area with your finger nail. It should be smooth and not ridged. Purchase some plastigage along with a standard .000 bearing. Clean rod surface, install new bearing and plastigage. Tighten to torque. Remove cap and measure plastigage for your oil clearance. Now you can purchase the correct bearing to match your oil clearance. If you don't have a repair manual, now's a good time to get it. It has bearing tolerances for you to get the correct bearing. After you have the correct bearings, use oil additive to grease up the new bearing/crank surfaces. Put everything back together, put some quality magnets inside of your oil pan near the drain hole and cross your fingers.
Posted on Nov 20, 2008
54generator
  • 3 Answers
SOURCE: oil leaking from generator
Whose engine do you have? Briggs and Honda have websites where you can down load their manuals and replace the rear seal.
Posted on Jan 04, 2009
bmw_tech_38
  • 113 Answers
SOURCE: BMW 318i M43TU Engine,
hi, glad i was able to help but if you want the part numbers they are 11 42 1 432 228 for the valve and 11 42 1 709 513 for the 'O' ring , hope this helps. regards mark.
Posted on Mar 16, 2009
  • 3600 Answers
SOURCE: The seal of the dishwasher is broken and the spot welding on the stainless steel strip that holds the seal has pulled away from the tub.
use super glue to glue in place in spots cut away seal near the weld seams, then make sure the door closes ok then get 5 minute epoxy and glue the seal on where it comes off, it's a permanent fix for a old machine but it will work. so go ahead and replace the seal.
Posted on May 29, 2009
Does replacing oil seal require removing oil pan on 2004 Honda civic ex 1.7L VTEC automatic?
not normally as it is in the timing cover case or behind the bottom sprocket or drive pullet for the timing belt
if it is a rear main seal it will require the transmission removal as well as the flywheel /torque converter
you were not specific as to which oil seal required replacing.
best get a workshop manual as that book shows the procedure to replace seals
Jan 04, 2017 | 2004 Honda Civic
Engine dies after 6 seconds
Hi Anonymous, your carb is gummed up. Go to Yamaha and buy some carb dip they make the best. Remove your carb, strip it down and follow carb dip instructions. If you need a service manual you can download one for $6.50 at the website below:
Harley Davidson Manuals Mark Workshop Good luck
Jan 19, 2014 | 2000 Harley Davidson FXDWG Dyna Wide Glide
I've noticed oil leaking from the unit but don't know where its coming from.
check at joint between engine and gen, its usually the engine oil seal need replacing u will need to split engine from gen, and replace the oil seal
Oct 11, 2013 | Groove Tubes Power Back 5,250-Watt...
Toyota 2e engine manual
Get yourself an aftermarket workshop manual as you need more than specs to do the job. There will be bent valves To do the job properly you will need to replace the cam shaft oil seal and the crank shaft oil seal and the idler pulley assembly. Oil is the biggest killer of timing belts.
May 25, 2013 | Cars & Trucks
Workshop manual for isuzu 4hf1 turbo charge engine, ECU
I need isuzu 4hf1 engine workshop manual.If any one got it please send it.
mesropeaccess@hotmail.com
Oct 30, 2010 | Isuzu Trooper Cars & Trucks
Wheelhouse 5500 Genarac Generator Replace rear Briggs Stratton engine Oil seal
the gen head will need to be removed if it in on that side and the flywheel side should be done as well the seals can be purchased from any auto parts store with using the numbers off the seal some engines need to be split do to the seal needs to enter from the inside side if this is the case reseal the hole engine i suggest you get a small engine repair manual or the manual for your unit this will be a involved undertaking removing the gen head can be tedious and special tools will be required so no damage to it hope this helps
Aug 30, 2010 | Briggs & Stratton Electrical Supplies
On a 2.5 range rover does the coolant and gearbox oil flow through the one radiator
No the coolant radiator is a sealed system, oil and water do not mix; as far as I am aware manual gearboxes do not have coolers.
If you have oil in your coolant water this will be an engine problem. Check the engine oil is not frothy and caramel coloured.
If your gear box oil is is a brown colour or dirty looking, this is due to water ingress, either through the breather hose or seals, try changing the fluid. If you can check the seals and breaher hose.
Suggest you get a owners manual and Haynes or workshop manual.
There are plenty of free files on line, do a search on Google, Alltheweb, Lycos, etc
Sep 11, 2009 | 1995 Land Rover Range Rover
I have a oil leak coming from the rear wheel final drive any suggestions?
oil seal gone on the shaft cheap to buy but a bugger to get off as you have to strip the drive off andthen pop the old seal off with a screw driver then slide it of and next ge the new seal dap some oil inside then slide into place and rebuild also top up oil in engine
Sep 04, 2009 | 2005 Honda VT 750 Shadow Aero
Oil leaking from generator
Dec 15, 2008 | Coleman 10' X 10' Sundome Tent 9160K101
Kitchen Ranges Logo
69 people viewed this question
Top General Kitchen Ranges Experts
Dan Webster
Dan Webster
D. E. Hev
Owen Barnes
Are you a General Kitchen Range Expert? Answer questions, earn points and help others
