When i on the printer display show paper jam - Computers & Internet
    Problem Solver:
  • 16 Answers
Required more information about this problem ?
there is a paper jammed inside your printer. open the top cover and remove your cartridge and then remove your jammed paper very carefully.
i hope it will helpful for you otherwise i need more info about this problem
Posted on May 18, 2011
    Problem Solver:
  • 19 Answers
Inspect the printer's rods and look for small pieces of paper that could be stuck. Most printers have a back troubleshooting slot that you can open, that's the most common place were you'll find jammed paper.
    Genius:
  • 1,127 Answers
Hi
First switch off your printer now open the door of printer and remove the paper that jam. checked any small paper pieces is there also removed...................now close the door and switch on the printer..
Why does my Canon printer MX310 show paper jam when there is no paper jammed?
Hi
try switching printer off & on. If that doesn't work, check the paper path for stray bits of paper or another obstruction.
Sep 20, 2014 | Canon PIXMA MX310 All-In-One Printer
Paper jam removed but machine still shows paper jam
Maybe there are paper stuck inside the printer or maybe out of ink
Apr 03, 2013 | Panasonic KX-FL511 Plain Paper Laser Fax
Key disabled message
The Down Arrow and the View buttons are disabled on the T6050 as default because reverse paper feeding is not recommended on the T6050 printer because they only have one pair of tractors which are mounted above the platen. If the printer tries to reverse feed paper, it could cause a paper jam unless the platen gap is open sufficiently to allow the paper to feed down through the gap unhindered.
You can enable reverse paper feeding if you are sure that a paper jam will not occur. This is done as follows. Set the printer to Offline. Press the Mode key: display will show Offline Normal. Press any Arrow key until display shows Offline Oper. Press the Forms/1 key. Press any Arrow key until display shows Oper Forms. Press the CPI/2 key. Press any Arrow key until display shows Forms RevPap. Press the LPI/3 key. Press any Arrow key until display shows RevPap Enabled. Press the Enter key and reverse feeding will be set. Set the printer to Online. Once the reverse paper function has been enabled this option will need to be saved to prevent the setting being lost when the printer is powered off. To save the Menu Configuration; Put the printer OFFLINE Press the MODE button, then press the DOWN ARROW until CONFIG is displayed Press FORMS/1, then press the DOWN ARROW until PRINTER is displayed Press CPI/2, then press the DOWN ARROW until SAVE is displayed Press LPI/3, and with POWERUP shown in the display, press ENTER.
Mar 05, 2012 | Tally Line Matrix T6050 Printer
Display shows paper jam, but no paper in machine.
Hi
Turn it off and on.
Try disconnecting the printer from power and from the PC.
Leave it as such for a while before connecting again.
Feb 28, 2012 | Brother MFC-5440CN All-In-One InkJet...
My HP Laserject 5100 Printer has the Paper Jam Problem. After that, I check printer. But i haven't seen any paper jam. When i print out, nothing show on paper and show the paper jam.. How to fix?
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jul 04, 2011 | HP LaserJet 5100 Printer
My printer keeps showing the message, " paper jam
Hello Tessty,
The Paper Jam message may appear on the display if the Brother machine is not feeding paper correctly, paper scraps stucked or the paper is not loaded properly in the paper tray, the jam clear cover located in the back of the machine, is not installed properly or the PE Actuator is missing or damaged.
Please visit the link provided below to resolve the issue step by step :
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000400/000095/faq000495_027.html?reg=us&c=ca&lang=en&prod=mfc240c_all&Cat=113
Jun 20, 2011 | Brother Multi-Function Center MFC-240C...
DISPLAY SHOWS "PAPER JAMMED "READING
I think it still have maybe a very small paper jammed.
Tries dismount the more you can from printer, since I'm almost sure it stills remains maybe a very small paper...
Apr 14, 2011 | Canon PIXMA MX300 All-in-One Printer
Display shows "Remove Paper Jam"
Unplug the printer and turn it around so that the back is facing you. You should see two little tabs to push, which unlock the back of the paper path in the printer. Remove the panel to expose the rear of the paper feed path. If there is any paper inside the printer you will be able to see it from this view. Remove anything inside the printer and then plug it back in. If you cannot locate any paper inside the printer and leaving it unplugged for over a minute or so does not clear the paper jam warning then contact the manufacturer directly for a possible warranty repair.
Nov 25, 2010 | Office Equipment & Supplies
Paper Jam and showing J42 on screen
look to d LCD display lay out of machines shows and the location mo paper jammed, release all green lever ang slowly removed the jam paper.
Aug 10, 2009 | Panasonic DP-8045 Grayscale Copier
Computers & Internet Logo
David Payne
David Payne
