Question about Garden
Lost my users manual for Vector pocket power inverter, 70 watt model #vec040. What is the sliding switch on the neck of the DC plug end and where should it be set for use? Is it possible to download a users manual for this inverter? Thank for your assistance.
  • 823 Answers
I can't remember what the switch is for but here is a link to the manual that you can download and keep:
http://www.baccusglobal.com/bd/manuals/VECTOR%20MANUALS/INVERTERS/VEC041%20MANUAL.pdf
Posted on May 18, 2011
Where can I get a fuse for a Vector 350?
Hopefully you are actually referring to a Vector VEC060 Power Inverter 175/350 Watt DC/AC as I cannot find a listing for a Vector 350 in the flashlight or spotlight listings.
The external fuse for the Vector VEC060 Power Inverter is a standard 30A spade type fuse available at any auto parts store. If you would prefer to purchase online, here is a link to them on Amazon:
http://www.amazon.com/Automotive-Truck-Plug-Blade-Green/dp/B00CJCS1V2/ref=sr_1_1?ie=UTF8&qid=1432440778&sr=8-1&keywords=30+amp+spade+fuse
May 08, 2015 | Vector Camping, Backpacking & Hiking
Need to know what size fuse how many amps and volts for this device.
Rule of thumb for 12vdc to 120vac inverters is 1 amp of fuse for every 10 watts of power. So, this one would use a 7 amp fuse.
Jul 06, 2011 | Inverter Vector Power - 70 Watt, Model...
Does the Vector Power Inverter VEC040 have an internal fan?
No they do not have any internal cooling devices. they rely on ventilation alone.
I will suggest that you read up on reviews for this item if you are thinking of buying one.
They have not gotten great reviews.
May 04, 2011 | Vector VEC040 70-Watt Power Inverter 40
I have a vector 750 watt inverter (vec1047bd). The charge controller in my photovoltaic system went bad and I had it repaired. When I got the controller back, my inverter did not work. The inverter has a...
If you have a manual for the inverter check and see ifDin there are diagnostic codes with the LEDs.
http://documents.dewalt.com/documents/English/Instruction%20Manual/Vector/VEC1045.pdf
I looked through this and your description of the problem was not listed in the document, but you may be able to contact the manufacturer and get more information. Basically this is a DC to AC power conversion device, which takes the 12v DC input and converts it to 115V AC
and in does so at a maximum peak power of 750 watts at 115V AC. since your charge controller went bad, it is possible in the process it overloaded this device or the battery system put out too low of a voltage when the charge controller died and low voltage input is not something this unit was able to tolerate. Check your remaining components to be sure they are good, then look at the inverter's board and transformer to see if anything was damaged. I would want to verify the charge controller was good and the batteries in good condition - and perhaps consider replacing this inverter with one more suited to your actual load wattage requirements.
Nov 19, 2017 | Vector VEC1047BD 750 Watt Power Inverter
I bought two veco51d 3000 watt inverters made by vector and conectted with two positive and two negative cables to a good battery 12.6 volts load test at 750 cranking amps and both inverters light up and...
Hello, I hear you. Was the reason to supply 240 volts? When you try the inverters separately, do you get 120Volts output? Let us look at the units working individually first and go from there.
Feb 06, 2011 | Vector 3000 Watt Continuous 6000 Peak Dc...
What type fuse does this model use
Reviewing the specs on this inverter, there is no mention of the fuse, but past experience tells me that the portion that inserts into the cigarette lighter would be the likely location. Try unscrewing the knurled portion at the tip. be careful because it may be spring loaded. Remove this assembly and a glass fuse may be located there. Check for continuity on it. You can go online and purchase the same fuse at newark.com
Dec 03, 2010 | Inverter Vector Power - 70 Watt, Model...
Plugged it into the recepticle in my2009 trailblazer, and it started smoking. removed it quickly
Hello Dusty,
Sounds like your inverter was already having issues. Otherwise, the power port in your trailblazer is wired backwards (center contact should be positive, barrel or ring should be negative).
Aug 26, 2010 | Inverter Vector Power - 70 Watt, Model...
Vector 2500 watt inverter red led fault light no output. Model veco56d.
There is a fuse on these things at the back of the case. Could be in a slide out plastic holder, or in a round holder with a knurled screw or bayonet type cap. If this fuse is not blown, then the news is not good.
Mar 21, 2010 | Vector 2000w Power Inverter
The fault light stays on my power inverter
Try disconnecting the DC input for 5 min. or so, this will generally reset the unit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Mar 13, 2009 | Electronics - Others
Garden Logo
734 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
