Question about Praktica SlimPix Digital Camera
I have a Praktika DC Slim5 but can't get it to switch on. When I press the left-hand button on the top the red "busy" light comes on for a couple of seconds then goes off and nothing further happens! Any ideas, please?
  • cornwallgeof May 22, 2011
    Actually it didn't work but I was grateful for the advice! Could not get the motor un-jambed and will have to scrap the camera.
  • 17,970 Answers
I read about this proelbm ago few time, the problem is a jammed motor. This motor is whats reponsible for the zoom on your camera lens. Dropping the camera can be enough to jar it loose but it can also damage your camera.
Also, keep in mind that some model wont work with SD upper to 1GB.
Posted on May 18, 2011
  • Elizabeth Atkinson
    Elizabeth Atkinson Jun 28, 2014
    I had not used my Praktica DC slim for a while and when I took it out of its case the red light was on.I placed new batteries in it and tried to switch it on. It did not come on at all. Just dead. Nothing. I certainly have not dropped it. Please can you help?
Sky remote code for model UE40J5100AK
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Press "TV" again then enter the code for the TV listings below (Use the 4 digit codes from the left hand column), the red light will flash twice if a valid code has been entered. Press TV then the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes below or continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code.
If you are still unable to control your TV from the remote control see: Programming The Sky Remote or go to Sky's official website where you can see if a particular remote control version number will operate your make of TV, this can be found at:Skyplease remember to use your back button and come back to us.
www.electro-medical.blogspot.com
Samsung brand code 0060
3 digit code for Samsung
065, 584, 037, 245, 476, 398, 516, 292, 318,037
Oct 13, 2015 | Samsung Televison & Video
PC twin shock gamepad
Switch your gamepad to 'analog' mode by pressing small button 'MODE' at the center. Light under that button should turn red (indicating analogue mode) from green (indicating digital mode).
Nov 14, 2012 | Microsoft Xbox 360 Wireless Controller
I want to change current keypad code linear LD050 model
To change the keypad code.
Step 1:
Erase the current code - On the upper right hand corner of the left hand side of the unit, you will see a "learn" button.
Press and hold the "learn" button for 12 seconds.
When you release the learn button, the red light above the button will blink 3 times and then come on bright for 15 seconds.
When the light goes out, the memory in the operator is erased.
Step 2:
Learn a new keypad code.
Press and release the "learn" button.
The red light will come on. You now have 15 seconds to complete the next task.
Go to your keypad and enter your desired code (1 to 6 digits long)
press start/stop on the keypad.
The red light will blink when the code is successfully stored.
Don't forget to re-enter all of your hand held remotes into the memory:
Press and release the learn button. When the red light comes on, press the button on the remote you wish to update.
Repeat for other remotes. By the way, If you hold the learn button down for 10 seconds, you'll have to start over and the memory will be erased.
Nov 14, 2012 | Home Security
03 Range rover "engine service
Try this:
Switch ignition OFF
Press and Hold left instrument panel reset button, switch ignition ON to position 1
Keep reset button pressed for approximately 5 seconds until the LCD displays "RESET SIA".
The distance to service and the service type " Inspection" will be displayed.
To reset distance the left hand button should be pressed before the 'RESET' message has
flashed 5 times. The LCD will display 'END SIA'. Switch ignition off
The timing to do this is must be about 5 seconds, if this is not working you can try again.
Jun 21, 2011 | 2004 Land Rover Range Rover
How do you set the correct date
Hi! Welcome to FixYa,
Hold down the top left hand button which is for the light and then a menu should come up saying chime and then if you want it on or off press the bottom left and so on. Keep pressing the top left hand button until it comes to time and then it will ask how many hours off the time. Choose the correct time and then press the bottom left again for the date and select the correct month and day and year and then you are all set up.
Hope this helps.
Jun 18, 2011 | Diesel Digital Dz7069 watch
My watch is stuck on military time somehow. I would like to know how to change it back to normal time. My watch is a Armitron Alarm/Chrono WR 165 sports watch. The number on the back is 45/6915. Thanks for...
Welcome to Fixya,
The Armitron WR165 is a digital watch that includes a 24-hour alarm, hourly chime, stopwatch feature, countdown timer and is water resistant up to 165 feet. With a rubber wristband and rugged style, the watch is meant for outdoor enthusiasts and athletes. The WR165 can be found online, in some sporting supply stores and in certain department or general home stores. Setting the Armitron WR165 only takes a few steps to perform properly.
1 - Push the top button on the left-hand side of the watch until the seconds flash on the display.Press the top button on the right-hand side to zero the seconds.
2 - Push the bottom button on the left-hand side of the watch until the hours flash and then the top button on the right-hand side of the watch to increase the hour on the watch display. Note that "PM" will appear on the watch display for PM times, but there is no "AM" indicator on the display.
3 - Press the bottom button on the left-hand side of the watch until the minutes flash on the display.Press the top button on the right-hand side of the watch to increase the minutes on the display.
4 - Repeat to set the month, date and weekday on the watch. Press the top button on the left-hand side of the watch to return to time mode.
5 - Press the bottom button on the left-hand side of the watch to enter the stopwatch mode. Press the top button on the right-hand side of the watch to start the timer. Press one more time to stop timing. Press the top button on the left-hand side of the watch to reset the stopwatch to zero and the bottom button on the left-hand side of the watch to return to time mode.
6 - Press the bottom button on the left-hand side of the watch twice to set the alarm. Press the top button on the left-hand side of the watch until the hours flash on the display. Press the bottom button on the left-hand side of the watch until the alarm number flashes. Press the top button on the right-hand side of the watch to choose Alarm Time 1 or Alarm Time 2. Push the bottom button on the left-hand side of the watch again until the hours flash. Push the top button on the right-hand side of the watch to choose the alarm hour, followed by the bottom button on the left-hand side of the watch to change to minutes. Press the top button on the right-hand side of the watch to advance the alarm minutes. Press the top button on the left-hand side of the watch to set the alarm time and the bottom button on the left-hand side of the watch to return to time mode.
I hope this will help you.
Thank you for usinf Fixya.
Feb 21, 2011 | Watches
I pressed the "on" button
Move the slide switch on the side of the card.
Feb 01, 2011 | Cameras
3.1 DishnetWork remote problem
I suspect that the remote address got changed somehow. Pree and hold the sat button on the top left hand side of the remote until all buttons light up across the top and release. Now key in 0-1 on the numeric keypad and press the pound sign. The SAT button will flash three times. After it the SAT button is done flashing press the small red dot record button. Now try to operate the remote. You should be able to control the system now. Thanks for using Fix Ya.
Mar 13, 2009 | DISH Network IR Remote Control
HP Business Inkjet 1200 Lights flashing
Check the paper sensor has not come loose. Lift the lid, it is on the right hand side of the rollers with the red and blue wire. Press down lightly to make sure is hasn't come loose.
If not, reset the printer:
While the printer is on, press and hold the configuratuion button and press resume (paper feed) button 3 times.
Wait 20 second and press the power button.
Disconnect the power and wait 20 seconds.
Connect the power and switch the printer on.
Feb 24, 2009 | HP Inkjet 1200dn Printer
Praktica SlimPix Digital Camera Logo
139 people viewed this question
Top Praktica Cameras Experts
Jose Ma DM.
Jose Ma DM.
Are you a Praktica Camera Expert? Answer questions, earn points and help others
