I changed power supply board of bizhub c35 and now the machine is displaying error coed 004e after initialization
4 Suggested Answers
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
  • 118 Answers
SOURCE: SCAN TX FAILED mesasage on bizhub C35
Settings not set up properly, drop me a line i may be able to help
Posted on Oct 31, 2011
  • 118 Answers
SOURCE: bizhub C35 Will not automatically select the #1
its probly because the tray attributes are off.. check to see if the trays have the exact attribute you are printing... if not then change them
Good morning. We have a Bizbub C35 how is it possible that the Meter reading has gone wrong? it is showing we have done 41000 copies yet we have only used 2000 sheets of paper. how do we fix it?
What does the total counter say inside the front cover if it 41,000 then it is 41000. Sorry you can not reset then people would sell old machines as new
Jan 27, 2017 | Konica Minolta Bizhub C35 Multifunction...
How do i fix error code 13DD ON KONICA MINOLTA BIZHUB C35
The counter data on one card does not match counter data on a different board did some one try to reset the counters to make the machine newer???? Need to get tech out to try and rewrite the firmware,
Jun 30, 2015 | Konica Minolta Bizhub C35 Multifunction...
Error bizhub c450 c9401
The bright lamp under the big glass is burned out or the circuit board that controls it is bad try this first if the code comes back get tech out to look at the lamp or board.
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Aug 26, 2014 | Konica Minolta bizhub C450 Scanner
Konica minolta bizhub c35 black toner being recognized as empty
sir/mam replace the cart then might have gotten a bad one from the store
Mar 11, 2014 | Konica Minolta bizhub C35 Black Toner...
Konica Minolta won't power on
check the power plug secure??, zero indicator lite might have a bad power supply
Jan 16, 2014 | Konica Minolta Office Equipment & Supplies
ERROR COO4E
C 004E Power supply unit cooling fan motor failure to turn.Check the DC 24 V and the connection to fan motor,if need change the fan motor.
Mar 12, 2013 | Konica Minolta Office Equipment & Supplies
Error E1 samsung washing machine model TORNADO 7.0KG WA90B
E1: Water Supply Error
-Display Shows 'E1'
-Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
-To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
-The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
Keep me posted!
Nov 01, 2012 | Washing Machines
Bizhub C35 misfeed error
This video will show some of the most common causes for Bizhub C35 misfeeds
https://www.youtube.com/watch?v=Sbo0gon8EIY
Feb 26, 2012 | Konica Minolta bizhub C351 All-In-One...
10.10.00 supply memory error coming on HP Laserjet 5200 Printer.
Dear Sir,
I has change the printer cartridge. After changing the printer cartridge above mentation comming. When I am making printer power on the (10.10.00 supply memory error) display. Please tell me how to solve this problem. Best regards,
Thanking
Ajom Khan Hero
Mobil No.092 5192797.
Al Nahr Co.Ltd
Tripoli - Libya
Jun 17, 2009 | HP Hewlett Packard LaserJet 5200 Printer
62 people viewed this question
k24674
