Question about Onkyo Audio Players & Recorders
Hello, My problem is ; when I start the receiver, it simply freeze, where they no longer respond to any remote command or buttons on the faceplate. The volume knob, the on/off switch... nothing works, but the unit is on. Then once we remove power completely by pulling the plug. After I plug on , the unit starts as same as when it was pulling the plug, and it continues the same freeze situation. Today I found a firmware update on your web page, I will update it this night when I go to home. I am wondering what is the problem. How can I get rid of this problem? It drives me crazy. Could possibly help me please? Yours sincerely.
  • 11 more comments
  • mutlu_ekim May 18, 2011
    Receiver is Onkyo TX-NR709
    I am at work now. I will try your solution opinion at night. I will inform you after i try. Thank you. I hope it will be helpfull.
    First of all,thanks for your reply. You mean that there is a hardware problem. I bought it last week. But i can't return it back to the dealer because i bought it from different country when i was on holiday. and it is not easy to send it back.
    And i can't dare to open this new device.And also i am not a specialist for this.
    The main thing i want to ask that are you sure that the problem is really a hardware problem.
  • mutlu_ekim May 19, 2011
    i did the firmware update, but it didnt work.
    Receiver is Onkyo TX-NR709. you can read the comments i wrote about what i did to make it run properly, but nothing changed.
    Nothing changes.I reset from the remote and also from the receiver with holding vcr+ONOFF button. Then I update it with new firmware, and failed again.
    i also think that there is a hardware problem. But this recevier does not selling from my country distributer, i bought it from another country. would this be a problem for service, i dont know. is the problem you said is an general problem for the receivers which can be handled by an authorised ONKYO service.
  • mutlu_ekim May 20, 2011
    I bought it last week. i update it with the new firmware, but nothing changed.
    Hello , when i ask to the authorised person he said that there is no such switches in recevier. my Receiver is Onkyo TX-NR709 . i am confused. he said that there may be a problem in the main chipset(i dont know the exact name), and it has to be changed, but the price is very high.it about 300-400 $. i dont know what will i do.help please
  • mutlu_ekim May 23, 2011
    hello,
    i took the recevier to an ONkyo service and we made some tests about the voltage, bu t it worked that time like kidding.I think the problem is not about the voltage.
  • 2,069 Answers
Did it just start suddenly or it gradually developed. this may most probably turn out to be a hardware problem than software. and would require physical inspection of motherboard components to identify which one is failing. if still under warranty, consider that but if not. then a tech may help better.
thanks
Posted on May 23, 2011
  • 4,472 Answers
I would update the firmware first and see if that fixes it. It could easily be a firmware issue. What is the model number of the unit and how long have you owned it?
Thank you,
Lee
Posted on May 20, 2011
  • Lee A.
    Lee A. May 20, 2011
    If you just bought it last week then you will want to return it to the store you bought it from as it would be under manufacturer warranty. all receivers have 2 years parts and labor warranty. visit this link:
    http://www.us.onkyo.com/warranty.cfm
    Thank you,
    Lee
  • 2,098 Answers
This kind of symptoms indicated of out-of-regulation in the power supply section. The main processor can't initialize itself because the supply voltage gone to malfunction, that is why the front panel button even the remote control can't access the command.
The common caused of this symptoms is the leaky/dried filter electrolytic capacitor in that area. It will dropped the normal working voltage of the power supply and will disable the unit. Another caused of the symptoms is the bad solder joints(cracked/dried/cold solder) in that section.
Firmware update will not solve the issue unless the faulty parts is isolated.
If you don't have necessary tools and can't troubleshoot the unit yourself, I would advice you to look for a qualified technician to isolate the problem or send it in to reputable Onkyo service center.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
    Top Expert:
  • Onkyo Master
  • 75,311 Answers
Hello
You ahven't specified nothing about your Onkyo receiver. Please provide its model number. Without it I cant post a solution before you. OK.
Posted on May 19, 2011
  • 1 more comment
  • The Knight
    The Knight May 19, 2011
    Hello
    Before udating the firmware, Check whether your remote control emits ifrared rays or not. i don't know whther you uses its orginal remote control or not. It original remote control number is "RC-807M". If the remote is OK, reset the remote mode to it default remote control code. [1] While holding down REMOTE MODE that you
    want to reset, press and hold down HOME until
    REMOTE MODE button lights (about 3 seconds).
    [2] Within 30 seconds, press REMOTE MODE again.
    REMOTE MODE button flashes twice, indicating
    that the button has been reset.
    Each of REMOTE MODE is preprogrammed with a
    remote control code. When a button is reset, its
    preprogrammed code is restored.
    Note
    • The learning command is also reset
    You can reset the remote controller to its default settings
    1 While holding down RECEIVER, press and hold
    down HOME until RECEIVER lights (about 3
    seconds).
    2 Within 30 seconds, press RECEIVER again.
    RECEIVER flashes twice, indicating that the remote
    controller has been reset.
    If these does not help you, just update the firmware. OK.
  • The Knight
    The system memory IC of your device has damaged I thinks. As the system does not work either from remote or through front panel, this is the only possibility. Your systems circuit is ver complicated one. I advice you toe get it repaired by authorised Onkyo service center nearby you. OK>
  • The Knight
    Hello --- Onkyo is a standard Japanese company. Their products are very advanced, and so much research is behind is. Each and every model I serviced since 39 years, have entirely different circuit diagams and circuits. Moreover, the system control secion of theirs nor resemble to no other companys'. They uses their own programmed system control ICs and memry ICs, which cannot be bought from open market. That is why I adviced you to get it repaired from the nearest Onkyo authorised service center. If you want to get it repaired by ano other company, contact Sony Authorised service center. They also can do this work. Anyway, its repair is so complicated one, and must have very sophisticated testing equipments and well experienced professionals. If you open it, and look. You will fell I;m right. I've repaired this model. Its system control section is very difficult to follow. Anyone who take this work will take time also. It is a general problem to most of these type of sets, irrespective of which company produces it. i know it is a costly set and its sound quality is great. Both digital and analogue technologies are used it it by Onkyo engineers. So never attempt ot repair this set by yoursef, unless you have a sound knoledge and expereince in repairing this type of sets. There is no problem, about from where you bought this set. it is a world standard set and can be repaired anywhere in this world. Ok
    Guru:
  • 610 Answers
This problem can be caused by a corrupted firmware and you can do a firmware upgrade to fix such problem. You can either upgrade using a media (DVD/CD or USB Pen Drive) or your computer network connection (ethernet cable).
As each of the models of these Onkyo Receivers requires a specific step on updating the firmware, I will not be posting the steps here, otherwise we might end up breaking it as you haven't mentioned the exact model of your receiver.
I strongly suggest you to their website by clicking here and look for your specific model of onkyo receiver. This is the website where you can download the specific procedures and the firmware (in .zip format) to update your device.
Read the instructions carefully before you start, the update procedure should take around 60 - 75 minutes.
Hope this helps.
Posted on May 18, 2011
  • 760 Answers
This is a common problem with a couple models. You have 1 or more push switches that are bad. The best thing to do is replace all 19 or 20 of them. It is only a few dollars for all of them combined and they are very easy to replace. They only have 2 legs that need to be un-soldered. The switches are on pc board that is on the face of the unit. I hope this helps you.
    Guru:
  • 1,833 Answers
Hi'
According to your problem, update the firmware. Check also the electric outlet and power cord. Try to change the cord. May there is anything in plug.
2 Suggested Answers
rockmeister
  • 2047 Answers
SOURCE: Hello, My problem is ;
What kind of receiver are you refering to? Firmware update for your receiver could be the problem but instead try to restore the old update and test the unit as the update might not be suitable for your unit. Please provide more information on the make and model of the receiver.
Hoping to hear from you soon.
Thank you for visiting fixya
KDC-148 in demo mode. None of the buttons on the faceplate will respond. Just stopped playing while I was driving one night. Any ideas. Already tried reset.
A quick trick on the faceplate connectors is to use the eraser of a lead pencil to clean the surface of the faceplate connectors. It could simply be a dirty connection.
Aug 25, 2016 | Car Audio & Video
Kenwood kdc-x811 faceplate quit responding.
Call Kenwood they can give you a code to enter by using the remote
Mar 22, 2014 | Kenwood KDC-716S CD Player
Hello, My problem is ; when I start the receiver, it simply freeze, where they no longer respond to any remote command or buttons on the faceplate. The volume knob, the on/off switch... nothing works, but...
May 18, 2011 | Audio Players & Recorders
Hi we have an Integra DTR-5.4 receiver that "locks up" The unit simply freezes, where it no longer responds to any remote command or buttons on the faceplate. The volume knob, the on/off...
Does this normally happen if you press a few buttons or settings faster in succession? If so then maybe the receiver can't keep up with multitasking or what you would call processing power so maybe just try to not select functions as fast and give it a few seconds in between changing settings before switching to another. my cellphone and receiver will also do this because of lower quality components used in manufacturing. A lot of company's now days to compete with price points are cutting corners so certain components are lacking to keep up with demand of other components in the system.
Jan 06, 2011 | Integra Audio Players & Recorders
Error code 344*
Error code344 shows that The remote machine has failed to respond to a fax command from the product because the connection was interrupted.The remote user has pressed the Stop button while the remote machine was receiving.
Under rare conditions, incompatibility between the two machines can cause the remote machine to simply abandon the call.
check here for more information
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00062808#A5
Jan 26, 2009 | HP Officejet 4315v All-In-One InkJet...
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Mar 15, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Faceplate not responding / acting very weirdly
Sounds like a bad connection with the faceplate and the multi connector that the faceplate mates with when closed. check for dirt and bent pins on both connectors. Luck
Dec 14, 2006 | Sony CDX-CA900X CD Player
203 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
