Question about Broderbund American Greetings Creatacard Platinum 8 for PC
CreataCard 8 Platinum 8 DVD
I have this software since some years. I am working with Windows XP Professional. But now, I cannot see online content anymore. Does someone know a fix for that problem ? Thanks in advance.
And.. I have a friend who have the same program : CreataCard 8 Platinum DVD. Now, he has a new computer. His OS is : Vista. When he wants to install Creatacard, he gets a message saying to contact Broderbund. I think that is no solution for him. Am I right ? Thanks for any help you can give me.
(Please, forgive me for my bad English, I am a French woman.)
  • 1 more comment
  • tirelou Aug 14, 2008
    I got this solution for CreataCard 8 Platinum DVD installed on Vista.
    Simply read this topic.
    http://forums.encoreusa.com/tm.asp?m=234...
    Hope this help somebody !
    Thanks a bunch, White Noise. Yes, it's a very bad news but I appreciate a lot you wrote me this answer.
    Have a nice day and thanks again !
    -TireLou
  • tirelou Dec 16, 2008
    Thanks a lot, steve_nicegu. It was the first thing I checked : if See online was checked and yes, it was. I don't know how to fix this problem. But thank you very much to help me. I appreciate your help a lot.
    Again.. sorry for my bad English.
If you look at the cards or art... and then look at the bottom of the screen you will see a box that you can check or uncheck.. one box say's online... make sure it's checked.
we didn't notice it for about two years and cried about for the whole two years until we figured out you can just check the online box and get everything back
good luck
Posted on Dec 16, 2008
It looks as though American Greetings has discontinued CreataCard which means they shut down the online content. There is no solution as American Greetings no longer supports the product.
The program is not compatible with Windows Vista.
Sorry for the bad news. Your English is just fine!
-WN
Posted on Aug 14, 2008
I run win7Pro & AG CreataCard Platinum 8 will not install..is my favorite card making program for family & friends, any help appreciated.
CreataCard Platinum 8 was written for XP and older versions of Windows. Changes in the OS make it difficult/impossible to install.
Do you have the 32-bit or the 64-bit version of Win7Pro? Click Start > Control Panel > System and Security > System. If the title reads Windows 7 Professional x64, it's the 64-bit version. (If it doesn't end with the x64, you have the 32-bit version.)
In any case, the best option is to try running an older version of Windows on another machine, a dual boot system or a virtual computer. With the Pro version of Win7, you can run a virtual XP for free (if your hardware can support it). Download and install Virtual PC and the XP mode package from Microsoft. (You'll need to set aside some memory for the virtual PC to run.) Then install CreataCard when running XP mode as if this is your only computer.
The only real problem is that you will not be able to have hardware installed on the virtual XP and the Windows 7 real machine at the same time. (So you can't share a printer.) Also, to share files between the two "systems", you will need to save them to external media (flash drive or optical disc, for example). Your motherboard and CPU need to support Virtualization. You have to turn this on in your BIOS on some systems. (Press Esc, F1, F2 or F10 repeatedly depending on your system right after turning on the system. If you miss the timing, shut down the computer and then retry.)
Other virtualization programs are Parallels and VMWare. However, with those programs and the other possible options for running CreataCard, you need a licensed version of the older version of Windows.
If you have the 32-bit version of Windows, you can try the Compatibility Mode. (Right click on the installer and choose Properties. Then click on the Compatibility tab and select Run the program as compatible with an older version of Windows. Apply the changes and click OK. Then right click on the installer again and choose Run As Administrator.) You may have to repeat this on the program icon after installing. However, the compatibility mode doesn't always work even if you have the 32-bit OS (and thus don't need the signed driver).
An alternative is to upgrade your software to one that is Win7 compatible. I'm not sure which of these Broderbund design and print products are most similar to CreataCard: http://www.broderbund.com/c-6-design-print.aspx . However, you will probably not be able to open old documents.
I hope this helps.
(XP mode is available with Win7Pro and Ultimate. At my house, we have two computers with Win7Pro with one running XP mode. At least once, the virtualization was turned off during a BIOS update and XP mode failed until the setting was corrected.)
Dec 24, 2011 | Broderbund American Greetings Creatacard...
CreataCard Platinum 4 is it copattable with Windows 7 ?
Sorry, CreataCard Platinum 4 or 8 is not compatible with Win 7.
Dec 13, 2010 | Broderbund American Greetings Creatacard...
Is Broderbund Creatacard compatible with Vista?
In Vista, start the "Windows Program Compatibility Wizard".
Choose to install a "Windows XP" program, namely the Broderbund software. Vista will wrap a "cocoon" around the application, to fool the application into thinking that it is running under Windows XP, not Vista.
Apr 05, 2010 | Broderbund American Greetings Creatacard...
My Creatacard Gold does not work with Windows 7. It worked with Vista and Windows XP.
my creatacard gold c.d dose not work on my new laptop which is window 7 can you help
Dec 08, 2009 | Broderbund American Greetings Creatacard...
I am trying to install creatacard 8 on windows xp home. it freezes at 8% installing fonts. i have installed this before on my computer and this time it does not work.
I have the same problem when trying to install on Vista (Home version), except it freezes at 4% intalling fonts. Have tried to adjust setup.exe properties to compatible options, still doesn't work. Also used Windows Vista compatability wizard with no luck.
Aug 22, 2009 | Broderbund American Greetings Creatacard...
Printing CreataCard Platinum 7 with Vista
if there are they will be on their website, but i'm going to say you've probably made that software useless and will have to buy a new program
Jul 25, 2009 | Broderbund American Greetings Creatacard...
I am getting a laptop computer. I have CreataCard Platinum 8
Vista has been a problem since it was introduced. Essentially Microsoft released it without ensureing driver were available for existing software and hardware. Some manufacturers have been making efforts to get Vista compatible Drivers available. Check the software websites for updated drivers.
Feb 20, 2009 | Broderbund American Greetings Creatacard...
Creatacard Platinmum 6 won't work with Windows Vista.
CreataCard Platinum 6 is designed to be used with Windows 95/98/2000/Me or NT 4 and XP, therefore in order to run it in Vista I'd suggest to run your program using Compatinity Mode --> Go to your Desktop --> Right click on the program icon--> Properties-->Compatibility--> select one of the versions above
Nov 12, 2008 | Broderbund American Greetings Creatacard...
Broderbund American Greetings Creatacard Platinum 8 for PC Logo
667 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
