Question about Welding Tools
Need operators manual for migomag 300 and 315 compact mig welder
CarlGehrke
  • 169 Answers
SOURCE: electrical problem with mig welder
Call Lincoln Electric (the manufacturer) at 216-481-8100 and ask them to email you one.
please rate my answer,
Carl
Posted on Dec 03, 2008
luxur4
  • 92 Answers
SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
Posted on Jan 23, 2009
luxur4
  • 92 Answers
SOURCE: SNAP-ON FM140A MIG WELDER. HOW TO SET UP WIREING
Hi, yes it can be ugraded but,( theres always a but,) you will need a feed from the mains to a rated connection on the main fuse box, this is not a DIY job, certain rules and regulations prohibit the unqualified. the new line will run to it's own fuse box, then to wherever you want, garage or w/shop with electrical cable 1.5biger than your max (30 amps) best be safe , you cooker socket is thirty amp, but thats max, there are some people that would increase the fuse size, ending up,( If they arel lucky), for a total re-wire those unlucky guy's arn't around to tell the tale. contact your provider and get it safe.
lets know how you get on
Posted on Mar 01, 2009
  • 14 Answers
SOURCE: looking for operating manual for dan mig 140 mono
go to web sight theyll b happy to help,
Posted on Mar 15, 2009
  • 5 Answers
SOURCE: owners manual for a century wire feed 83160 mig
I believe century was bought by lincoln. call 1-866-236-0044 ext 3. Ask for century parts.
Paul
Posted on Apr 30, 2009
Ya240a mig welder
You can find all the century manuals and diagrams at this page:
http://www.lincolnelectric.com/en-us/support/pages/operator-manuals.aspx?q=wire+feed&type=text
Just click on it or copy and paste on your web browser.
Jan 15, 2014 | Welding Tools
Rossi 220BZ Gas/Gasless Inverter Welder MIG MAG ARC Portable Welding Machine
The Rossi 220bz mig welder comes set up to use gas welding, that is with the Mig electrode connected to the positive terminal, inside the machine.
To use gasless mig wleding, the mig wire must be disconnected from the positive terminal inside the machine and reconnected to the Negative terminal - inside the machine. Open both the side coveres of the welder using a phillips screwdriver. Use a 13mm spanner to undo the hex nut holding the thick copper Mig lead to the terminal named positive, then lead it through the machine to the terminal on the oppisite side of the machine, labelled negative and screw it in place there with a 13mm hex screw. Be carefull not to bump any of the many electric parts inside the machine.
If you run the Mig welder in gasless mode with positive earth and positive elecrode it will blow the household electric fuse.
If you run the Mig welder in gasless mode with negative earth and positive electrode it will work, but the end of the Mig gun tip will get very very hot and start smoking abnormally from excessive heat.
But if you take the side covers off and rewire it (takes about 10 minutes) to negative Mig Electrode, the Mig gun tip remains cool and does not overheat. You will have to cut just one white cable tie, to get an extra inch or so of free Mig cable, so the thick copper Mig lead will reach accross to the terminal on the other side of the machine named negative. Stick the earth lead at the front in the positive terminal.
I did this on my Rossi 220bz mig welder.
http://www.weldequip.com/gasless-mig-wire.htm
Jun 25, 2013 | Welding Tools
Have solar 110 2172 mig welder does this mig use gas can i use flux core wire also is owners manual available
Yiu can use both innershiel and solid core wire. All you need to do is inverse the polarity for the innershield wire (gasless wire) connect the gun to the ground and ground cable to positive side.
Dec 26, 2010 | Solar Mig Welder Welding Gun Liner Parts...
The Mars 180 MIG Welder Manual neglects to
Hi mate. Not sure on the power settings but the earth clamp is negative for gasless and possitive when useing gas
Mar 20, 2010 | Welding Tools
Need an operating manual for the century 80
Do a web search for lincolnelectric.com and look for the manual for this model.
Oct 12, 2009 | Lincoln Electric LE 83180 Century...
Where can I get a operating manual for a Craftsman 00920540 Mig Welder
Try www.partsdirect.com, this is Sears website. It may have in the parts list a part number for a operation/owner's manual.
Oct 01, 2009 | Welding Tools
Need manual for Hobart 500416
Hobart has a wonderful site. Go to hobartwelders.com click on service/products and then manuals.
Paul
Mar 18, 2009 | Hobart Handler 140 Mig Welder
I want to find a operator/owners manuel with a miller welders exploded repair diagram for 350P mig & spool gun
get a hold of miller theyll be more than happy to help you,and turn you on to a owners manual.hope this helps jojogunn.
Mar 15, 2009 | Miller Welding Tools
Welding Tools Logo
233 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
