Question about Iomega MiniMax (33464) 250 GB Hard Drive
We have a MacBook Air and a number of Windows machines. I have an Airport Extreme which I have connected the MiniMax (received yesterday) to via USB (I'm also using the USB hub facility to share 2 printers). I'd like to use the MiniMAx for Time Machine backupos from the Air and general file access from all PC's. I can see the MiniMax in the Airport Utility but I can't see it via Finder on the MAcBook Air. I also can't see the hard disk on the Windows machines.
5 Suggested Answers
  • 202 Answers
SOURCE: How to lock an Iomega MiniMax 250 GB Hard Drive?
They make chains with locks that screw to a secure surface. (floor,wall, desk, specially made etc.) You then hook you hard drive to the secure lock and someone can't easily pilfer it. Hope that helps, Tim
Posted on Feb 15, 2007
  • 10406 Answers
Take the computer to a qualified Apple technician -- the hard-drive could have "died". Is the drive still under warranty? If so, you can get a replacement for free, but you will need to contact a "Data Recovery Service" if you want to "recover" any of your files.
Posted on Dec 26, 2009
  • 6831 Answers
SOURCE: external HD won't mount
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Posted on Sep 29, 2010
  • 11 Answers
SOURCE: I have an Iomega 500gb Minimax Desktop, and need a
Posted on Feb 28, 2011
My d-link DAP-1320 connects to my wireless airport extreme but not internet
Mar 14, 2014 | D-Link DAP-1320 Wireless Range Extender
Is too short for her MacBook Pro. -Thanks.
I would recommend purchasing a newer router that is more powerful. The Apple Airport Extreme is a fantastic router. If none of these choices work then you can either connect your Macbook via ethernet or move it closer to your router. here is the Apple Airport Extreme.
Dec 19, 2010 | Linksys WRT54G Wireless-G 802.11g...
Apple Macbook Pro does not connect to wireless network
The antennas in the Macbook Pros have had an issue with reception due to the aluminum housing of the laptop but, should still receive decent reception just not as much as a plastic Macbook or plastic PC laptop. It could be possible that the antenna's cables have become disconnected from the Airport Extreme card inside your Macbook Pro, that the card itself is faulty or damaged or that the Antennas themselves have been damaged in some way. As always make sure you have the latest updates and have installed any driver updates from Apple regarding your Airport Extreme card. Here's an article that may help eliminate any wireless interference that may be affecting your signal strength. Apple - Wireless Interference hope this helps, if so don't forget to comment, vote, etc. Thank you.
May 28, 2010 | Apple MacBook Mac Notebook
I f I connect hotel internet via Apple USB 2.0 Ethernet Adapter to my MacBook Air, internet after few minutes disconnected, to connect again i take out the cable, and then plug in, usually internet start...
Try turning off Airport. Your computer may be finding a wireless network and automatically switching to it, and getting an intermittent signal. Just a guess, but for a good ethernet connection you want to disable the Airport searching feature anyway.
Open the System Preferences application, select "Network" and right on the top left of the resulting window there's a pretty big button that will either say "Turn Airport On" or "Turn Airport Off" - just turn it off if it's not already ...
Hope this helps!
For help with Public Address Systems see my new How To Video, available as a DVD at
Feb 15, 2010 | Apple USB 2.0 Ethernet Adapter for MacBook...
Airport extreme / Windows XP with VPN problem
have you reset the airport extreme? theres a tiny hole you can push in w a paperclip. Also, do you have the latest firmware?
Mar 10, 2009 | Apple AirPort Extreme Router
Macbook Pro airport extreme
You should only use Windows xp for running a program that is not yet available from Apple. There shouldn't be much reason to link to the net while in Windows. Also while in Windows you are wide open to any viruses that exist. Try getting your work done without getting on the net, then go back to your Apple format. There you are 99% free of viruses. … Still need to link onto the net let me know I will ask at our Apple Computer Club on Monday
May 10, 2008 | Apple MacBook Pro Laptop Computer with...
Can't print to mac wirelessly (could do it a few days ago)
I had the same problem until recently. You have to install the drivers FROM THE CD that came with the printer, instead of selecting the drivers from the default list. Then, when selecting which printer driver to use (you'll have two options) choose Canon IJ and NOT Canon MX310 series. This is a problem with their MX310 driver, which is solved using a default/generic Canon InkJet (hence, the IJ) driver. Hope this helps!
P.S. This only works on Mac OS X. I have yet to figure out how to print wirelessly through Vista. Will keep you posted.
Mar 28, 2008 | Canon PIXMA MX310 All-In-One Printer
Iomega MiniMax (33464) 250 GB Hard Drive Logo
61 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
