Question about Dell PowerEdge 1800 Server
Hola, como silenciar alarma de PowerEdge 1800? Saludos
3 Suggested Answers
  • 13433 Answers
SOURCE: Poweredge 1800 server
Hey,
I looked over the spesifications for the poweredge 1800 servers, go ahead, it will work perfectly but there is one problem in the windows XP setup, you will need to insert / load SCSI or SATA drivers for the hard drive With a floppy disk, or if you don't have a floppy drive your going to need to create a custom windows xp setup cd and add the drivers into it so it can start the SCSI or SATA hard drive and finish the install. without the drivers it might not find the hard drive.
Aside from that I don't see any other problems. You should be able to get the drivers, and everything ese from dell site
http://support.dell.com/support/downloads/
Actually I looked over the dell downloads, I see only windows 2000 on the list with windows server 2003, and 2008 and linux distributions.
This could be a 2nd problem, drivers might not be avaialble, or work with xp, but we might be able to get it to work.
So two problems, SCSI or SATA drivers in windows xp / windows 2000 setup
2nd problem is in windows xp drivers, you could try windows 2003's drivers and 2000's and see if they work, if not, then we would have to look for drivers ourselfs from the internet.
So xp might cause headache but we might get it working, windows 2000 seems to be supported perfectly.
Let me know how the project goes
Thanks,
Ekse
Posted on Jun 03, 2009
  • 110 Answers
SOURCE: hello, my dell poweredge 1800 does not see up than
Check the RAM frequency of the RAM which should be compatible to the main board. also chk for the other RAM frequency also
Posted on Nov 20, 2009
COMO DESCARGO LOS DRIVER DE LA PLACA E241819
Hola.
Cual es la marca de la placa? El modelo no aparece en las listas de Intel.
Saludos, espero tu respuesta para ayudarte.
Aug 29, 2011 | Intel Motherboard
Tip
Hola amigo saludos de una hispano sin duda tu post uno de los mejores explicado...
Sorry, FixYa seems to have made it impossible for the novice internet user (such as myself) to alter or edit my tips to my satisfaction so I have removed it. Sorry for any inconveniences.
Hope you will find what need elsewhere.
Macmarkus :)
on May 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hola, resulta que estoy intentanto instalar un nuevo sistema operativo en la dell power edge 1800, pero no he podido porque la dell no arranca desde el cd. Entre en la bios y en la secuencia de booteo no...
Install another cd unit that is recognized by bios so you can install the software. Without that you can do nada!
If another known good player is used and it also is not recognized then you have an issue with your CMOS - not a good thing!!!!!!!!!!!!!!!
Sep 09, 2017 | Dell PowerEdge 1800 Server
Mi alarma esta muy sensible, con cualquier ruido, como le hago para bajarle de intensidad?
Hola, debes buscar el sensor de impacto, normalmente lo instalan en el area inferior del volante o timon, es modulo que usualmente esta conectado al modulo de alarma por tres cables, tiene un indicador LED y un control de sensibilidad que se ajusta con un desarmador plano pequenio.
Mar 09, 2011 | Car Audio & Video
Saludos tengo un recibidor 311 y se me dano mi control 3.2 ir y compre uno 21.0 ir/uhf y no se como programarlo
Hola mi nombre es Kimberly Escobar con DISH Network, tengo entendido que su control 3.2 esta danado y por esa razon compro un control 21.0. Siento decirle wue este nuevo control solamente es disenado para funcionar con nuestros recividores VIP HD. Necesita un control 3.2 para que funcione su recibidor. Nos puede llamar directamente al 1800-333-DISH y podemos ver su cuenta, si usted tiene el plan de proteccion en su cuenta el control se puede reemplazar gratis. Gracias y esperamos oir de usted pronto.
Feb 22, 2011 | DISH Network IR Remote Control
Ocupo los drivers para mi MSI 6580 no tengo audio ni video mi pc es una pentium 4 de 1.7 el procesador
Hola, saludos, verificando tu informacion, leo que el modelo MSI 6580 tambi?n se conoce como 845PE, y de acuerdo con esto, te envio el link de descarga de la pagina del manual y los drivers, saludos...
http://www.msi.com/service/search/#/?kw=6580&type=download
Saludos desde Venezuela...
Jan 07, 2011 | Computers & Internet
Acaban de componer mi camioneta (pontiac montana sv6 1999) porque los buzos hidraulicos estaban pegados y no pasaban aceite (le pusieron nuevos), al siguiente dia de uso empezo a fallar la aguja del...
hola ayuda por favor. tengo una pontiac montana 97 y la falla es que en ocasiones da marcha pero no enciende a la primera. hace como que arranca pero se apaga. pero si acelero un poco al dar marcha si arranca y ya se mantiene normal. que sera. gracias. saludos
Nov 19, 2010 | 1999 Pontiac Montana
Como desactivar manualmente alarma toyota corolla 2006
como puedo desactivar la alarma de un corolla 2005...se me quedaron las llaves adentrooooo
Oct 14, 2010 | 2006 Toyota Corolla
Se activo alarama dogde grand caravan 98 3.3l y no tengo control
Hola estoy intentando siguir su problema. esta es hora punta y tenemos muchas preguntas.
Asegurarse que no hay otra alarma que no es de fabrica. En este caso deberia de haber otro modulo de control de alarma. Alarmas no de fabrica suelen tener un boton de deactivaccion (Valet Key) debajo de la console de instrumentos.
Si el pin 34 esta libre, el alarma deberia ser inactivo. Probabilmente se activo' cuando hizo los trabajos en el coche.
Uno de los pins connectados al ~BCM es el alarma.
La unica manera de deactivar este alarma es enviar un impulso al pin del alarma, descargandolo a terra.
Hay que poner una resistencia de 9KOhm en el medio , de otra forma el alarma no se deactiva.
Aqui la esplicaccion:
"Factory Alarm Disarm Wire (-): This vehicle will disarm with (-) negative through a 9000 ohm resistor, must use single pulse to disarm and a double pulse on this wire will also unlock.
Factory Alarm Disarm Wire Location: N/A"
La esplicacion termina con "Factory Alarm Disarm Wire Location: N/A", sin decir qual pin es el alarma.
yo se de otras fuentes que deveria de ser el pin 34. Por esperiencia personal puedo decir que el connector deveria de estar conectado all bloque de aranque.
El hilo deve de ser blanco y rojo o bien violeto y azul.
Si no se pone una resistencia de 9Kohms en el pin apropiado, el alarma no se quita.
No hay otra manera.
Nov 06, 2009 | 1998 Dodge Grand Caravan
Dell PowerEdge 1800 Server Logo
107 people viewed this question
Alun Cox
