Question about TallyGenicom 2280 Matrix Printer
I have a problem with 2280+ tallygencom printer. I have hardware alarm problem and with sense code +0001 +131 --- 000002 +2733 -0962 . Please help me . Thanks
    Novelist:
  • 169 Answers
The hardware alarm indicated is indicating a problem with print head movement.
This error can be indicated if there is any thing which may be preventing print head movement, things you can check include;
1)The printer ribbon is not jammed and is located correctly in the printer,
2)You can also check to ensure there is no paper jam of loose paper which may prevent print head movement,
3)You can also check the carriage shaft to ensure it is free from paper dust or any other obstructions.
4)Also clean the thin transparent timing strip next to the carriage shaft.
5)With the printer powered off, the print head should slide freely across the width of the printer, you can then see if there is any obstruction to the print head.
Posted on Jun 06, 2011
Hardware alarm -4045 +131
That error means the that Printhead is not where the printer expected it to be. Clean the emitter grid (under the Printhead) with a soft cloth and clean the sensor with canned air. If that does not clear it up it is normally the Main Board Assembly.
There is a T2280 and a T2280+ they take different Main Boards so make sure you get the right one.
T2280 MRP provides IT Parts Product Supplies and Services
T2280+ MRP provides IT Parts Product Supplies and Services
Aug 13, 2015 | Genicom Tally 2280-2t Dot Matrix Printer...
Hardware Alarm Wrong Board tally 2280
Hi Denis,you are having wrong board tally because you fixed the wrong part.pls check the part number and get a new one and fix it back.
Apr 11, 2014 | Tally Matrix T2280 Printer
TALLY GENICOM 2280+ HARWARE ALARM CODE +0016 +131
Unfortunatly not enough of the Hardware Alarm Task Number is included in the description to identify the most likely cause of the problem but some things you can check are;
  • Remove the ribbon from the printer, ensure this is not jammed or damaged
  • Power the printer OFF and try manually sliding the print head from side to side, look out for any objects which may obstruct the movement of the print head (pen lids etc!)
  • Ensure the print head gap is not set to close to the paper, thus jamming the print head
  • Remove the paper to ensure the paper is not restricting print head movement.
  • Clean the Optical Timing Strip that runs under the print head, ensure this is not damaged also.
  • Clean the carriage shaft, this should be FREE from any lubricants WD40 etc and dry running. Remove build up of paper dust etc.
  • Dec 06, 2010 | TallyGenicom 2280 Matrix Printer
    Our tally 2280 Dot matrix has an alarm code 025609413032 What causes this to be displayed on the 2280 screen.?
    check out this FAQ page for the hardware alarm codes:
    http://support.dascomeurope.com/index.php?option=com_content&view=article&id=295%3Ahardware-alarms&catid=234%3Afaqs-t2265-t2280&Itemid=57&lang=en
    Mar 19, 2010 | TallyGenicom 2280 Matrix Printer
    I have an error message on my 2280+ Serial Printer that says ''Hardware Alarm'' Could you be as kind as to help me with this one please?
    The 2280+ will normally display two lines of numbers when it displays a Hardware Alarm error. These numbers give a better idea of what might be causing the problem.
    Some things you might want to try are;
    1. Power the printer off, and remove the ribbon from the printer. Try sliding the print head from side to side. The print head should be free to move when the printer is powered off. In doing this you can check for any instructions which may be stopping the print head moving.
    2. Check the ribbon cartridge, ensure the ribbon cartridge is not jammed, twisted or damaged. Perhaps try powering the printer on with no ribbon and try printing to identify if the ribbon may be causing the problem.
    3. Clean the Timing Strip and Carriage shaft.
    The Carriage Shaft is the metal shaft that runs the width across the printer. This is the shaft the print head slides across.
    The carriage shaft should be clean and free from any type of lubricant. I would recommend cleaning this shaft and any build up of paper dust or other dirt on the carriage shaft this can cause problems with print head movement. If the carriage shaft has any lubricant I would recommend cleaning this lubricant off the carriage shaft.
    The Timing strip is a thin plastic strip that runs across the printer just next to the carriage shaft. I would recommend cleaning the Timing Strip with a dry cloth to remove any dirt or dust. The printer uses the timing strip to monitor the position of the print head. If the timing strip is dirty or dusty this can prevent the printer detecting the position of the print head and will cause this type of error.
    Other than that you may need to see what other errors are being seen on the pritner.
    Nov 03, 2009 | TallyGenicom 2280 Matrix Printer
    I have a TallyGenicom 2265+ printer with a Hardware Alarm
    Please try if a reset to default settings is solving the problem. To do this press and hold all 4 keys below the display while turning on the printer.
    You may also check whether you have the latest firmware installed on your printer @ www.dascom.com
    Oct 08, 2009 | TallyGenicom 2265+ Matrix Printer
    Tally 2280 printer givesw printhead hot error
    Is it a + version, with an Ethernet board included? These were known to cause such errors, seamingly not related at all. Try replacing the Ethernet board, or at least pull t out and disable to try.
    Feb 14, 2009 | TallyGenicom 2280 Matrix Printer
    Tally printer hardware alarm home postion
    There is a broken gear(s) in its mechanism that's why you are having this hardware alarm message.
    Dec 07, 2008 | Tally T2250 Matrix Printer
    Tally sprint pro
    Please tell me the hardware alarm number . The number will display onthe control pannel LCD of your printer. Then only I can help you.
    Aug 26, 2008 | Tally Matrix T2280 Printer
    T 2250
    tally t 2250 give hardware alam
    code +03211 ne -007000 000000 128+0304
    Jan 19, 2008 | Tally T2250 Matrix Printer
    TallyGenicom 2280 Matrix Printer Logo
    339 people viewed this question
    Top TallyGenicom Office Equipment & Supplies Experts
    Kolbrun...
    Raj Patel
    Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
