Question about Samsung CLX 3160fn All-In-One Printer
My problem is the message on the printer: Internal Error Power Off/On e59ff0542T932ImT1 Please help me.
    Scholar:
  • 111 Answers
This can be a lot of malfunction, but try first to disconnect the printer from power for 10 minutes, then try, if this does not help open and close the front and rear cover to assure that the sensors are in function to print, last you can do deinstallate the drivers from your computer reboot it and installate them from the samsung CD new then reboot again and try, hope it work
Posted on May 18, 2011
My hp2840 scanner not working display message : scanner error 3 turn off and on please advice
Scanner Error
The device has experienced an internal hardware error.
  • Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.If the error persists, replace the scanning assembly.
Jul 09, 2011 | HP LaserJet 2840 Printer
Sir, i have hp laserjet colour printer CP5225, having error 55.0601. Kindly give me online solution
this all i manage to find for hope it helps
55.x Error
Error Message
55.X Error
Turn off then on
Description
The printer has experienced an internal error. The printer may experience one of the following errors:
55.0 DC controller communication error
55.0601 DC controller NVRAM data error
55.0602 DC controller NVRAM access error
55.1 DC controller memory error
Action
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the printer to initialize.
If a surge protector is used, remove it. Plug the printer directly into the wall socket. Use the power switch to turn on the printer.
If the message persists, contact HP support.
You need to first check the connection between the dc controller and the formatter and if the connection is fine you need to replace the dc controller.
Dec 22, 2010 | Office Equipment & Supplies
My HP Photosmart D-7160 keeps advising me that the yellow cartridge is empty even though I just replaced it. Any ideas?
Note that illustrated instruction some of the following can be found at:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00692953&cc=ca&lc=en&dlc=en&product=1156652&tmp_track_link=ot_search
Step one: Reset the printer
CAUTION: Do NOT perform any other type of reset on the printer before the ink initialization process has been completed.
1. Without turning the power off, remove the power cord from the back of the printer and from the wall socket.
2. Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.
3. Check the printer for the error message. If the error message still displays, go to the next step.
Step two: Clean the cartridge contacts
Lift the top cover.
Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch and then lift the latch.
Remove the cartridge indicated in the error message.
Gather the following cleaning materials:
Distilled, filtered, or bottled water. Do not use tap water, alcohol, or platen cleaners.
Lint-free cloth or swab. Eyeglass wipes and coffee filters work well.
Lightly moisten the swab or cloth and squeeze out the excess moisture.
Holding the cartridge by its handle, wipe the copper contacts.
Replace the cartridge and then close the latch and the printer top cover.
Check the printer for the error message. If the error message continues, go to the next step.
NOTE: The printer might take up to 15 seconds to clear the error and recognize the cartridge after closing the cover.
Step three: Replace the cartridge
If the error message continuess, replace the indicated cartridge with a new cartridge.
You might also want to perform the built-in internal tests to verify that the printer internal firmware is functioning properly.
NOTE: The tests do not verify that the computer and printer connections are working properly.
It is always preferable to perform all these tests when the communication cable has been disconnected from the printer, and after having turned off and on the printer.
1. Make sure plain paper is loaded in the In Tray.
2. Press and hold the Power button.
3. Press the Resume button four times.
4. Release the Power button.
Trust the above helps resolve your problem. Please vote. :)
Dec 20, 2010 | HP Office Equipment & Supplies
Samsung SCX-5530FN internal error power on/off
It is not possible to scan to email anymore. Also the copier makes noise when copying and the result is blurred and illegible.
Jan 22, 2009 | Samsung SCX-5530FN All-In-One Laser...
Laserjet Printer
if it seems like it wants to take the paper in on the first print but don't and then gives you the error message , then the paper feeder will need to be cleaned ( rubber grabing wheels)
if the error message comes on before it trys to grab paper , then there is an internal problem with the printer
if this helps you then please give a fixya rating and i will tell you how to clean the paper feeder rollers
electech
Nov 07, 2008 | HP LaserJet 1320 Printer
Ink system has failed. unable to print. error 0xc18a0206
I find a solution 6180
unplug power cable
press 9 and # on keyboard
replug power cable with buttons pressed
the error must disapear
change the print cartridge indicated they became bad ( why ?)
reset is done you must reput language and network ip adress
Philippe GERARD
Jul 03, 2008 | Office Equipment & Supplies
INTERNAL ERROR--FALSE
My printer was able to print an "INTERNAL ERROR - FALSE, Position: 0x1227e (74366)" error message as well as a test page, but not documents sent to print.
However, the problem was fixed once I switched to another USB port as the person above mentioned. So for any other people with similar problems, try that! In addition to power cycling the printer (I did that first)
Jan 23, 2008 | Samsung ML 2010 Laser Printer
Internal Error DRAM-FUNC.c 58 R
Under warranty ring samsung to confirm, the error relates to comunication with the ram chip, probally not seated, but I think you might find in has a "in house" warranty which means they will come to you.
Dec 22, 2007 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3160fn All-In-One Printer Logo
49 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
