Question about Locks & Locksmithing
I have fitted a door knob to bedroom door. This lock has a key. The problem is that I cannot lock the door and go out as it does not lock. The key seems to release the latch when the knob is depressed but will not lock the door
  • 10,865 Answers
Hello joan. check to be sure that the door properly latches when it opens and closes with out locking it at all. sometimes the latch does not easily and freely go into the latch hole as the latch hole needs to be adjusted. joe
Posted on May 18, 2011
Kwikset lockset does not lock
The shaft for the lock fits in the knob. The lock on the knob might be 90 or 180 degrees out of rotation. Please remove the know and twist the lock 1/4 turn and put it back together. Also you may need to reset the location with a key and when the lock knob is off, turn the lock set with the key, then turn it and replace the knob.
Mar 01, 2018 | Kwikset Locks & Locksmithing
Our schlage lock with thumbturn on inside and keyed on outside. When unlock inside, knob turns freely as if it is really unlocked but if I close door, I get locked out. Please help
Be sure the outside knob is unlocked before closing the door.
Schlage locks do not lock the inside knob or lever. After releasing the turn button, also turn the inside lever or knob, then check the outside knob.
What model of lock is this?
Apr 09, 2014 | Locks & Locksmithing
Door knob replacement
On the inside side of the door knob you should be able to use a screwdriver to remove the finish covering against the door. This should get you to a point where you can release everything.
Nov 14, 2013 | Kwikset Locks & Locksmithing
The lock got flipped on the bedroom door. I am now locked out. The door knob has been removed but I cannot get the mechanism inside the door unlocked. How can I do this?
You are almost there. Take the knob containing the spindle and insert into the latch mechanism. Twist it and the lock button will pop out. Open the door. Put everything back together. NOTE: I just confirmed this using a lock mechanism in front of me as I answered this.
Nov 09, 2013 | Hardware & Accessories
How do i break into a locked bedroom door?
look for a small whole like screw whole twisting it around should open it did it before allot of times.
Oct 05, 2013 | Locks & Locksmithing
I locked my bedroom door with my keys in the room
Look closely at the door knob and you will see a very small hole in the middle of the door knob. Use a piece of stiff metal such as a heavy paper clip straightened out and push it into that hole. that will unlock the door to your bedroom if you have a normal bedroom door lock.
Mar 25, 2011 | Garden
Broken door knob. no access to hinges, screws. Rental property!
Take apart a similar doorknob in your house. Use the stem with knob on it and insert into the square hole in the lock--turn!
Feb 27, 2010 | Hardware & Accessories
My knob has fallen off
sounds like the lockset has come apart in a way that it was not intended... normally you need to push a small spring loaded pin on the knob shaft in to remobe the knob, then a finished trim plate snaps off revealing the plate that gets tightened down to the face of the door... after tightening you snap the trim plate back on then the knob snaps on while pushing the pin in...
if it's a standard bedroom unkeyed lock then the plate and knob are one piece and the screws are exposed thru 2 holes on the inside knob...
Sep 02, 2009 | Kwikset Professional Door Lock...
Stuck Door Knob with No Access!
I agree with your Hacksaw method. Very easy and very fast. You are going to want to replace the knob anyway so this does not happen again. Just Hacksaw that knob as close to the door as you can without damaging the door. From there you are on your way to access to the parts of the lock. Now you can replace that knob and never have this trouble again!!!! One less headache in Life......Hope this helps you ........Joe
Jan 10, 2009 | Hardware & Accessories
Locks & Locksmithing Logo
94 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
