Question about Canon imageCLASS MF4150 All-In-One Laser Printer
Black lines Hi. My canon mf4150 is displaying a black line down the margin of documents, but only when I use the feeder. When I print or copy using the glass, its fine. Also, I just put in a new toner and it is still giving me the warning that it is out and the light won't shut off. Also, when it runs out of paper, I have to unplug it before it will register that I put the paper in. Help!
  • washingtonco Aug 14, 2008
    Awesome! That thing was really dirty! How about the toner issue and the paper issue? Any thoughts?
  • Canon Master
  • 2,794 Answers
There is a small strip of glass that the document feeder uses. Once you clean off the section, the lines will go away. Even a tiny speck will cause that to happen.
Posted on Aug 14, 2008
SOURCE:
Black lines on copy only when printing but copying is ok i.e km 1650
If this only occurs when using the document feeder then you will need to clean the smaller glass that sits next to the large glass that you manualy place your documents. The document feeder scans the originals over the small glass and any ink ,whiteout that may be on the glass will appear as lines down the pages
Oct 24, 2013 | Kyocera Mita Office Equipment & Supplies
Vertical Black Line
Probably there is nothing wrong with that scanner, just open and clean document feder with alcohol or glass cleaner.
Mar 29, 2013 | Canon PIXMA MX870 Wireless Office...
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
My Canon MF4150 multifunction device started displaying streaks (or black vertical lines) on pages scanned via the ADF. These streaks appear when scanning from Windows 7 (64bit home premium) as well as...
Hello I just figuered out this problem. When the paper is feed thru the ADF ( Automatic Document Feeder ) there is a plastic piece with a plastic film. Check to see if #1 that plastic film is clean and #2 That the Film is not bent and created a crease which is the line that shows when try to print or scan using the ADF. Hope this helps
Dec 28, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
My Canon ImageRUNNER 3225 does not print correctly aligned when sent through the feeder? When feeding paper, I have tried Landscape and the resulting copy is cut off from the top and bottom and the left...
Is it ok when you just put the document on the glass? If so, the Document feeder needs a whole set of rollers.
Otherwise the document scanner may be bad. This needs to be changed out by a technician.
Whit
Item, Inc
Sep 15, 2010 | Canon imageRUNNER 3225 Black and White...
When making a copy on our Canon copier (super G3; image class MF4150) we are getting a vertical black line down the entire length of the paper. Is there something we can do to fix it? SG
You can fix this yourself by cleaning the scanner glass. When you insert a document to make a copy it is pulled in and travels over a thin strip of glass. When something gets stuck on this glass it is read or scanned as a solid line. What you need to do is make a copy. Then put that copy in the feeder the same way you put the original document in. Now the line on the copy will "line up" with the area of the glass that has something stuck to it. Use this as a guide to pop open the feeder cover, locate the glass and clean it with a cloth dampened with a bit of glass cleaner. Once you have it cleaned just run a copy again and the line should be gone. Sometimes a small flashlight helps to locate the glass.
Good Luck and Thank You for using Fixya.
Sep 02, 2010 | Office Equipment & Supplies
Black lines down on printed page
This is caused by dirt/debrise on the ADF (automatic document feeder) scanner glass. You need to open up the feeder where your originals are fed in and look for a strip of glass that runs from front to back. It is about an inch or so wide. You need to clean this glass to get rid of the lines. Some models have this glass just to the left of the large main glass, but in your case I beleive it is in the feeder itself.
Good Luck.
Apr 23, 2010 | Brother MFC-7820N Printer
Copying with page feed results in a vertical line on every page
There must be a strip of glass about one inch wide, next to
the large glass. There is the problem !
Clean that strip thourougly. When you use the feeder the pages
are scanned thru the small strip of glass.
Mar 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Black Line Down Center of Page
I had the same problem. I cleaned the strip above the glass and this fixed the problem. Hope it helps!
Feb 14, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
379 people viewed this question
Clive
Clive
old marine
old marine
Ekse
