Question about JBL GT5A604 Car Amp
When i start the amp the red light is on constantly and green light bilnks what would be problem, i changed the power supply ic 494 but the problem sitt accurs
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
No picture or sound with a red flashing power light. Have replaced the convergence IC's but no change (do not have the chirpint sound). Removed main power board & green LED does not light up
On that model the conv IC is usually not the solution. I believe its the blown capacitor problem with is an easy fix. Check the site www.TvRepairKits.com for a repair kit.
Apr 11, 2012 | Hitachi 53UWX10B 53" Rear Projection...
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light position...
tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light
Aug 30, 2011 | Sharp 21" Multi System Stereo TV
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to ...
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light position ,please to help of rectivied this problem and send circuit diagram and IC pin configaration thanking you sir
Mar 03, 2011 | Televison & Video
The red lightcomes on when i hook up things to it when nothin is hooked up its green
Usually, this indicates an overload condition. I have a Pyramid 35 amp supply that has no green light but uit does have a red light and an irritating little beeper that the instruction book says is activiated when power draw approaches 90% of rated output. (Why not call it a 30 amp supply if you can't use the full 35???) Enough editorializing. You don't say if the supply actually works, just that the light changes color. If it doesn't work at all, I would start with checking the diode bridge for a blown or leaking diode. If one is bad, it can output enough to drive an LED but fail anything else. If these are good, check the filter capacitor. If this is bad, the hum could concievably confuse the regulator circuit. Next, I would check what ever voltage regulator it has in it. I can't comment on specifics as there are many schemes that can be used. My unit, for example, is like a mouse driving an elephant. It has a small 723 regulator IC, (Aprox. 100ma output), controling 4 large TO-3 pass transistors driven by a 36 volt 40 amp transformer to boil it all down to an adjustable 12 to 15 volts.
The bottom line is without knowing if the unit is puting out or not and not having it in my hand to look at, this is the best I can do. I hope it helps.
Good luck.
Jeff
Feb 03, 2011 | Pyramid 10 Amp Power Supply (068888701655)...
Nec pf-68v21 pwr led flashing red green after horizontal output
check the supply at horizontal driver trans former ,if voltage is correct at ho/driver trasistor ...then check allthe fusible resistances from power supply,,,if tv is taking h/oscillation for awhile ,,give more screen control in lot,,, & see for a horizontal line ,,,before tv becomes off,,, if so vertical ic problem...
Mar 16, 2010 | Televison & Video
I have a 60sdx88ba and will not power on
First I would check to see if you may have shorted the STK ICs pins when you soldered them in. There may be more than one short, so check them carefully.
Next I would check to see if that circuit uses ant fuses or pico fuses on the supply lines to those ICs.
Good luck.
Dec 01, 2009 | Hitachi Televison & Video
I have onida dvd modal no. is dfx-2000. it having
Plz change ur dvd player bcz it was 2 old
Jul 18, 2009 | Televison & Video
Green standby/power light bilnks and pic goes out
you have defective power supply! at the hot side section!
Oct 08, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
JBL GT5A604 Car Amp Logo
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
