Unlimited MoneyOnce
you have the Zen Garden, water the plants until they don't need
anything else. After that, change the Date on your PC to another day. As
soon as you do, the plants will need water again. Repeat this -- buy
new plants, grow them to full size, sell and repeat to earn money.
This also works to get Marigolds in Crazy Dave's shop when they are
out of stock. You can fill up your Zen Garden and make all the money you
need. You don't even have to close out of the game.
CostumesEnter these codes with your keyboard during gameplay for the desired effect:
Milking Walnut Bowling for coinsHere's how to make Walnut Bowling more profitable:
1) Protect the Lawnmowers -- Each Mower is worth one gold coin ($250).
2) Line up shots off the front runner. After the first zombie is hit, each additional zombie strike generates coins.
3) Create a front runner where none exists! Pole vaulting zombies run
fast until they vault over a nut, and the newspaper zombie runs fast
after getting the paper destroyed by a nut. Just let them run a little
bit down the lawn before sending a nut their way.
4) Just because you have nuts does not mean you have to use them.
This is where "Nerves of Steel" comes into play. When there are a few
zombies ambling down the lawn without a clear ricochet shot, wait a
little bit to see if more of their friends will step out to play. They
can always be killed once they cross the red line.
5) Remember how many nuts it takes to kill a zombie; this is
important when the cross the red line. Use one nut for regular zombies,
three for bucket wearing zombies, and two for the rest.
6) Reserve the exploding nuts. Try not to use those nuts unless a mob
crosses the line, or there are not enough nuts or room to clear out a
hard to kill zombie. Use the regular walnuts for the zombies that have
not reached the red line.
7) Don't use exploding nuts to kill pole vaulting zombies directly.
Pole vaulting zombies only jump obstacles in their own lane. A pole
vaulting zombie who has not vaulted yet will safely jump over explosions
or nuts in their own lane; so find a neighbor in the next lane and time
the nut to hit when the pole vaulting zombie gets close to the
neighbor.
Play Slot Machine for Extra Coins and Diamonds1)
Set up your defenses around the slot machine. Try for one row of
wallnuts on the right side, one or two rows of sunflowers on the left,
and fill everything else with pea and snow pea shooters.
2) Protect the lawn mowers. Each are worth a Gold Coin at the end of the game, so don't let them mow the zombies.
3) Stop collecting sun around 1900 sun points. At this point, the
garden should be full, so getting the extra 100 points to win should be
easy. Just collect enough sun to offset the slot machine.
4) Keep the slot machine spinning! It will randomly drop one or three gems as long the patience lasts.
5) If the Zombies get close to the mowers, end the game. Just collect the sun lying on the field to end the game.
Switch Locked SeedsTired of being stuck with the crappy cards Crazy Dave
makes you have? All you have to do is exit the game and
restart it and the 3 cards will be changed to something
else.
