Question about LG Washing Machines
Lg di dvr 9kg does not spin.ser no f1403fd[oe comes up in window,to stop program]what should i do.
    Guru:
  • 500 Answers
Hi cheyrlsouthw,
OE error is Outlet Error. You will need to clean the Pump Filter, as it is most likely clogged by a foreign object. Check your Manual for instructions on how to do this.
Kind Regards
If you found this solution helpful, please rate accordingly :-)
Posted on May 18, 2011
LG WM1355HW Washer will not start. No power at all. I've check all the power sources coming to the washer and there is power to it.
try this service manual:
http://www.manualslib.com/manual/687992/Lg-F1403fd-5.html?page=20#manual
Sep 07, 2016 | LG Washing Machines
Front loader will not spin
oe code is pump blocked, but because you have cleaned it, make sure the pipe from pump is not blocked
Feb 04, 2012 | LG Washing Machines
Lg inverter 9kg f1403fd. keeps stopping @ OE on dislay even with no load. Tilt switch or computer ?
Neither! LG's OE' stands for '(water) Outlet Error'. It cannot drain properly.
(following is pre-typed as it is a common problem and I cannot type fast!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 19, 2011 | LG Washing Machines
My LG washer keeps stopping during spin with the display OE.
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Oct 21, 2010 | LG WM2101H Front Load Washer
Shows OE error. Won't spin
if its only 6ths old call out the manufactures.
Sep 28, 2009 | LG WM-2277HW Front Load Washer
LG washing machine keeps stopping and it says OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Apr 11, 2009 | LG WM2042 Front Load Washer
Washing Machines Logo
125 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
