Question about Alpine PXA-H700 Car Video Player
Hi Sir, I need help about my alpine pxa h700. After done doing all the audio setting then I save to preset 1 (also try another preset 2 to 6). My problem is that when I recall or loading my preset, the front 1 right gain always back to 0 (My setting is -8). How to solve my problem? Thank You....waiting for the answer. Regards, Hartono
  • hartonokhoe May 18, 2011
    My defeat is off. When I recall memory The others setting are fine only for the front 1 right gain always back to 0. Is it because the IC memory...Could u provide what part should I replace? Ths
    Top Expert:
  • Alpine Master
  • 74,136 Answers
Hello
Make sure that the Defeat Mode is OFF when you save the settings to a memory position. If you have done this after Defeat mode is in OFF position, and still it does not memorize the settings, the memory IC inside the ciruit board of your Alpine is faulty, and should be replaced. OK.
Posted on May 18, 2011
  • The Knight
    The Knight May 18, 2011
    It is due to Memory IC fault itself. This is a small IC, haveing 8 solder terminals, can be located very near to the main system control IC at the fron panel board of your set. Normally this IC is be an SMD [Surface mount Device], and cannot be replaced by normal resoldering and soldering methods. Hot blower type surface mount desoldering machine is required. So it is not self reparable I should say. The IC is cheap to buy, but its mounting is difficult. you have to disassemble the front part as a whole to finish the work. OK.
Want to buy Alpine RUX-C701
put a add on craigs list in the free iteams.
Jan 20, 2013 | Alpine RUX-C701 Controller for PXA-H701...
Hi, can I test a PXA-H701 and RUX-C701 without a head unit by just connecting the power harness just to a 12V car battery ? Thank you Robin
Yes, take the power (red wire) and the accessory (yellow wire) and put them on the positive, and the ground (black wire) on the negative.
Jun 06, 2011 | Alpine RUX-C701 Controller for PXA-H701...
How do you set stations and clock
1.Select the radio band and tune in a desired radio station you wish to store in the preset memory.
2 .Press and hold any one of the Preset buttons (1 through 6) for at least 2 seconds until the station frequency on the display blinks.
3. Press the Preset button into which you wish to store the station while the frequency display is blinking (within 5 seconds). The display stops blinking once the station has been memorized. The display shows the band, preset No. with a triangle (9) and station frequency memorized
http://vault.alpine-usa.com/products/documents/OM_CDM-7854.PDF is link to full manual
Mar 03, 2011 | Alpine CDE-7853
How do you set the radio stations on a alpine CDa-9855
go to a station you wish to save, then choose a preset number from 1 to 6. press that button for 3 to 5 seconds. the station should be locked into that preset number.
Dec 13, 2010 | Alpine CD Player CDA-9855 LIMITED QUANTITY...
Radio code for my ford fiesta
Your Code is : 1 6 4 8
Ford  Code Entry Instructions
Once the unit has been turned on the display will show ' CODE - - - -'
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ 5 ] key to accept.
The set should now operate.
Mar 06, 2010 | Alpine Car Audio & Video
PXA-H700 optimum set up...
The way the EQ is hooked up is correct.
You set the factory radio to a set level, then use the volume on the EQ for everyday adjustments.
I believe your problem lies in the amplification.
Your BOSE amplifier was made to run a 4 channel 8ohm stero load.
Low powered - high in sound quality.
You have swapped the factory 8 ohm speakers (15W) for 4 ohm power hungry ones.
Now the amplifier is working harder to produce the same output.
You would be best served eliminating the factory amplifier and getting 1 good 4 or 5 channel amp to power your speakers.
a 4 channel amplifier could be used stereo (left and right) on channels 1 and 2, (2ohm stereo load)
and bridge channels 3 and 4 for your subwoofer.
For a true surround sound - a 5 channel amplifier could run each speaker individually, and the 5th channel is reserved for the subwoofer.
a small dedicated 75wx4 channel amplifier with built in crossover, and level gain controls - would blow your socks off. It is 200x better than the factory 12Watt amplifier. Your ears will love you for it :D
If you need more help - just let me know.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 23, 2009 | Alpine PXA-H700 Car Video Player
How do I preset the stations for an Alpine TDA-7547 car Stereo. This is an older stereo and setting the stations is not intuitive.
Select the station you want. Then hold down one of the 6 preset buttons for a couple seconds. When the station ID flashes, release the button and it should be saved.
Dec 06, 2008 | Alpine TDA-7547
Alpine PXA-H700 Car Video Player Logo
42 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
