Question about Ricoh Aficio 1515MF All-In-One Laser Printer
I dont know how to install the printer ricoh 1515f and what is its defoult ip adress?
    Genius:
  • 1,127 Answers
Hi
Download the manual and read, this is very easy to configure, for manual please click hear u get all manual, chose which one you want..
If u have any problem to installation or configuration, feel free contact me prashantbsharma84@gmail.com
Posted on May 18, 2011
    New Friend:
  • 31 Answers
Hi there! Helder Lameira is right! But let me tell you the WHYS! The drum unit is made to last 45 k copies. Sometimes it last more , sometimes, less... The reason for machine ask a new toner is because the gears inside the unit got damaged and the screw type conveyor does no long have traction and does not feed the toner in. Well, the toner density sensor is along this screw and, if no toner arrives there...you got it!
There s no gear kit (for this model) selled apart (not there i know off), but,the image unit (drum kit) is now unproper to work another 45 k. There are drum and blade to reconstruct the unit but with the gears damaged......Buy a drum (image) kit. It will last you another 45k. Note that (in this machine) , you also going to need a fuser roller now and then . It lasts more than 45k if you have the precaution of leaving staplles and clips AWAY from the machine. Best regards Aldo
Posted on May 05, 2014
I replace new toner but toner indication still coming pls tell me
Posted on Jul 19, 2011
  • your drum unit has reached its limit 45k, part number 411844...
No interface setting option in system settings menu
Try this user/tools button then highlight system tools or setting press ok then scroll to interface settings press ok then network press ok there you will find to set ip/ gateway and DNS or highlight auto dhcp and will setup it self with info. Turn off copier and back on should be ready
Jan 17, 2014 | Ricoh Aficio Office Equipment & Supplies
I'm using ricoh aficio 2045e, it's not printing! I think because I don't have the hostname or the ip address and I don't know from where to get it?
Enter in SP mode and print the ALL SMC report .In this report find the IP adress.Enter in your PC printer device the IP adress.
Feb 17, 2013 | Ricoh Aficio 2045e 2035e Copier...
Need installation disk for Ricoh Aficio MP161
you dont need installation disk just log on to copier via the ip adress and set it up via the web interface. the log on is admin or administrator
Oct 12, 2012 | Ricoh Aficio MP 161 Black and White Copier
Can not find ip address on richo 1035. I tried to connect my richo 1035 with computers through internet. I did all to change ports on printer properties section. I am putting ip address of my service...
Connect the machine to a router or a switch with a network cable.
In used mode, under network settings - set the machine to DHCP, so it will get an IP adress from the switch/router.
Print out a network status page, and see if you've got an IP adress.
In the command window on your PC type: ipconfig/all and see the IP adress of your computer. Compare it to the adress the machine got from the router/switch and see if they are almost identical apart from the last digits.
Install the driver, and install the printer using device name, and you should be good to go. Or you can set the IP you got from the switch/router as a static adress, and install the copier using the IP adress.
Jun 27, 2017 | Ricoh Aficio 1035 Copier
How do you print via computer double side print automatically with duplex on a Ricoh 1232C copier printer.? (also know asc Aficio DSC, Gestetner R032C, Infotec)
First you need to enable the duplex option in the accessories tab.
Go to printers, and sellect properties(right click) and accessories.
Feb 25, 2010 | Ricoh Aficio 1232C Color Copier
Network problem with Aficio 1515f
Sounds like you have a wireless router, but are (for some reason) plugging your laptop into it, and if it's not wireless, you should return it and get a wireless one for about the same money, that will let you use your laptop from anywhere, and the setup is often easier, as it can usually all be done via the Installation CD. You can also still plug the Aficio 1515 into the router and print wirelessly to it from your laptop, once you have it configured.
Next, the Aficio 1515 printer feature included a standard usb port, so I find this a little strange.
You can download the manuals here:
http://www.ricoh-usa.com/downloads/manuals/bw/aficio1515/
The 'network settings' guide will be most helpful. The two things you primarily need to be concerned with are the "IP address", and "subnet mask". Do not use "Auto", but rather set them manually, and then configure the printer driver
If you don't have a basic understanding of IP addresses, and network printing, then you'll really need some help to complete the setup
Mar 02, 2009 | Ricoh Aficio 1515F Plain Paper Laser Fax
Revised IP address for Ricoh 2020d
Go to user tools counter. Go to settings. Go to interface. You should see the IP address settings window. Some Ricohs have auto DHCP. Usually I turn that on to get it to recognize your router. Make sure your gateway address is inserted as well.
Jan 11, 2009 | Ricoh Aficio 2020D Copier
Configuration of LAN fax
The best solution I use is Smart Net Monitor, which is supplied with the Ricoh disks or can be downloaded from www.ricoh-usa.com . First you need to install the lan fax driver, after that then install Smartnet Monitor.
From there click start, and then control panel, then printers and faxes, then right click on the Ricoh LAN fax driver, from there click properties, click ports, then click add a port, under available ports you will see smartnet port (highlite) and then select new port, a new box will come up and then select search, the software will then make the connection and add the port. Besure to click ok and apply and then you are connected
Oct 09, 2007 | Office Equipment & Supplies
Ricoh 1515f
This model can be used as a printer and a scanner , but you need to add a print scan controller wich you can obtain at any ricoh otlet .
Pierre
Sep 11, 2007 | Ricoh Aficio 1515F Plain Paper Laser Fax
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
451 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
