I want to buy this to my g900wa lcd monitor...how can assure a safe site...
Did you finaly used this site ? Can we finaly trust them ?
Posted on Aug 07, 2011
When i turn on my lcd samsung syncmaster 540n it displayed a lot of colored vertical and horizontal lines.no video when i attached my cpu but it turns on when i powered my cpu
boot up in safe mode (press f8 while booting) If your monitor works now, you need to go the the samsung site and download the driver for you monitor. I assume windows 7, since that is where most of the monitor problem occur.
Mar 08, 2011 | Samsung SyncMaster 540N 15" LCD Monitor
LCD Monitor (Model Number M17FBA) Signal Out of Range
Hi
Start the computer in SAFE mode. F8 before Windows starts. Once in SAFE mode change the screen resolution to 600 X 480. Do this by right clicking anywhere on the desktop. Once done then reboot into normal mode.
Jun 03, 2010 | Scanport 17" LCD Monitor
Dell E228WFP keeps entering powersave mode
disconnect all the cables from the back of the monitor except the power
you would see a test screen
if it still go to power safe while you are in the test page you monitor cud be bad better buy a new one as usually repairs are expensive
Apr 17, 2010 | Dell E228WFP LCD Monitor
I havE A VEIWSONIC Va520 when I turn it on , it brings up a screen saying out of range H-30-62 KHZ V-50-75 Hz what does this mean?
1. maybe the problem is with windows, because the refresh rate is set to an acceptable value
2. your lcd screen runs at higher hz than 60
3. you are running a resolution higher than 1024x768 15" LCD's generally can only support 1024x768 whereas larger panels support higher resolutions.
Possible solutions
1. The LCD you buy is shipped with a plastic cover over the screen which shows maximum resolution and recommended refresh rate. When you first turn on your computer press F8 to access safe mode, after you enter safe mode, configured the required setting on your lcd monitor. when you are done, reboot or restart your computer, hopefully your computer should be fine.
2. attempt to access the bios setup utility by pressing del or f2 of your keyboard after you see the initial display of your pc, if you can see it, the problem is with windows because the refresh rate is set to an acceptable value. Set it to its required settings by entering safe mode as posted on no.1
http://lcdmonitor-repairsecrets.url-Go.com
Dec 02, 2009 | ViewSonic VA520 15" Flat Panel LCD Monitor
Monitor stuck in standby
Try tapping F8 when booting and then choose 'safe mode with networking'
if this works go to the lcd manufactures web site and look for a specific driver for your screen.
Aug 30, 2009 | Dell E551 15" CRT Monitor
Samsung monitor screen slowly flickers on
try on different computer and see if it still happens if it does time for new monitor as they are factory fix only and not worth cost
Jul 07, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Is it safe to repair a LCD monitor? As its manual mentions, it contains materials like mercury that is hazardous to health
CRT have phospor gas that's also hazardous to health that's why you need to be trained first to service these devices
Apr 07, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
SCRAMBLING SCREEN
befor replacing,make sure settings in video output from video card are set for that monitor.If color quality is set too high or resolution settings not supported by the monitor are used picture may not show up at all.(try safe mode,Settings are usually at bare min.in safe made)
Jan 09, 2009 | Acer AL1715 17" LCD Monitor
Emachine 17" lcd monitor from Best Buy
1: Check the cable connections for the VGA or DVI cable at both ends for a secure connection.
2: There may be a button on the bezel of the monitor for input source to switch between VGA, DVI, or HDMI. While the monitor is on, press that one or more times waiting 2 or 3 seconds between presses to see of it finds the signal.
Apr 10, 2017 | E-Machines e15t 15" Flat Panel LCD Monitor
Board FSP048-3PI01
I found an LCD inverter database list that has the board listed but I am not sure what to do after that. (https://www.combase-direct.com/html/csshop/images/data_sheet/gy15vtsn_edc_parts.pdf) The site also said:
"You can search for updated part codes through CMS web site.
URL : http://ecms. samsungelectronics. com/"
Jun 17, 2008 | Samsung 710N V2 17" LCD Monitor
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
