Cant tune in blaupunkt tv mx 72 83 vtm - Televison & Video
Got the new shape bt vision remote control but cant find the code for my blaupunkt tv can you help
Try these codes. Hopefully one will work.
034,118,119,138,189 if no joy then refer to your TV manual and look for a code there.
Sep 12, 2014 | Televison & Video
My check engine light and vtm light are on in my 2008 Honda Pilot I checked the codes it's saying the egr valve is bad would that cause the Vtm light to come on to
Yes, the VTM-4 module will light up.
Here's the deal; when you manually turn on the Variable Torque Management-4 system, the light to the console switch is illuminated- letting you know that the vehicle is in traction control mode- and it is functioning properly.
However, if you did not manually activate the VTM, and your cruising along under normal driving conditions, but you start experiencing engine problems, like when the Exhaust Gas Recirculation valve starts to malfunction, this malfunction will cause the engine to misfire and lose engine power.
When this loss of engine power occurs, the VTM perceives that the engine power is being reduced to restore traction to the car's drive line (axle and wheels)- so it triggers the light to go on.
The triggering of the VTM could also happen when the idle speed control valve malfunctions.
So once you have the EGR valve replaced, the codes on the OBD module should be cleared; the check engine light will turn off; and the VTM system light will turn off too.
Jul 04, 2014 | Cars & Trucks
What do i do to watch TV with an atena
Connect the antenna at its socket, select the input to "TV" and then re-tune it. Refer its user manual for more about how to tune it. http://electronicshelponline.blogspot.com/
Mar 31, 2014 | Maxent MX-42HPM20 42 in. Plasma HDTV
WHAT IS VTM-4 LIGHT?
VTM-4 LIGHT is the 4x4 option you can use when your in the auto shift gears 1 and 2. When you put the shifter in 1 or 2 gear, you can push the VTM-4 button on dash and you will engage the 4 wheel drive constently. If you switch out of 1st or 2nd gear it will disengage automatically. The VTM-4 also works in reverse gear. Hope this helps.
Dec 27, 2010 | 2002 Acura MDX
How to tune in stations on blaupunkt siena rcm 148
Thats an amplifier, not a head unit. The point of that is to power the speakers. The output on the head unit plugs into this, and the speakers plug into this. You tune the station on the head unit in the dashboard
Oct 08, 2009 | Blaupunkt THA125PNP 300 watts RMS x 1 at 2...
Recording on blaupunkt VCR RTV 430/540 from T.V
the VCR should record even without a tv attached.  The VCR will display what channel it is on.  The TV is only for viewing.
Cable hook up is ..
1. from the wall (or antenna) to the VCR input jack
2. from VCR output jack to TV input jack
Most TVs use channel 3 for VCR viewing.  You will need to hit the TV/VCR button on the VCR also.
Oct 13, 2007 | Televison & Video
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
