When i turn the air on it will not get cold at all, someone mention i could have a leak where the freeon goes.. what kind of problem could this be and how much is the cost of fixing it?
    Genius:
  • 1,033 Answers
Hello, it could very well be a leak, if the air filter, evap coil, and airflow all seem ok then i would suspect a leak. Depending on where it leaks will depend on how much it will cost, if it is just a leaky schreader valve core then the core is just replaced and freon is added to the proper level. This would be somwere in the 100-150 dollar range. However, if it is a leak somwhere in tne lineset or in the evap coil then the leak must be repiared, a vacuum pulled on tje unit, nitrogen added, and finnally freon chraged back in, this would be closer to 400 dollar range. I hope this helps
Posted on May 18, 2011
Air conditioner not working
first check if the compressor engages if not could be fuse, broken wire, or just low on freeon you will need to send it to a ac shop to empty and fill, test for leak
Apr 01, 2014 | 2006 KIA RIO Remote keyless entry
Replaced air compressor, blow's cool air and then warn air
check the blend door actuators and for a vaccum leak to the hvac
Jun 12, 2012 | 2006 Pontiac G6
Can you recharge the freeon in a frigidaire upright freezer?It's not as cold as it should be!
I the freon has leaked out, this means there is a leak in your sealed system. Unless you can find the freon leak, charging the system will do no good. It will leak out again. There are many things to cause a freezer to not freeze. Is this a "Frostless" Freezer or a "Manual Defrost"?
Mar 30, 2012 | Freezers
Fridge has run out of freeon can some be added to stop the fridge from not staying cold
Yes, but it will only leak again if you don't have the leak fixed first...
this can get very expensive...
Here isa tip that I wrote about how to add refrigerant to a air conditioner or coolingsystem
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
Sep 18, 2010 | Refrigerators
A/C not producing cold air
First make sure you pressed the button for the air to circulat internally and the blue air conditioning button is drepressed. If you still don't get cold air,open the hood and see if your ac belt is present. If it is there, make sure it is not slipping. You can mark it with a red permanent marker when the engine is off. If it is spinning make sure the ac clutch is enganging. With your engine on see if the ac clutch on the side of the ac compressor move a little showing it is engaged. It will also load your eninge and there will be a slight difference in speed which you can hear. If all of these are working you most likely need a freeon charge. However, first you will need to check that there is not a leak withing the ac system. This is done by mechanics using a dye. Once the leak is located, it is repaired and freeon is charged into the system. Thanks for using Fixya.
Aug 23, 2010 | 1999 Plymouth Voyager
No cold air coming out of air condition just hot air
Check you ac belt under the hood is not slipping. Check that your ac clutch is engaging.
Check your freeon level.
It is possible you may have a freeon leak. The mechanics will use a dye to determine if you have a leak and where it is. The leak will be repaired and new freeon put in.
Aug 17, 2010 | 1990 Chevrolet K1500
The blower puts out hot air, no cold air,could it be out of freeon? it is a 2000 volkswagon beetle. the air had been working great up til today
you need to have someone look at it that knows vw a/c systems
there too many things that could cause this to start guessing
Aug 14, 2010 | 2001 Volkswagen Beetle
My air conditioning in my Mitsubishi Galant (2005) is not real cold and the a/c light is blinking?
Your Freeon might be leaking or empty. You can buy replacement containers at any local auto shop, should this be the case. And remember, never try to refill a freeon container yourself.
Mar 18, 2010 | 2004 Mitsubishi Galant
AIR CONDITIONER ON 2002 JEEP LIBERTY IS LEAKING FREEON SOMEWHERE IT WILL COOL FOR FOUR DAYS AFTER CHARGING WITH FREEON AND THEN IT BLOWS HOT AIR. NO LEAK VISABLE WHEN I ADDED FREEON DYE. WHERE COULD THE...
its probley leaking in the evaporator you cannot see it without removing the dash see if anyone that you know has a freon sniffer then lacated the drain tube for the evaporator case most of the time its located on the fire wall on the right lower area with a full charge use the sniffer and see if indicates a leak
Jul 09, 2009 | 2002 Jeep Liberty
PINGUINO PAC-L90 PORTABLE AIRCONDITIONER
yes we charge freon if it leaks out, but we fix the leak first. but also it may have electrical problem only, better get it check with a technician
May 09, 2009 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
