Question about Garden
What fuel mixture is suitable for the makita RST 200
200 chevy s10 2.2L 5sd 2wd code P0171 indicates that the bank 1 system is too lean for predetermined period of time
It means the engine fuel air mixture is incorrect. Too much air makes lean fuel burn. The computer will try to adjust by enriching the fuel air mixture. At some point it reaches a limit and kicks a code. Check for sources of intake or vacuum leaks.
Mar 15, 2017 | Chevrolet S 10 Cars & Trucks
How do i mix my 2 stroke for a makita chainsaw how many ml of oil to a litre of fuel
Mix the fuel and oil in a suitable container that is airtight with a secure stopper to ensure the fuel mixture has a long shelf life. Keep the funnel, spout, container, etc., dry and very clean. Storing it all in a large plastic bag serves very well for this purpose.
Any quality engine oil can be used but an oil of the recommended type and viscosity will produce much better results. Purists and traditionalists still like to use vegetable oil but this has a very short useful life and dubious results. Self mixing 2-stroke oils are best and synthetic-based oils are reckoned these days to be superior.
Put fuel in the container first and then add the correct quantity of oil for the number of litres of fuel, close the container and shake with vigour for a few seconds and then transfer the fuel to the tool.
The number of ml of oil to use per litre of fuel will vary depending on the engine type, manufacture and age. The fuel/oil ratio is often marked on the fuel tank or cap, 30:1, 40:1, 50:1, etc.. 50:1 would require 20ml of oil per litre.
Some 2-stroke oil bottles have a useful measuring scale on the side...
Aug 06, 2016 | Makita Garden
Picked up a Makita leaf blower rbl250 model...what is the fuel mixture...I was thinking it is 40:1?
try, it its a good place to start if it blows a lot of smoke thin it out.
Sep 19, 2013 | Garden
Fuel mixture ratio
Oil Mix Ratio:
Starting in the early to mid 90s Dolmar, Echo, efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl and Tanaka all started recommending 50:1
  • 1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil or
  • 4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen recommend 40:1
  • 1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil or
  • 4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
Jan 07, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Regarding makita petrol disc cutter dpc6410- how much oil do i need to add to a full tank?
Don't add oil to the fuel tank, it doesn't mix well in there and you'll almost always use too much oil. Mix your two-cycle oil and petrol in a gas can to get a 50:1 mixture. Read the directions on the two-cycle oil bottle for how much to use and put the oil in the can first so the petrol will mix well with it as you add it to the can.
Oct 11, 2010 | Makita DPC6410 64cc 12" Power Cutter
I want to check if a makita rbc 230 brush wood cutter runs on petrol (neat) or two stroke mixture
I think the model your speaking of is the RBC30. It is a 2 stroke mixture. The 430 models are 4 stroke and do not require mixing oil and fuel. They are made by Ryobi for Makita.
Here is the RBC 30
RBC30SESA
  • Powerful 30cc 2-Stroke Petrol Engine
  • Easy-Start Carburettor
  • Expand-It™ Attachments Compatible
  • 18"/46cm Cutting Path Width
  • 2 Year Domestic Warranty
Info on the 430
RYRBC430SES
  • New 4 Stroke Design
  • Light in Weight 7.3kg
  • Safe Anti-kick Feature
  • Reduced Noise Levels, Lower Emissions
  • 2 Year Warranty
This is pretty much the entire line up of their brush cutters:
http://www.mowdirect.co.uk/acatalog/MowDIRECT_RYOBI_BRUSHCUTTERS___PETROL_STRIMMERS_311.html
There is not a 230 model.
Thanks for choosing FixYa.
Kelly
Sep 06, 2010 | Garden
What is the mixture of oil and gas
Husqvarna recommends 50:1
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Stihl & Tanaka; all recommend 50:1.
McCulloch & Poulan; recommend 40:1.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 24, 2010 | Husqvarna Chain Saw 20" Bar
To keep my Makita weed wacker running I have to close the choke about 3/4. I see no mixture adjustment on the carb and everything appears clean.
An IPL for a 26cc line trimmer can be found here:
BCM2610 Line Trimmer
http://www.makita.ca/data/upload/tools/BCM2610.pdf
The carburetor is pictured but not where it mounted on the engine or how you gain access.
It sounds like it is very lean. Have you cleaned the air filter? Checked for leaky fuel hoses? A loose carb or damaged boot may also be the cause. There is a reason it is running lean. HTH
Lou
Continued operation in a lean condition may cause it to cease.
Oct 02, 2009 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
Makita Generator G2800R
Check your tank for contaminants (water, trash, dirt, monsters, etc), as well as the balance of the fuel system. You may also need to remove the carburetor and clean it out, particularly if the generator has sat for more than a month with fuel in it (most do, including mine) and now has deposits. The only thing that the choke does is make the mixture rich by cutting off the air.
And just for grins, look at the spark arrestor screen on the muffler. This can be related and problematic as well.
Mar 10, 2009 | Makita 2,800 Watt 6 Hp Portable Power...
Blown engine
makita likes you to use at least 91 octane fuel and a synthetic oil mixture. the stens oils is garbage, i switched to the makita oil around 6 months ago and i havent had a problem. also, the wacker saws use the same motor and their piston heads are sleeved in carbon so they last longer and dont score the cylinder as fast as the stock makita heads.
makita also makes a 100:1 mix hi performance oil you can use.
Oct 30, 2008 | Makita DPC8112 16" 81CC Gas Powered Power...
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
