Question about Zanussi Washing Machines
18 month old ZANUSSI "essential 1400" ZWF14069W washing machine wont drain and just stops mid cycle. Start/pause button then flashes red. Emptied water out via drain pipe & cleaned filter but no change. Grateful for advice on anything else I can do.
  • 130 Answers
SOURCE: jetstream 1400.Zanussi Front Load
buzzing indicater mostly motor problem.other possibilitires are  It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
It's slow to fill Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
There's no water at all If there's no water at all, make these checks:
  • Is there water getting to the machine?
  • Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
  • If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown?
  • Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Posted on May 07, 2009
beltronic205
  • 1466 Answers
SOURCE: unable to use ZJ1217, start/pause flashing
Are you able to open the door ?if so door interlock switch could be at fault
Posted on Oct 02, 2009
Testimonial: "this is very helpful, Allthough I am not capable of carrying out this work I do at least know what the repair guy may say. thanks."
  • 53 Answers
SOURCE: has power but not working zanussi zwf14069w
is the door locking? if not check the interlock. if ok check the motor brushes
Posted on Oct 25, 2009
SOURCE: zanussi electrolux essential 1400
bad smell coming from inside the drum how do i fix it? thanks
Posted on Jan 17, 2011
  • 6277 Answers
SOURCE: Zanussi ZWF16381W. The wash stopped mid-cycle
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 07, 2011
How do I stop my washing machine from stopping and showing an error code E20 when it gets to the spin part of the cycle?
These type of machines now have a balance sensor fitted, if you have to much in the drum, or like I did once washed just a single bathroom mat, the drum sensed that the single item fell against the drum making it uneven & stop the spin to protect itself, this could be the problem, try taking some out or even putting more in to even out the wash? if this does not cure it, then you may need to get the error code reset, unfortunately only a washing machine mechanic has the ability to do this, I don't agree with these tatics, but you cant get round it, some can be got from the web.
Apr 12, 2015 | Zanussi Washing Machines
Manual zanussi essential 1400
You have a bad Drain Pump! It needs replacing. Unplug the machine first, Drain all the water out.
Jan 19, 2014 | Washing Machines
Washing machine humming but nothing else :(
if you watch carefully, the end light flashes and then stops, and then flashes again... how many times flashes?
Dec 22, 2013 | Zanussi FS1455W Front Load Washer
Zanussi Essential 1400 ZWF14070W1
Check the belt that spins the drum for proper tension. If it has stretched you will have a hassle. Often you can loosen a belt pulley and put some extra tension on belt, restore friction and operation till belt is replaced with a nice, new tight one.
Nov 23, 2013 | Washing Machines
"ZWF160070W1 Washing machine. Only 18 monthe old!
I would start by checking the filter and cleaning it, this is usually located at the bottom right front of washer behind a flap or cover, unscrew an ti-clockwise to remove and clean.
Nov 14, 2010 | Zanussi WJD1257W Front Load Washer
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
Machine won't restart after reset, 'start/pause' button flashing.
When you put it to drain/spin does the pump make any attempt to drain,if not it could be that there is something stuck in the pump,needs draining manually.Another thing to try is to find the fault code.If you hold down the 2 buttons on the far right of panel then press on/off button till lights start chasing,then release the 2 buttons on right hand side.Now the first function button by the on/off button you will need to press until the light above the button reaches the 9th or 10th position this will give you a read out in the display.
E10 = low water press.
E20 = pump or filter.
E30 = press. switch or heater faults.
E40 = Door swich.
E50 = motor.
Some of these numbers can vary there are more but those are the most common.After checking codes switch off machine then back on twice to reset.
Hope this helps.
Jan 26, 2010 | Zanussi FLE1416W Front Load Washer
Unable to use ZJ1217, start/pause flashing
Oct 02, 2009 | Zanussi ZJ1217 Front Load Washer
WASHING CYCLE STOPS AFTER A MINUTE
Can you skip through the programme to drain? Press pause button. then press start to move the lights down to the empty cycle. leave to finish.
If you have already tried this, I can explain how to put machine into engineer test mode, which will then give out a fault code to identify problem.
Apr 04, 2009 | Zanussi FJD1266W Front Load Washer
Zanussi jet system 1200
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Press "end of cycle" to finish the mid stoppage..
Rate me pl.....if helped.
Jan 02, 2008 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
129 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
